Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 09-05-2010, 07:58 PM   #21 (permalink)
The Capi
I resized all the links below the swash as they don't move that much, everything above the swash will work itself out. Can you guys check your rear bevel gear for me to see if my strange one matches everyone's elses.
Old 09-05-2010, 08:07 PM   #22 (permalink)
What is that long black rod with big plastic bits on the ends poking out of your rotor head?
TEAM OUTRAGE RC
TEAM SAVOX
SKOOKUM ROBOTICS
Jason_Adamo is offline        Reply With Quote Quick reply to this message
Old 09-05-2010, 08:18 PM   #23 (permalink)
The Capi
A superior flying system
Old 09-05-2010, 08:31 PM   #24 (permalink)
Hahaha! Yes I prefer Flybar heli myself nothing beats the real deal!
Flybarless seems a bit more like having a plastic inflatable girlfriend you can play with it all you want but it just don't feel real
Charley Stephens
Charley Stephens is offline        Reply With Quote Quick reply to this message
Old 09-05-2010, 08:50 PM   #25 (permalink)
Long live the Flybar!
3Dmuse is offline        Reply With Quote Quick reply to this message
Old 09-05-2010, 08:54 PM   #26 (permalink)
Capi...you rotten bastage!! Did ya have to post this???
All I can say is "WOW!!"
billbill242000 is offline        Reply With Quote Quick reply to this message
Old 09-05-2010, 08:55 PM   #27 (permalink)
The Capi
Finish your 50 first, I got you most of the way to the finish line at IRCHA.
Old 09-06-2010, 12:14 AM   #28 (permalink)
It's spreading like wildfire here Charley even mark has the flybarless bug now. Soon my plan to eradicate the flybar's will be complete.
TEAM OUTRAGE RC
TEAM SAVOX
SKOOKUM ROBOTICS
Old 09-06-2010, 12:55 AM   #29 (permalink)
The Capi
I will be setting up an RJX 90 with a SK720 this week, I plan to go FBL myself next year on the Fusion 50, this should help me narrow down the field on which FBL unit i want to buy.
Old 09-06-2010, 07:12 AM   #30 (permalink)
Charley,
I went on a week long business trip and when I got back Jason and Steven had the SK720 installed and the 140 conversion done and it was flying they did a real good job, wiring nice and neat, cut the frames above the servo mount to install it, I was quite proud of them.
It fly's great, may have to convert one of the 90's now to FBL
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote Quick reply to this message
Old 09-06-2010, 08:12 AM   #31 (permalink)
Which is the flying weight with and without fuel?
morph78 is offline        Reply With Quote Quick reply to this message
Old 09-06-2010, 08:15 AM   #32 (permalink)
it doesn't fly w/o fuel
howardm4 is offline        Reply With Quote Quick reply to this message
Old 09-06-2010, 08:20 AM   #33 (permalink)
sorry had to laugh out loud
Clyde Fox
Port Charlotte, FL.
Old 09-06-2010, 06:03 PM   #34 (permalink)
LOL , man that is top notch packing.
Kustom
2 trex 450's Donated for a good cause
Bergen gasser build thread
Kustom is offline        Reply With Quote Quick reply to this message
Old 09-06-2010, 11:16 PM   #35 (permalink)
Capi,
I believe that I have the same tail gear issue. I will send you a PM. Well i think that my 90 is ready to fly. Just finished it up about an hour ago. I am debating on taking off work tomorrow to spend the day with my new love!
Jim
Schuster_Helis is offline        Reply With Quote Quick reply to this message
Old 09-07-2010, 11:53 AM   #36 (permalink)
Default Tail Bevel Gears
I found a similar issue with the bevel gears but with mine it was the long umbrella gear in the front TT assembly that seams to be affected.
The gear is slightly discolored compared to the others and has some imperfections where the bearings slide on. The 12x18x4 bearings are a bit loose on the gear. I also had to sand the gear box halves a bit to get them to clamp snuggly on the bearings.
The mesh of the gears in the front assembly on my kit is way off. The gears are tight and mis-aligned. I'm hoping they will wear in to an acceptable level.
The rest of the kit however went together very well and looks good.
Deftone45075 is offline        Reply With Quote Quick reply to this message
Old 09-07-2010, 12:35 PM   #37 (permalink)
The Capi
I got an answer from Clyde that confirms what I thought, these are the new gears that solved one of the last problems on the prototype. The gear is molded not CNCed, that is why it looks different. The bevel gear should fit smoothly onto the TT end caps, if the gear is difficult/tight to get on the TT end caps you need to get it replaced. The gear meshing will sort itself out in a flight or two.
Old 09-07-2010, 08:37 PM   #38 (permalink)
Default Vel 90 main gear
HFG- great job on pics and ideas.
the main gear to pinion mesh on my Vel 90 seems a good bit loose. I was thinking about lengthening the slots to allow the engine to slide closer.
any ideas?
Team OUTRAGE Helis
helidirect.com -- check it out
Nate Quan is offline        Reply With Quote Quick reply to this message
Old 09-07-2010, 08:49 PM   #39 (permalink)
The Capi
Dunno, my mesh worked out pretty well. These are mod 1 gears so they wont have to be super tight like on say a 550.
Old 09-07-2010, 08:55 PM   #40 (permalink)
OK cool
I ordered an extra main gear when I got my kit, so I think I'll just go with it and see.
Let ya know how mine turns out.
Thanks man
Team OUTRAGE Helis
