Old 01-22-2014, 09:01 AM   #221 (permalink)
Default Soko has done it!!
Originally Posted by jbobb1 View Post
Using a leveling table has nothing to do with the swash plate configuration. The table is used to get the main shaft at a absolute vertical position, which is a 4 point measurement. Then you get the swash level, set pitch with the Soko and adjust the linkages to do so.
Yes, but it makes the spirit level part easier
770 Evolutione
Black Thunder
7HV
X5 - 550
TBur is offline        Reply With Quote Quick reply to this message
Old 01-22-2014, 09:09 AM   #222 (permalink)
Yes, spirit level only. I suppose one could measure as many points as you want. I just use three as it's easy to reference them repeatedly by using the three links on the swash Then adjusting the corresponding table leg. I would think if you get 0 on these three positions it should read zero in any position.
770 Evolutione
Black Thunder
7HV
X5 - 550
Old 01-22-2014, 09:36 AM   #223 (permalink)
So you find it fairly easy setting the main shaft at vertical with only 3 adjustments?
jbobb1 is offline        Reply With Quote Quick reply to this message
Old 01-22-2014, 12:51 PM   #224 (permalink)
Hey guys!
Great you like the videos - put some thought in it to make it as short, clear and multilangual as possible
@nick: great you sorted it out. if you calculate the target angle in with facing to the two other sides it would be the same
About the leveling table:
I think it is personal preference and also depends on the size of the table. Here are my 2 cents:
- If the size of the table is not (much) bigger than the area of the heli skids 3 legs can be unstable. 4 legs are always stable as long as they are out of the skid area.
- With 3 legs you cant get a wobbeling table
- Its hard to tilt the heli just to the left or right when using 3 legs
Soko
The future of setup... now! Soko Heli Toolbox app for a next generation setup experience.
ONE tool for ALL setups of ALL sizes and ALL brands of helis
www.soko-heli-tools.com
soko is offline        Reply With Quote Quick reply to this message
Old 01-22-2014, 01:53 PM   #225 (permalink)
The first video was very well done. Kudos!
It conveyed a lot of information very quickly.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 01-22-2014, 02:55 PM   #226 (permalink)
Soko
Heck, I just take a turn off one side and add an equal turn on the other. Table tilted. The single on the other end gives me the fore aft lean angle fairly quickly. The larger the table the more stable they are! The only time I have ever had an issue was when I leaned against it standing up one time. That almost got real ugly in a hurry....
Old 01-22-2014, 04:31 PM   #227 (permalink)
@mkovalcson: thx man!
@luvmyhelis: u r right of course if you do the same amount of change to both legs just the opposite direction u get a pure left/right tilt.
Old 01-27-2014, 07:49 PM   #228 (permalink)
Having set up all my helis with the soko tool now, I can safely say it's pretty awesome. Much easier (and faster!) than fiddling with a pitch gauge on the blades.
Team Only Fine Helis
smwht is offline        Reply With Quote Quick reply to this message
Old 02-01-2014, 06:18 AM   #229 (permalink)
My new levelling table,
Thanks to Luvmyhelis and Soko for the ideas and help
Busher is offline        Reply With Quote Quick reply to this message
Old 02-01-2014, 02:50 PM   #230 (permalink)
looks great! I love your "added" feature: THE handle
Old 02-01-2014, 06:34 PM   #231 (permalink)
Default My Soko doesn't seem to fit my Blade 500X
Ok, first off, I'm pretty much brand new to CP helis. Only other one I've flown, and not much, is the McpxBL. But, I got a new Blade 500X at a good price so I bought one. It'll be a while before I attempt to fly it, but I wanted to make sure it was all good to go, so I bought the Soko tool after some research. I've not even mounted my blades yet, but wanted to try out the tool. Problem is, the Helical doesn't seem to fit. The blade screws fit in the 550 holes, not the 500 hole, but the helical only fits between the blade holders at the 500 size. I noticed someone else earlier in this thread said he's used it on a 500X, so I'm really confused. I sent an email to Soko (probably the same guy that seems to be reading this thread), but it's Sunday there, and don't really expect any response. Just wondering if anyone else has had this issue, or if I'm just having a brain fade.
