Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Odin and 3D+
Odin and 3D+ Compass Odin and 3D+ Model Helicopter Discussion
Old 04-17-2013, 12:55 PM   #1 (permalink)
Default boom strike just after $250.00 rebilled
crashed my compass 3D plus from doing tic toc to low. $250.00 later i got it back in the air i was fling around and then did a full roll and the heli reacted kind of slow and then blow up in mid air. my blades were tight and head dampers are good. i did noticed that when seting up for the 6 degres cyclic pitch that beastx was in the read. this was the fist time that it was really in the red zone. could this have cause a boom strike?
joecass2 is offline        Reply With Quote Quick reply to this message
Old 04-17-2013, 01:04 PM   #2 (permalink)
Closed Account
did you check for binding? E-ring? Might have popped a link.
Error401 is offline        Reply With Quote Quick reply to this message
Old 04-17-2013, 01:46 PM   #3 (permalink)
whats the E ring?
Old 04-17-2013, 01:48 PM   #4 (permalink)
Closed Account
cyclic limit. I forget the exact step in setup.
Old 04-17-2013, 10:35 PM   #5 (permalink)
Probably popped a link going from swash to grip arm. How many flights on your links? What about the grip arms and yokes them selves, did you do anything to those in your previous crash?
This is the first time I have personally read of a boom strike on the 3DP or 6HV.
Airtronics SD10G, SK540
Synergy N5c, Novarossi .57 3DS
MAAC #85462
Down Low is offline        Reply With Quote Quick reply to this message
Old 04-17-2013, 11:03 PM   #6 (permalink)
Registered Users ):>
+1,
Have you replaced the links on the delrin tubes?
I make it a point to replace them after a crash.
They get loose after time and crashes and risk the chance of poping a link.
P.S Hate to hear about your crash.
Banging them sticks.
-Dan Duzinski
frypan is offline        Reply With Quote Quick reply to this message
Old 04-18-2013, 12:45 AM   #7 (permalink)
This is a typical for a breakage of one blade link from my experience.
The heli is then reacting like half cyclic and bearly steerable. When you put load on the disk like in a roll or a flip then the blade can run out of the normal very much and strike.
I guess that one of the links was damaged and you did not see the microcrack in the repair.
RogerRabit is offline        Reply With Quote Quick reply to this message
Old 04-18-2013, 02:37 AM   #8 (permalink)
agreed , sure sounds like in your rebuild , you missed something.
sry for your crash , sucks when it isnt your fingers puttin it in. well , sucks more.
one thing ive found helps me a lot , i got a silver sharpie marker , and i "color" my links with it after any damage to check for hairline fractures , it really makes a crack in black plastic stick out well visibly.
Warp, 6HV LED,6HV, Alien 450 MR, 250 mini Quad racer(4s monster) FPV rules the roost!
Airworks is offline        Reply With Quote Quick reply to this message
Old 04-18-2013, 12:12 PM   #9 (permalink)
That is a good tip.
We have a crak-detection spray for metal in the company. That works with color also:
http://www.technolit.de/App/WebObjec...Spray-Set.html
I use it on aluminium like bladeholders.
Old 04-18-2013, 04:22 PM   #10 (permalink)
Nice tip
And to the OP sorry to hear about crash
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is offline        Reply With Quote Quick reply to this message
Old 04-18-2013, 10:26 PM   #11 (permalink)
I replaced the 2 links from the grips to the swash plate. but I did not replace the 3 links that run up to swash plate. when I was looking at the heli after the crash I did noticed that one of the 3 swash links were missing. parts will be here Monday $394.74
Old 04-19-2013, 09:46 AM   #12 (permalink)
The Delrin Drive Tubes, as well as the links can crack.
I had one that looked fine, unless you looked at it very closely, after a crash. The bottom portion of the tube, which supports the shank on the link had split.
I caught this before flying, but I suspect it would have let go in flight.
Old 04-19-2013, 10:29 PM   #13 (permalink)
thanks Ah Clem I will keep a look out for that
Old 04-30-2013, 06:46 PM   #14 (permalink)
I've blown off links on my Atom 500 before which made it 'boom strike' but that was only a result of the entire arm free-flapping on the grip and the blade collapsed when I hit throttle hold.
Sure sucks to go through these kinds of mis-haps. Unfortunately on my larger machines these types of problems have led to probably over 1/3 of my total incidences/crashes with the #1 cause being lost servo connectors.
Chin up at least. It's a great machine to have around. I know I'm going to be a mess the day I ever put mine in.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote Quick reply to this message
Old 04-30-2013, 09:30 PM   #15 (permalink)
thanks guys. on the rebuild I noticed that one ball was missing on the iner part of swash plate
Old 04-30-2013, 11:04 PM   #16 (permalink)
Yeah I had the exact same thing happen on my 6HV. There was an advisory put out a couple years ago that you should use red Lock-tite on the swash balls to keep them from working their way loose. The newer solid balls were supposed to help combat the problem but they should be checked periodically just like the yoke bolts and any other fastener that goes I'm the head and tail components.
Again, sorry that that happened. I suppose it's a message that should be reiterated from time to time.
Tim
KBDD TEAM PILOT
