NX4 Discussion and support of the Gaui NX4 Nitro Helicopter |
11-23-2012, 10:30 AM | #1 (permalink) |
LiFe 6.6v pack
Planning to use Hyperion LiFe 6.6v unregulated. I use the same setup in my 600N and SDX with 2100mah. I wonder if anyone here uses a smaller LiFe pack than 2200mah to reduce the weight
Rudy |
11-23-2012, 10:41 AM | #2 (permalink) |
I have and plan to use the hyperion 1450 mah pack
11-23-2012, 11:31 AM | #3 (permalink) |
I just check the spec.
1450mah is 82.3g 2100mah is 106g. The difference in weight is 23.7g which is not so significant. I may just go with 2100mah. |
11-24-2012, 04:55 AM | #4 (permalink) |
I wouldn't worry to much about the weight. I have a 2250mah 7.4 on mine right now. With no muffler or fuel it is still tail heavy.
Teambob00 |
12-09-2012, 04:05 PM | #5 (permalink) |
li-fe
im planning to use a li fe too. was trying to figure which is too big or too heavy? anyone know what weight will make it nose heavy or tail heavy? i was gonna go with a gens li fe 2100 6.6v at 125grams or the 1800 at 110 grams.
12-09-2012, 08:34 PM | #6 (permalink) |
I used this same pack 1450 LiFe over the weekend and got 5, 7 minute flights no problem. JC went 7 flights with his before a charge (which I wouldn't try)
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR |
12-10-2012, 07:17 AM | #7 (permalink) |
li- fe
so matt. how is your nx4 balancing with the 1450mah? it it tail heavy too?
12-10-2012, 09:47 AM | #8 (permalink) | |
For example with my X5, I can run a 2600 mAh 6S pack or a 5000 mAh 6S pack, or a 2200 mAh 3S pack and it hovers perfectly neutral with all of them. It piros pretty flat with all three as well. This is with a VBar. My NX4 is still in a case from traveling. When I get it back together, I'll check the CG. Hopefully someone else will be able to respond quicker.
05-29-2013, 02:38 PM | #9 (permalink) |
Just to confirm, the 2100mah LiFe will fit? My LHS only has the 2100mah in stock
Minion Mini Quad 4S / Mini Talon V-tail Drone / Micro H Quad on Taranis FPV |
05-29-2013, 04:15 PM | #10 (permalink) |
My nano tec2000 fits on lower tray
Rick, Team pilot , EGODRIFT, KST, Helidirect, Lynx/Oxy |
05-29-2013, 06:20 PM | #11 (permalink) |
Perfect, thanks!
06-03-2013, 02:50 AM | #13 (permalink) |
06-05-2013, 01:36 AM | #14 (permalink) | |
