Night Flying Night Flying Helis Info |
04-03-2013, 04:24 AM | #161 (permalink) |
Post your Night Rig Pics and Videos
Just a short video of my very first inverted autorotation by night (at 1:52). I was pretty nervous watching in HD and fullscreen seems to be the best. only normal flying, nothing special!
04-17-2013, 03:20 PM | #162 (permalink) |
Here's my budget attempt on a night rig
It's a 370 sized Esky FP. Just had my first flight in the (almost) dark, just some hovering, which is difficult enough as it is. Having separate colors on the left and right does help a lot by the way. But it really needs some night blades...
HB FP V2 (Night Bee) and CP3 (in bits and pieces), GW 9958. Electronics enthusiast. Duck and cover! |
05-09-2013, 09:22 PM | #163 (permalink) |
I've got my 520 night blades done, just needing a test flight.
Considering this is a pitch black room, I may have overdone it on the white. Should make landing easy. |
05-13-2013, 08:54 AM | #164 (permalink) |
700E headlight flying!! Had 10 cars turn there headlights on and a cop tried to follow it with his spotlight on his car. Lol fun night!!
http://m.youtube.com/#/watch?v=wkkYCHx-sOA Mattox
Sponsored By: MingDa Tech Helicopters, Astroid Designs MKS Servos USA, Haiyin Lipos, Scorpion Power packs USA |
05-13-2013, 12:30 PM | #165 (permalink) | |
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0 PRÔTOS 500 FBL "Sky Whip" | Robird G31 Audacity P6 FBL "Phoenix" | MSH Brain | 12s Goblin Speed | iKon |
05-28-2013, 01:00 AM | #166 (permalink) |
A follow up to my night rig.
The canopy and tail fin are powered by their own 1S lipos so they can be easily changed back and forth between my 550 helis. With the brightness of my main blades I have decided to just order up some glow in the dark decal to wrap the booms. I may also wind up using it to partially wrap the canopy. |
06-04-2013, 06:43 AM | #167 (permalink) |
My first night rig set up on my align 550.
06-20-2013, 11:45 AM | #169 (permalink) |
800 xxtreme night rig so far
In the process of setting up my Logo 800 xxtreme as a night rig, so far the blades and canopy are complete.
Canopy took over 10hrs work to lay it all out and solder it up, has 6.1m or 366 LED's. Edge 813 self built night blades with 9 LED's and centrifugal switches so they light up on spool up, they run for 45 mins on a 240mah single cell lipo.
Trex 600N Pro with Vibe 50 Head and YS91RS motor, Vibe 50 VBar FBL, Trex744 VBar FBL MW44 Turbine, Logo 800 XXTreme, Logo 600 12s, Logo 500SE, Vario UH-1D (Building), Scratch built 625mm Quad. |
06-20-2013, 12:20 PM | #170 (permalink) |
very impressive, Kevin. I love the canopy.
06-20-2013, 12:38 PM | #171 (permalink) |
Yep, SWEET canopy lighting!
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), Oxy 2 (Falcon 12) Graupner MZ-32 Experience is something you gain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
06-24-2013, 12:08 PM | #172 (permalink) | ||
Hello,
my new Blads. 64 RGB Leds and 512 Color with 796 Lines per Rotation. Sorry my english.
06-24-2013, 01:41 PM | #173 (permalink) | |
06-24-2013, 01:51 PM | #174 (permalink) |
Wow, that's awesome. Did you make these yourself? If so, do you have any information on how you did it?
Team Synergy Field Rep, Rail Blades |
06-25-2013, 02:52 AM | #175 (permalink) |
Hello,
sorry my english. I have made this same. You cannot buy this. The pictures are on micro SD Card. Werner |
06-25-2013, 03:05 AM | #176 (permalink) |
And this is the PC Program
06-25-2013, 09:27 AM | #177 (permalink) |
Wow, a lot of work went into that! I had a feeling that making a PCB was about the only way that it could be done.
07-02-2013, 09:12 PM | #178 (permalink) |
Re: Post your Night Rig Pics and Videos
Yay, my first successful night flying heli!
I use rotor tech luminous v2 610 main blades and 95mm edge night tails. I may do away with the blue lights on the canopy and put red or just more green in its place because the blue is not visible in the air with the other colors. The best part for me is the white led cluster I put on the bottom which lights up my landing zone when landing. My first 4 flights were quite successful. Its a Chaos 600 on 6s by the way. With an 800mah 2s pack to run all the lights Sent from my DROID RAZR HD using Tapatalk 2 |
07-02-2013, 09:14 PM | #179 (permalink) |
A pic in a brighter room shows the led strips better
08-23-2013, 10:22 PM | #180 (permalink) | |
Your is my Bread and Butter. Compass Field Rep/KBDD Team pilot/Experiencrc.com |
