Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 08-30-2015, 11:37 AM   #1 (permalink)
Default Seriously Gaui...
Are your clutches made of cheesium?
Broke in flight...
Too many helicopters! - My wife.
bjornal is offline        Reply With Quote Quick reply to this message
Old 08-31-2015, 12:28 PM   #2 (permalink)
It's not the clutch material, it's teh gap to the liner.
I was breaking clutches like it was my job. Barely 10 flihgts and they would break. So at Ircha a friend set me up.
Here is what he did. get a new clutch, new liner and a beer. Drink the beer. Preferably a good beer. Save the can. Take the liner out of your old clutch bell. Takes a while, but scrape it out. Then get the new liner, and use it as a template to cut a piece of the beer can out. You want the liner to be closer to the clutch. Glue the beer can strip onto the clutch bell, then the liner to the strip. Take your clutch and wrap one time around it with electrical tape. Put the clutch into the clutchbell and let the 5 minute epoxy cure for 24 hours. Your gap on the clutch will essentially be the thickness of the electrical tape.
I have not broken a clutch in 2 gallons. Longest I've gone. Including one crash.
bgymr is offline        Reply With Quote Quick reply to this message
Old 08-31-2015, 03:44 PM   #3 (permalink)
+1, I did beer can mod a while ago. I didn't use a beer can, but Coke can, all the same and result. You will find the first few flight, the clutch biting much before 1/4 throttle.
I have gone a gallon without breaking a clutch. Long may this continue as I hate taking my machine apart
Regarding Gaui parts, they are not of great quality. So far, the muffler broke in 2. One swash follower broke in flight. The tail boom broke on landing, I generally do a mini auto from a foot or two up to land. I lost count how many times I lost the 2 pins that attaches the canopy to the heli.
I still LOVE this heli despite its quirks.
Cheers
DON'T GIVE UP ON THE BASICS
krante is offline        Reply With Quote Quick reply to this message
Old 09-01-2015, 04:06 PM   #4 (permalink)
Yep. Google-fu told me too much of a gap on the liner was a common fault so I guess I'll do the beer can mod. Just hope it works with alcohol free beer as that's all I drink
My clutch have survived almost 2 gallons though. So I should be happy...
Old 10-05-2015, 10:14 AM   #5 (permalink)
Default I need advice, how to...
Hello,
I had the same problem with my clutch this weekend - it was quite new - exactly 20 flights.
I am not sure, whether I understand to the modification correctly (maybe because of my English) - could you, guys, describe deeper the modification of clutch bell for me :-)?
Thank you!
Roman
Gasserheli Morphis, Hanson 300, Spirit FBL;
Logo 600SX, HC-3sX; T-Rex 470LP;
Miniprotos, Helibug 600, HWC700PUH, HWC 600, T-Rex 600 GT15HZ600 conversion, T-Rex 600 GoEngine 56, T-Tex 600N;
SlezY83 is offline        Reply With Quote Quick reply to this message
Old 10-05-2015, 09:15 PM   #6 (permalink)
Could you please clarify this part? I assume you disassemble and remove the electrical tape after the epoxy has cured, correct?
Thanks!
How do you make a small fortune in this hobby?
Start with a large one!
HelisRock is offline        Reply With Quote Quick reply to this message
Old 10-05-2015, 10:27 PM   #7 (permalink)
Yes remove the electrical tape when the glue is set on your clutch liner. I did this with my Heli.
kane601 is offline        Reply With Quote Quick reply to this message
Old 10-06-2015, 07:37 AM   #8 (permalink)
Thanks kane601
Seemed obvious, but didn't want to assume anything.
Old 10-06-2015, 08:02 AM   #9 (permalink)
Soda can trick worked nicely. Now I just have issues with twitching tail - bobs 5-10 cm to the side, randomly... Tried both a Spirit FBL and a VX1e with same result, so swapped out the DS525 for a DS520 but still haven't gotten around to test it just yet. Tail pitch slider is butterly smooth...
Old 10-07-2015, 03:36 PM   #10 (permalink)
Well, I have decided to modify the clutch bell by can (coke can) as you mentioned, but from preview, it seems that the clutch will be still in small grip when I fix it.
Will it be broken in?
Or am I on a wrong way?
Old 10-07-2015, 03:39 PM   #11 (permalink)
How about engine? Is not too rich?
Or are not there any kind of vibrations (bad bearing etc?)
Maybe, could you place a video of this behavior?
Old 10-07-2015, 05:24 PM   #12 (permalink)
No problem helisrock
Old 10-12-2015, 08:51 AM   #13 (permalink)
I *think* I have it dialed out now, it wasn't as bad with the 520 as with the 525, and I set the servo delay a bit higher which seemed to fix it. The engine might be running a bit on the rich side, but not enough to cause large vibrations.
I've also put on a Futaba GV-1 as the Spirit gov... yea... no... Really hope I've ironed out the issues now and can start to really lean it out with 30% nitro and get some good smack out of it.
Old 10-19-2015, 10:36 PM   #14 (permalink)
So.... why wouldn't you guys just buy a thicker liner from a different company? Way easier then your mod???
flyswatter40 is offline        Reply With Quote Quick reply to this message
Old 10-21-2015, 03:09 PM   #15 (permalink)
Errrrm... Ummm. Well... *glances quitely past flyswatter*.
For me I was already ordering some parts and just put the liners in the basket anyways. Not an hard mod to do either.
At least now it works perfectly with GV-1 even though I had to "cheat" it a bit to get it past 2100 headspeed. Tuned it in so it's just a hair off being on the rich side with 30% nitro and tons of power. Not like an OP'd electric, but on par with a nice 90 with YS-120 p/w ratio
Old 02-14-2016, 04:52 PM   #16 (permalink)
What liner did you find that worked and was a bit thicker?
MHS PROTOS - FB-CF, ThuderPower, Quark Gyro
E-Flite mCP x - C05 & HP05/SR120 Tail
SAB Goblin 770 -
Kontronik Motor&ESC
memheli is offline        Reply With Quote Quick reply to this message
Old 02-17-2016, 05:54 AM   #17 (permalink)
The TT Raptor 50 liner will work. I concidered that before I bought the NX4 one, but since raptor parts are getting harder to get I did buy the original one. Requires trimming to size, but otherwise it'll work.
Old 07-09-2016, 10:22 AM   #18 (permalink)
Just had a clutch break on me for the first time. The original clutch lasted well over 100 flights without failure and recently replaced because the one way started failing. The replacement only lasted for 10 flights or so before breaking. I also replaced the bell and liner at the same time and clearance was tight; and checked again after it broke and was still tight.
Thinking back to this thread, I started to wonder if something has changed on the new part and decided to compare the original to the broken one. Sure enough the original one appears to be beefier than the one that failed.
Here are some comparison pics. The one not broken is the original with over 100 flights. Curious if others agree this could be contributing to a higher failure rate.
D22597 is offline        Reply With Quote Quick reply to this message
Old 07-09-2016, 06:43 PM   #19 (permalink)
Did you have the original liner in?
Old 07-09-2016, 08:45 PM   #20 (permalink)
I replaced the bell and liner with the new clutch. Clearance was tight.
