Old 01-06-2010, 02:09 AM   #1 (permalink)
Default Jive + mini vbar + dx7 a weird problem
hi all,
i have been building a fbl protos, ran into a weird problem. i cant seem to get into programming mode or arm the jive. i can however do that with a r7000 receiver. i suspect it has something to do with the mini vbar not sending out correct 0 throttle to the esc. i tried to adjust the throttle subtrim and endpoints so that under receiver adjustment in vbar software it would show 0 throttle at mid stick, 100 and -100 at high and low sticks. i also tried normal and reversing the throttle in dx7. no dice. scratching my head here.
anyone has a simliar setup got their jive to arm?
thanks,
buggiez is offline        Reply With Quote Quick reply to this message
Old 01-06-2010, 03:52 AM   #2 (permalink)
BD Forum Support
The Jive calibrate you throtle during setup process.
1) connect the receiver (mini V) to the Jive
2) set the throtle stick to the 0
3) plug the battery
4) wait for beeps
5) unplug the jumper on the Jive
6) wait fo the beeps
7) now it will be beepipng according to the MODE
one beep - MODE 1
two beeps - MODE 2
four beeps - MODE 4
When you hear four (4) beeps pull the throttle to the max
8) wait for the beeps
9) unplug the battery
This is the whole Jive setup and it also calibrates your throttle stick. Now it should work!
popokatepetl is offline        Reply With Quote Quick reply to this message
Old 01-06-2010, 03:59 AM   #3 (permalink)
I have your setup except with a Jazz, and the above post was my experience as well.
Except come to think about it, I may have had throttle hold on (-5%) at step 2
But either way, it all worked fine.
http://www.helifleet.com/Justin <--- check out my fleet get your fleet online
nyc863 is offline        Reply With Quote Quick reply to this message
Old 01-06-2010, 06:47 AM   #4 (permalink)
BD Forum Support
.. actually that's why you should calibrate your JIVE via mini-V.
Old 01-06-2010, 01:36 PM   #5 (permalink)
do you use subtrim and endpoints to get throttle channel on the rx adjustment window in the vbar software to 0 at mid stick, 100 at high stick and -100 at low stick first? when you say throttle at 0 you mean low stick right? i ll give it another go when i get back home tonight.
Old 01-07-2010, 04:07 AM   #6 (permalink)
got it resolved, ended being that i was using the wrong port. i was using Rx C port instead of Rx B port which sends out the throttle signal. thanks all for your helps
