Old 07-18-2011, 07:12 AM   #1 (permalink)
Default LED lights
A question for all you night flying guys. Im using a dx6i and ar6200 receiver. Can I just run a led light with a jst connector straight to my RX. Im assuming the RX is using 5 vdc and most leds are 12 vdc. Ive found some strip lights at walmart, hobby king and rclights.com. Im assuming that is the simplest setup. Seen many vids on this but they all use separate power sources or batteries to power the leds. I just want to make a straight connection from the RX to the LED and turn it on or off from my extra open channel on my RX.
Blade MSR FP, Blade MCP X, Rustler VXL, Erevo ERBE, Slash 4x4 Platinum 6s, EXI 450 CP,Syma s107g CoAx, Esky Hunter CoAx
joecool73 is offline        Reply With Quote Quick reply to this message
Old 07-18-2011, 09:13 AM   #2 (permalink)
The output of your RX is not a switch output, it is a pulse of varying width that controls the servo position so you can't use it to switch a LED without a controller of some sort, regardless of the voltage.
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1
soXos DB7 nightflyer : Jeti DS-16 & DS-12
I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 07-18-2011, 03:53 PM   #3 (permalink)
If you are thinking using these strip:
http://www.hobbyking.com/hobbyking/s...idproduct=8942
these can operate at 11.1 or 7.4 (dimmer) but not at 5-6 Volt.
but you can hook this up directly to your 3S lipo. they are very bright at 11.1 v
and add a Rx controlled switch like this:
http://www.hobbyking.com/hobbyking/s...idProduct=8833
then you can control it with your extra channel or any channel.
You CAN use Rx power if you use light strips that operates at 5-6 Volt. the HK strip is 3 led in series and then parallel chained together. You can do your own soldering/wiring to make 5Volt operated led string. Just a little more work. You do need to figure out what the voltage should be used, or you may burn your leds. different color leds may run off different voltages.
kaos is offline        Reply With Quote Quick reply to this message
Old 07-18-2011, 04:28 PM   #4 (permalink)
Those were exactly what I was looking at. I dont think I want the strips though, just something for headlights. Maybe 2 single leds and that turnigy switch.
Old 07-18-2011, 05:48 PM   #5 (permalink)
If you just want to place a couple round leds on your heli, this will be much better:
http://www.hobbyking.com/hobbyking/s...idproduct=6811
It is much lighter than the Rx controlled switch, and can operate right off the Rx power (takes 3-10 volt power source), it gives output of 3.5 volt. and has 3 output ch, it comes with a green, red and white flashing led. you can pull any one out of there if you don't want 3 led. one of the 3 ch is flashing ch, any led connected to it will flash. Take a look a the manual listed. Has a few different functions. and this can be daisy chained to add more switch controlled leds.
Old 07-18-2011, 06:43 PM   #6 (permalink)
Fantastic! Thank you that looks like a winner. Its funny how big these sites are because I searched Hobby king dozens of times and never saw that product. You got to wonder sometimes if they dont tag products with the right keywords. I just wish I could get the red and white, not big on green. Can you swap out the leds on those? I dig it though great find, thank you.
Old 07-18-2011, 08:45 PM   #7 (permalink)
yes, you can swap out any led and put any led runs on 3.5 volt or so. those 3 leds are plugged into 3 ports. you use any way you want with those 3 ports. but with rx switch function, one of the port will be flashing.
Old 07-19-2011, 05:25 AM   #8 (permalink)
Awesome thanks again for the tip
Old 07-19-2011, 09:35 AM   #9 (permalink)
You are welcome. The only thing I have not found out is what the max load for the switch in the kit. I strung 3 led to one port without burning out the switch. so the max load to each port and the total amperage supported by the switch is unknow to me. If you find out the piece of info some time. let me know.
