Old 12-07-2012, 08:02 AM   #1 (permalink)
Default batteries/flight pack question
So what batteries are you guys running? I just slid 2 5200mah packs from my 550 into my new build,I have to say she feels a little heavy!
I was going to order 5000mah packs but now I'm looking at 4500's... not sure if there will be much weight difference though?!
Also, what about c rating? I guess with series packs you may be able to get away with a slightly lower rating?
If anyone has any input/advice I would be interested to hear...
EC225LP is offline        Reply With Quote Quick reply to this message
Old 12-07-2012, 11:17 AM   #2 (permalink)
Rx is any size you want to but i would run 2000 to 2400mah and 25c is fine. You dont need a very high c rating. Bigger last more flights betwern charges on Rx bat. 4400 on mainbat will give you a much lighter bird and close flight time to a bigger heavier 5000+ battery. Less weight means less power usage. 45c is sufficient especially good lipos like Gensace. If i used 65c id go with 4400mahs. Mainly depends on how you fly. Heavier batteries will damage your bird more in a crash.
AMA #1039539
ddj74 is offline        Reply With Quote Quick reply to this message
Old 12-09-2012, 04:04 AM   #3 (permalink)
For 5000mah packs, anything 30c and over is going to be fine for most people. For that size of pack, it's a sustained discharge rate of 150amps, which is some way clear of what the other components are using.
Yes if you do hardcore smack/live somewhere really hot etc etc, a higher c rating would be nice to have, but for most people it's fine.
SAB Goblin 500 Mini V-Bar | TBS Discovery PRO | TREX 450 Pro V2 3GX
blackout19 is offline        Reply With Quote Quick reply to this message
Old 12-09-2012, 04:08 AM   #4 (permalink)
gens ace 4400 65c in my goblin are intense.
perform great!!!!!!
Sent from my phone using Tapatalk2...otherwise i would of sent it from my home PC.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 12-09-2012, 07:27 AM   #5 (permalink)
Thanks for the input guys... I went with 5000mah 35c's... Think they should be ok for my mild kind of 3d... Only issue is its pretty dam hot here!
Sent from my GT-I9070 using Tapatalk 2
Old 12-09-2012, 07:40 AM   #6 (permalink)
did you get the Turnigy 5000mAh 6S 35C packs?
I use them, they fit well and fly great.
It gets hot where I am too, if you mount your ESC up front I recommend cutting a vent hole in your canopy for airflow over the ESC. It helps mine a lot. I can post pics if you want.
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar
T-Rex 450L Dominator | JR DSX9 9503 Mode 2
Steemo is offline        Reply With Quote Quick reply to this message
Old 12-09-2012, 10:19 AM   #7 (permalink)
Have you checked the ir of the packs on your charger? I got some zippys the first go around and the ir is horrible, all cells between 12-17 each. Running gens ace 30c now with 0-1 ir per and plan to use the 45c when I get my 700 but would like to have a cheaper option that is a decent pack for just goofing off
shein95 is offline        Reply With Quote Quick reply to this message
Old 12-13-2012, 11:58 AM   #8 (permalink)
I've been flying the Spyder batteries from Progressive RC and love them. Great packs with true 30C rating and the weight is good, but with a powerful heli like this one, weight is not a huge issue, IMHO!
I have both, the one continues 12S 5300mAh pack and the individual 2x6S 5300mAh packs. Both fit perfectly. I have charged them at max output of 30A from the charger without any problems. Friend of mine has flown on his Avant Aurora 700E the same packs for two and a half seasons and the packs still pull stumps.
Great price too.
http://www.progressiverc.com/spyderb...00mah-30c.html
http://www.progressiverc.com/spyder-...00mah-30c.html
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote Quick reply to this message
Old 12-18-2012, 07:03 AM   #9 (permalink)
No, I got TY-max packs... from a local supplier, They are 5200mah. I use the same ones on my 550 and have over 60 flights per pack.
Yeah... sure, it would be great if you could post some pictures. I did the first couple of set up flights today and the ESC came down hot, and that was with no canopy on.
Old 12-18-2012, 07:05 AM   #10 (permalink)
Old 12-18-2012, 10:40 AM   #11 (permalink)
here ya go
ID:	375258   Click image for larger version
ID:	375259   Click image for larger version
ID:	375260   Click image for larger version
