Night Flying Night Flying Helis Info |
10-07-2012, 11:18 PM | #122 (permalink) |
Super Bright Led install on my quadcopter.
New LED install.
[YOUTUBE][ame]http://youtu.be/LOSoBEhII5w?hd=1[/ame] |
10-07-2012, 11:48 PM | #123 (permalink) |
10-19-2012, 04:26 AM | #124 (permalink) |
Align Trex 550 stretched with Bell 222 fuse. Align Trex 600e Pro. Last edited by phobius; 10-31-2012 at 12:06 AM.. |
10-28-2012, 12:13 PM | #125 (permalink) | ||
Firework display with 'Night Magic Blades'
Hi Guys,
I've just flown a display in the UK at a local school firework do. I managed to get some video shot of it and thought I'd share it with you all. Hope you enjoy it
Fast Lad Performance Edge blades Opti-power |
11-01-2012, 12:51 AM | #126 (permalink) |
This is my Trex 600 Pro in night flight setup.
HD750, TDR II, TDR, Logo 700, Logo 700 XXtreme, Logo 550SX V2 |
11-08-2012, 07:11 AM | #127 (permalink) |
These are the first pictures I see where somebody has used different colours left and right. As I come from planes I'm used to that and so I have at least different colours at the boom of my 600 (blue left, green right, white down).
How are your experiences with orientation ? How useful are different colours in your opinion ? RK |
11-08-2012, 09:47 AM | #128 (permalink) |
A video of a friends TRex 600 with led-lights and Align night blades. It worked and looked cool but unfortunately there is not enough light on the blades. Looks good from beneath but needs more light on top. Still a good idea and something to work on.
Enjoy: [ame]http://www.youtube.com/watch?v=tIUEnnCNUGM[/ame] Clips |
11-08-2012, 02:54 PM | #129 (permalink) | ||||
As of different colors on different sides, it helps the orientation to a certain degree. I have terrible eye sight and it is worse in the dark. Different colors helps me personally. Here's video my buddy shot last weekend. You can take a look to see whether it helps or not. The added benefit is it gives you more effect.
Hope this helps Happy night flying Cheater
11-08-2012, 03:29 PM | #130 (permalink) | |
Nice birds everyone
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0 PRÔTOS 500 FBL "Sky Whip" | Robird G31 Audacity P6 FBL "Phoenix" | MSH Brain | 12s Goblin Speed | iKon |
11-08-2012, 03:54 PM | #131 (permalink) |
Hello clips. Guess you are the one who recorded my First attempt at night flight then :-D
I soon discovered that the blades was to dim, making it too easy to loose orientation. Now Im just waiting for the parts to make diy blades. Taoy: What type of Brushless speed controller do you use? Sent from my U9200 using Tapatalk 2
-------------------------------------------------------------------- Spelling check : OFF Logo 600 3d - Vbar, T-rex 700N DFC - Vbar, T-Rex 600EFL - Vbar, T-Rex 450 Pro BeastX Spectrum DX8 With NO PROBLEMS |
11-08-2012, 08:11 PM | #132 (permalink) | |
11-09-2012, 02:43 AM | #133 (permalink) |
I also tried that on my 600 but it didn't work very well. First the ESCs needed 0% to initialize which is not very comfortable as I only wanted it to be a fixed value. Then the regulation at lower light/throttle was very bad. It even flickered at low values. Maybe I had too intelligent ESCs but my simple ones all are only for 8 Nixx.
In the end I just used ~3 diodes to dim the boom lights. RK |
11-09-2012, 03:04 AM | #134 (permalink) |
I use the same HK ESC with my night rig and use it on a slider as well. Just have 0 when you plug in and then set the light brightness. The best thing with this setup is that you can set the lights based on ambient light so if you are flying at twilight you can have them up full and back them off to match the blades when it is darker.
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1 soXos DB7 nightflyer : Jeti DS-16 & DS-12 I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades |
11-09-2012, 01:24 PM | #135 (permalink) | |
I'm going to try led-lights too but I will start with airplanes first. They are much more comfortable to crash. Won't be until January though as I'm leaving for Thailand pretty soon. Hopefully I'll be flying during the daylight and way to busy with other stuff at night Clips |
11-14-2012, 05:03 PM | #136 (permalink) |
I also got that brushed ESC to try, but am not using it.
I hope i can make it usable by reprogramming the chip. It would be a relatively simple program. There are already a few projects running to reprogram the cheap brushless ESC for quadcopter use. Just need the basic parts from that program. PWM input and PWM output algorithm. that is all! And i believe that is partly incorporated in these chips already. For our use we are just switching a single FET on and off. Unfortunately the chip is unbranded. I am assuming it is just one of the simplest popular PIC chips, but i will need to trace a few pins to their function and compare to the datasheet. It has 14 pins. Perhaps it is even easier to build one from scratch. Just the PIC chip and a FET is needed. gets its 5V control power from the servo lead. As usual my plans are bigger than my time and brainmass.
MSH miniPRÔTOS & PRÔTOS 500 a better way to fly GAUI Hurricane 425 night rig & 550 the monster |
11-15-2012, 07:28 AM | #137 (permalink) | |
Might be easier with one of the RC switches, maybe a kit. The chip could be socketed. As long as a transistor is the switch it should work RK |
11-15-2012, 09:00 AM | #138 (permalink) |
What is the problem with using the esc as it is? I have two brushed esc in the mail for night setup. Hope it will work. If i need to make a new program for it, it will be simpler and faster to build my own controller.
It is a very simple program that is needed for basic pwm dimming. Sent from my U9200 using Tapatalk 2
11-15-2012, 08:58 PM | #139 (permalink) | |
//Dennis.
12-12-2012, 05:27 AM | #140 (permalink) |
Ok heres my first attempt at making my own blades....
Not to hard. Thanks to everyones input from here...... Running a reg on the canopy LEDs. runing @ 10.5 volts. 12 is too bright! Im going to get some heat shrink for the batts tomorow..... Align 523 Blades. Trex 550E heli. Align logo is the top or course....... Right hand Blade..... |
