Old 07-28-2014, 03:36 AM   #1 (permalink)
Default Castle ESC Programming
hi
I want to swap my ESC to a caslte light 100AMP
My question is does anyone know the programming for the castle?
I know from my Align heli's I can just input the gear ratio's etc, is there any information on the logos todo this?
DX18 & VBAR EVO | LOGO 600SX VBAR NEO | T-REX 500XT VBAR NEO | T-REX 600N AR7200BX | 450X
thomascoleman is offline        Reply With Quote Quick reply to this message
Old 07-29-2014, 05:04 AM   #2 (permalink)
Yes, you can put your heli's motor, gearing info.
You can download the Castle Link software from CC's site and can run it in demo mode and can see exactly what settings you can adjust the esc.
|Michalis|
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 07-29-2014, 12:40 PM   #3 (permalink)
Might this be what you are after?
http://www.vstabi.info/en/node/1539
Team Mikado USA!!!
Team Scorpion!
Logo 600SX - Scorpion 4035-560, 10s 4400 packs
Logo 690SX - Stock Scorpion motor, 12s 4500 packs
sgrim80 is offline        Reply With Quote Quick reply to this message
Old 07-29-2014, 03:01 PM   #4 (permalink)
That only applies to running the Edge series Castle ESC on a vbar governor. It's a great setup, but I'm not sure that's what the OP is after.
acidla is correct, to run the Castle gov you can just plug the gearing info (tooth counts, motor size) into the CastleLink software and it will calculate the ratio. Then tell it which headspeeds you want. In order to know your gearing we would have to know which Logo. Plus we would have to assume a stock setup which may not be correct. Best bet if you don't know is to just count the teeth.
Team MikadoUSA
hemp is offline        Reply With Quote Quick reply to this message
Old 07-30-2014, 02:52 AM   #5 (permalink)
I don't care about running a gov.
All I want todo is program the Castle ESC with the correct information for the Logo 480 motor.
So far I cant find what those settings are..........
Old 07-30-2014, 03:57 AM   #6 (permalink)
If you aren't going to run a governor then you don't need to tell the ESC about your gearing. ESC doesn't care about gearing if you're just running a throttle curve.
Assuming you got the motor combo then the motor you're asking about is the Scorpion HK-II 4015-1070. Details for that motor can be found here: http://www.scorpionsystem.com/catalo.../HK_4015_1070/
Specifically what you need for the CastleLink in order to set up the governor is the motor (magnet) pole count, which according to that page is 8 (eight) and/or the motor kV which is 1070.
As for the gearing, the combo pinion size is 23t, the main gear is 212t.
Team MikadoUSA
Old 07-30-2014, 04:17 AM   #7 (permalink)
Perfect - as if I was to add/switch on Gov I just need to inout those fields on the castle?
Old 07-30-2014, 04:20 AM   #8 (permalink)
if I was to add/switch on Gov I just need to input those fields on the castle?
That's correct. The CastleLink software has input fields for those values, or you can input the gear ratio directly (needed for some models like the Goblin that have a two-stage drive.)
Team MikadoUSA
Old 07-30-2014, 04:21 AM   #9 (permalink)
Perfect thank you for your help
Old 07-30-2014, 11:40 PM   #10 (permalink)
In case you were not aware, there is a dedicated Castle Creations sub-forum too.
https://www.helifreak.com/forumdisplay.php?f=261
You didn't mention what kind of FBL controller. One would think that doesn't matter, but actually just in case its a 7200BX, there is a recommended procedure, particularly as a pre-cursor to governor mode. This helped me a lot.
https://www.helifreak.com/showthread.php?t=549141
petertha is offline        Reply With Quote Quick reply to this message
