Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
01-03-2011, 04:47 PM | #121 (permalink) |
If I understand what you are saying it would seem to me that it matters how much current you expect to draw through the Powerbus. If expected draw exceeds the capacity of your balance connector wiring then that method won't work and you should be using the Western Robotics BEC(?). A related link is:
http://174.133.212.163/showthread.php?t=259116
Always learning, and enjoying the process! |
01-03-2011, 04:54 PM | #122 (permalink) |
Cheers for that, im going to go with the Western Robotics BEC as i don't want to mess about with a rig this expensive.
Also, i wanted to loose the need for a 2s lipo powering the bus/servos and the xtra weight involved. So to summerise, Compass 6hv fbl running on 2 x 6s packs - external bec with internal not used external bec powers the powerbus which then powers the servos direct and then the 720 unit itself. Sounds easy hey
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep |
01-03-2011, 05:00 PM | #123 (permalink) |
Being relatively new to this I can't say that I'm the "heli set-up voice of experience" but from an engineering perspective what you said makes sense as long as the WR BEC/wiring can supply the necessary current. Have fun!
01-03-2011, 05:02 PM | #124 (permalink) |
Well, i've found this 1 looks just the ticket, there is a superbec but thats $99 and has more functions than i need.
http://www.western-robotics.com/herc...-HV_plane.html
01-03-2011, 06:11 PM | #125 (permalink) |
Team Taco VP
Thats the unit! It's what I will be using on my 6HV.
Bob
"Don't Taco My Pack Dude!" NEW Video Link -> Safety Video #1 Video Link -> CAUTION using powerful tools! Video Link -> How to CRASH TWICE in one flight! Video Link -> Don't Taco! |
01-03-2011, 06:14 PM | #126 (permalink) |
Thats good to know then I have seen the CC bec pro now too, any thoughts?
I do like the look of the whole western robotics, they remind me of our own spartan somewhat. I like that
01-03-2011, 06:17 PM | #127 (permalink) |
Team Taco VP
Have not used a Castle unit either. BUT.... some guys out here with the first versions had problems with the wires breaking off at the case due to vibration. After seeing the failures I know it was "user" created based on letting the wires flap around like a mad man. It could have been prevented in my honest opinion but, they could have strain relieved the wires better.
For me the WR BEC looks like the ticket for this heli anyway. Bob
01-03-2011, 06:22 PM | #128 (permalink) |
Thats just made my mind up then, what with all the cc bad press lately, and the fact that my ice 50's case fell apart out of the box
The western will look like it belongs with the spartan lipo guard too almost like there made in the same place Thanks for your help, again
01-03-2011, 06:47 PM | #129 (permalink) |
Team Taco VP
Well don't get me wrong. Even though I have not personally used the CC BEC, the failures I have seen were due to complacent installations. It would be nice if CC beefed up the unit to be more user FU install friendly and all but I do not think it is a bad unit based on the design (yes I had one apart to fix broken off wires for a friend).
So I think the CC BEC is a good unit you just have to take some care with it. I for sure would be concerned about reliability on a Nitro heli though... I would mod the unit right off the bat to make sure no wires broke off inside the unit. Again however I think the design is totally capable of handling the AMP draw they claim. Bob
01-04-2011, 12:57 PM | #130 (permalink) |
Bob,
The western robotics is ordered now! I would have probably gone with the CC one as its compatible with the castle link i already have, just don't want to take any risks with a bird this size and expense, so the thought of a wire coming loose doesn't instill much confidence in me. This will be my first large heli and as such everything has to be done right first time. BTW, you planning on soldering a balance lead to yours and plugging into 1 of the balance plugs or direct solder into esc? Cheers..
01-04-2011, 01:03 PM | #131 (permalink) |
Team Taco VP
My last setup I made a double deans (soldered a male and female together end to end). This way I could power the BEC only off the main pack if I need to.
