10-09-2011, 02:01 AM
#81 (permalink)
Originally Posted by Lee2782
I noticed your Ail is +66 and your Ele is +62. I was under the impression with 3G and 3GX flybarless unites both Ail and Ele both have to be set at the same value? Is this not the case??
Hey.
No this is not the case I've found, you won't have any problems using different flip and roll rate values. On both the 3G and 3GX's I run differing swashplate mix and pc software cyclic values.
Bear in mind that on the elevator axis you have a pendulum weight which is going to effect any elevator movement in the form of the tail rotor held out back on the end of the boom.
