Old 10-14-2015, 02:16 PM   #341 (permalink)
You adjust the linkages first and get as close as possible with that.
The last adjustment is done via software (FBL mid point setup).
Reason: You have to do at least a half turn, usually a full turn, on the linkage which is way to coarse to get level.
Hint: If you have turnbuckle linkages you just do it with the linkages => mechanically perfect setup
Soko
The future of setup... now! Soko Heli Toolbox app for a next generation setup experience.
ONE tool for ALL setups of ALL sizes and ALL brands of helis
www.soko-heli-tools.com
soko is offline        Reply With Quote Quick reply to this message
Old 10-14-2015, 08:04 PM   #342 (permalink)
Reason: Usually you have to do at least a half turn, usually a full turn, on the linkage which is way to coarse to get level.
Soko
Thank you
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
Old 10-17-2015, 06:07 AM   #343 (permalink)
Originally Posted by georgi UK View Post
=] Soko has finally DONE it! as promised the worlds only all-in-one setting up tool has arrived! it's intro priced so get there quick, sets your heli up precisely, brilliant work!
http://www.soko-heli-tools.com/
Rick
=] take it you are over the moon with the tool??!
rickn816 is offline        Reply With Quote Quick reply to this message
Old 11-10-2015, 08:29 PM   #344 (permalink)
Trying to setup my raptor 90, downloaded the app and purchased virtual main shaft. Where is the selection for a 4 point swash, or is there one? All that's there it's 3 point and reversed. Any help?
6.6leater is offline        Reply With Quote Quick reply to this message
Old 11-11-2015, 02:08 AM   #345 (permalink)
Hi,
What exactly do you mean with 4 point swash? As far as I can see here the Raptor 90 has a standard TT swash...
If its an older version: Is it a flybar one?
If you have a heli like the Velos 880 with 4 cyclic servos - this is not supported by the app at the moment.
Soko
PS: If thats your only heli please PM me, we will figure something out for sure
Old 11-11-2015, 08:12 AM   #346 (permalink)
It's an older flybar that has been converted. 3 servo 4 point swash. 1 for collective, 1 ale, 1 ele. I can figure it out and get it to work. Just wondering if there was a selection that I was missing in the software.
Old 11-11-2015, 08:14 AM   #347 (permalink)
Ohhh wow...
frankly: never seen such a thing.
and no... no selection for such a mechanic in the app
Old 11-11-2015, 10:36 AM   #348 (permalink)
Ohhh wow...
Thats a typical Raptor head which does not use ECCPM mixing in the radio and instead uses mechanical mixing with an additional pitch servo.
Some of their more modern helis still use mechanical mixing
Tony
Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is online now        Reply With Quote Quick reply to this message
Old 11-11-2015, 02:27 PM   #349 (permalink)
seems it never got to our part of the world
Old 11-11-2015, 04:23 PM   #350 (permalink)
They tend to splash a few miles off the coast.
Dan
No-Team; Non-Rep, no-skill. Free advice worth every penny.
dogbreath is offline        Reply With Quote Quick reply to this message
Old 12-12-2015, 08:55 AM   #351 (permalink)
OK, I've been a bit of a naysayer and Luvmyhelis has told me repeatedly that the Soko unit has a more accurate higher quality digital level in it.
My RCLogger digital level is now all over the place and won't hold a value repeatedly within 0.3 degrees if that. It used to do better than that, but it is no longer reliable.
I pulled out my Soko level and it is still holding a solid value and I can move it around repeatedly and set it back down on a zero'd surface and it returns to 0.0 every time.
So maybe I just got lucky and my RCLogger did better than most for a while, but it definitely is fluctuating around too much for me to use it without a lot of frustration now.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 01-04-2016, 02:18 PM   #352 (permalink)
Default Soko Tool Screen Failing After <6 Uses... :-(
Hey guys...let me first start off by saying that I purchased my Soko tool quite a while back to support a (then) newer company trying to break into the heli tool market (I like to support the smaller guys), but I've taken a number of hiatuses in the period since I purchased the tool (I had a baby, major flood at my house, among other things - it was a rough year).
I've since used my Soko tool less than 6 times total, and the screen has started to go out on me. I've tried replacing the battery, thinking that might be it, but that didn't help at all. I try to guess what the numbers are, or just use the constant figures on the top, but that method is getting quite frustrating. I guess being an early(ish) adopter doesn't always pay off. For all intents and purposes, my Soko tool is in like-new condition, but obviously not from a functionality standpoint.
Has anyone else experienced this problem??
Please chime in if you have, and here's to hoping there's an easy fix. I'm SUPER bummed because I did like this tool better than my RCLogger tool, but for the price I would expect more. If I don't get much feedback here, I'll post in the general forum, but I figured I'd start here since we are the biggest Soko supporters. Thanks guys.
Just a few examples of the types of readings (or lack thereof) I'm getting:
-Shane
ID:	627993   Click image for larger version
ID:	627994   Click image for larger version
ShaneXman is offline        Reply With Quote Quick reply to this message
Old 01-04-2016, 04:25 PM   #353 (permalink)
Shane, possibly it is just a ribbon connector not seated properly.
CZorzella is offline        Reply With Quote Quick reply to this message
Old 01-04-2016, 10:53 PM   #354 (permalink)
I took yours and Sokos advice and decided to open it up...and you guys were exactly right, it WAS the ribbon cable. Except, it was a problem that was bound to rear its ugly head, and is definitely a manufacturing defect. Looks like someone had an off day with their soldering iron at the factory.
And to add insult to injury, I'm guessing the fact that it hadn't been opened up before was limping it along, and now it doesn't work at all (gobbledy gook on the screen).
Check it out:
-Shane
ID:	628096   Click image for larger version
ID:	628097   Click image for larger version
Old 01-05-2016, 01:50 PM   #355 (permalink)
Im sorry to hear that!
We test each Soko Gauge before it leaves us but its impossible to find 100% of the (goingvto be) faulty ones.
But no worries man.
We gonna send you a warranty replacement right away. Look at your PM for details.
Soko
Old 01-05-2016, 01:51 PM   #356 (permalink)
But no worries man.
Soko
You guys are awesome! Thank you kindly, I look forward to receiving my replacement.
-Shane
Old 01-05-2016, 03:56 PM   #357 (permalink)
Soko, you're the best!
Old 01-05-2016, 04:27 PM   #358 (permalink)
Lol, yeah, he is!
Old 01-07-2016, 10:30 AM   #359 (permalink)
Looking for the Virtual mainshaft app in the apple app store and can't find it.
Is it now included in the free app?
or am I just too simple minded to find it?
Diabolo 550 Vbar NEO : Diabolo 600 Vbar NEO : Diabolo 700 Vbar NEO: OXY 5 Vbar NEO : Logo 600SX V2 Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control : Citizen 735
shadco is offline        Reply With Quote Quick reply to this message
Old 01-07-2016, 10:32 AM   #360 (permalink)
It's an in-app purchase. Download the free one, and you'll be able to upgrade from within the Soko Heli Toolbox app. I hope this helps. Cheers.
-Shane