I think I show this setup in my Compass 600E videos on electronics placement. Bob
01-04-2011, 01:05 PM | #132 (permalink) |
Nice 1 Sounds like a plan
01-29-2011, 08:22 PM | #133 (permalink) |
hi fin i could use some help badd mann
im haveing trouble figureing out this esc bec thing as far as gettin it all hooked up and bount. can u help? i have a dx6i and a ar6100e and i cant figure out how to do it but jas off here has tryed to explain. heres what hes got: my post: i am haveing some trouble settin up my trex 250.... i have a align 15a esc and castle compatible bec.. the wires from the esc are done right as this heli was purchased used with the red wire already took out of the equasion in the esc. and i have a ar6100e rx the ports on it are as follows from left to right.... batt thro ale elev rudd gear aux1 i am told i have to connect the pit servo to aux 1 i am unsure where esc and bec wires go?? ale elev rudd and gear are as follows i think ale is the front servo on the left side of the heli lookin at it from the tail in position elev is the rear servo pit is the right front servo rudd is the 3 wires from gyro gear is one wire from servo.....although i dunno if it goes in the + or - positon (top or bottom)??? i also dunno witch way to plug the wires in?? i assume black is plus and white is minus am i correct?? also need help on bind process... do i need to have all the servos pluged in exept throttle or what?? i do have bind plug and have been told it goes on the batt slot am i correct and can anyone put up an easy process for all this it would be a vital post here in this thread..... thanks alot guys his post: You have most of that right except the RED wire is the power - it's in the middle. The black is usually negative and the white or orange is the signal. Now, here's the tricky part. In order to bind the thing, you need to stick the bind plug on the battery port of the receiver, but that's where the BEC plug goes. So... what some of us do is, we take the single wire from the gain on the gyro, and we stick that wire into the open slot on the BEC plug, then stick that all in the GEAR channel. That way you're powering the RX and getting the gain signal on the same plug, and you have the BATT slot open for the bind plug! Brilliant Now, during binding, you might want to unplug the motor wires, but not the ESC signal wire into the RX. end of post: my only problem with that is i dunno how to take the wire out of the plug and i also dont have an open port on my bec... its on the esc and i dunno if that would work or how to do so?? sorry for the novel jake |
02-03-2011, 04:51 AM | #134 (permalink) |
JR R922 Receiver System
So, are DS 610's (6v) servos usable with the output voltage of my R922 receiver system? I can't seem to find the output specs for it anywhere. Probably should put my glasses on...
02-03-2011, 05:18 AM | #135 (permalink) |
Team Taco VP
Almost ALL RX's output what you put in, the only exception is the AR7100R which has built in regulators. Not sure what a R922 is but your servos are running what voltage you are putting into the RX.
Again other than the AR7100R, RX's have a common power "buss" and all power pins share a common trace in the RX. Thus whatever is coming in is what is powering your servos. Make sense? Bob
02-03-2011, 11:59 AM | #136 (permalink) |
Thnx Bob, that definitely makes sense. We will be chanting songs of thanks over the desert campfires here in the UAE.....
So, physically what does happen when one tries to run 6v servos (which I have) at 7.4v (which I now know is coming into my RX)......bad things I assume, but, shortened life, unpredictable performance, quirkiness as what I have after my fifth cup of coffee....? MS |
02-03-2011, 12:33 PM | #137 (permalink) |
Programming mode
Hi Bob,
I recently bought a used Align ESC ( RCE-BL70G ) which has the built in BEC ( I believe). My question is this: To get into the programming mode (Dx61 and 6200 rx), do I need to have the motor (Align BL500L) connected (is that why you did in the vid ...i think it was this vid, I've been watching so many of yours recently )? I ask because I wanted to test the ESC to make sure it is ok. It's probably only a couple minutes to drop the motor and connect it (out of the bird ...500 clone used), but I need to get some new bullet connectors for the motor (i think they are 3mm from previous owner vs 4mm for the Align ESC). Thank you for all your great info. Makes getting into helis much less daunting for soooo many of us. Thanks, Jeff |
02-03-2011, 12:42 PM | #138 (permalink) | |
Team Taco VP
Bob
02-03-2011, 12:43 PM | #139 (permalink) | |
Team Taco VP
Bob
02-03-2011, 12:47 PM | #140 (permalink) |
bob,
how do i bind a trex 250 with esc and cc bec wired in per video with red wire out of esc. do i need to use a y adapter for bind process then hook up normal after bind plug is removed??? what kind of beeps should i hear? i have a dx6i and a ar6100e please help?? |