Thanks,
Jim
jimbes is offline        Reply With Quote Quick reply to this message
Old 02-01-2014, 07:37 PM   #232 (permalink)
Thanks,
Jim
Sounds like the 500X uses thicker blade bolts than a typical 500. You'll probably have to find some thinner screws for mounting the soko tool, you should be able to pick up something that'll work at your local hardware store for a buck or two. Just take the helical with you and find a screw that fits, plus a nut for it.
Old 02-01-2014, 08:32 PM   #233 (permalink)
I used it on my 500x and I had to go to my hardware store and get some bolts that would fit properly. It's a Blade thing I think, in using non-standard sized grip bolts.
johnsma22 is offline        Reply With Quote Quick reply to this message
Old 02-01-2014, 09:45 PM   #234 (permalink)
in the first vid where he is leveling the swash. Is he making the adjustments in his radio trim? Is that the right way? Seems you bump a trim now you lost your level. Why not adjust the links?
maskale is offline        Reply With Quote Quick reply to this message
Old 02-02-2014, 07:43 AM   #235 (permalink)
It depends how far off you are. If you aren't using turnbuckle links to the swash, "level" can be between turns so the only way to get level is to adjust the trim. How you do this depends on your fbl unit. Same thing for leveling at the travel endpoints - the only option you have there is electronic adjustments.
Old 02-02-2014, 09:54 AM   #236 (permalink)
Default Just got a smaller bolt/nut combo
Let me make sure to give credit to Andi from Soko. He replied to me within minutes of me sending him a message. Right after I posted here, I realized I could simply try to use a smaller bolt and nut. Surprisingly, I actually couldn't find anything at home, so a quick trip to Home Depot and I'm all set. You guys who responded are right. It's a Blade thing, as Andi pointed out also. I did try to see how well my heli was set up straight out of the box, but only got about 1/2 way through. Still learning terminology and trying to figure it all out.
Thanks for the replies!
Jim
Old 02-02-2014, 12:51 PM   #237 (permalink)
Hey guys,
Great you are sorted jimbes and maskale.
And a big thx to smwht & johnsma22 for the great answers
Soko
Old 02-09-2014, 02:09 AM   #238 (permalink)
Default how embarrassing!
I used my Soko yesterday to tune up my Protos 500 and Compass 6HV. What a difference this made! I am embarrassed how poor my previous attempts to level everything must have been! Absolutely stunning flights today, and very noticeable what a difference spending some time (and using proper tools) can make.
I'm sure that there are people that can do a great job without needing a Soko, however for me, its certainly been a great way to do a proper job.
btw, the Soko user manual puts every other manual that I have seen in the heli world to shame. Sets the standard for how user manuals (and support videos) should be developed. Nice one.
Compass 6HV FBL | Stock Motor | CC 80HV Ice2 ESC, gov via SK720 | SK-720 FBL & PowerBus
MSH Protos 500 | Scorpion 3026-880 | CC 75A Ice Lite ESC, gov via SK720 | SK-720
Other: Spektrum DX9 | iCharger 4010 Duo
boltor is offline        Reply With Quote Quick reply to this message
Old 02-14-2014, 08:28 PM   #239 (permalink)
Well, another new build done using the Soko system. And man I am glad I had the leveling platform under it. Just look at the severe rake of the skids on this one. Got it level side to side and the head perfectly straight up and down in just a few minutes. Tonight however my gauge was sticking on me, no biggie. It still worked like a charm...
ID:	487430   Click image for larger version
ID:	487431   Click image for larger version
ID:	487432   Click image for larger version
Old 02-15-2014, 08:58 AM   #240 (permalink)
I also just did a full setup on my compass 5.5...I.m very impressed with the SOKO.As said the manual was excellent.This is the first time i feel my heli is near perfectly set up.I,s also a breeze to use.....
COMPASS ATOM 5.5 SKOOKUM 720BE+ 540,YGE 120,Scorpion 4015-1070,Gaui X3,540 skookom,BLADE 450X AR7200BX,2 MCPX BRUSHLESS/DX9
tripper is offline        Reply With Quote Quick reply to this message
