Hitec Gyro/Servos Hitec Gyro and Servo Support |
08-15-2013, 11:21 AM | #1 (permalink) |
Hitec HS65HB cyclic servo getting hot - Tarot ZYX-s FBL controler
So I'm trying to setup my Tarot ZYX-S fbl controller on my t-rex 450 sport. I'm going through the servo trim and whatnot for about 20 minutes or so. I pack everything up and grab the heli to move it and feel the rear servo (elevator servo) and it's kinda toasty. I've got two other HS65HB servos on the swash and they're cool as can be.
Do I need to look at the mounting of the rear servo and see if I'm causing binding due to case deformation or something? Might it be a setting in the ZYX? Is there anything I need to measure? Any help is appreciated!
Outrage 550 - Scorpion 4020-1390kv - CC ICE 100 ESC, AR7200BX Gaui X3 - Xnova 2618-1580kv - CC ICE 50 ESC, AR7210BX Blade Nano CPx |
08-15-2013, 04:09 PM | #2 (permalink) | |
. Aurora 9 - EPA & T.Limit (added V1.08) - Difference & Use. Mixes can overthrow EPA% setting. Travel Limit is a hard stop point so mixes can not overthrow % set in T.Limit and bind up a servo. Servo horn an original for that servo? some others are to thick and will jam on top of case. . Servo - Horn Arm Spline Count and Inter Brand Compatibility . Servo - Burnout. Cause & Prevention see also Sub Section "Aurora 9 - Helicopter & Multicopter" under Hitec USA Support Forum Sticky: . Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers & Telemetry, - FAQ, Setups & Tips {Individual Links often updated} Alan T. Alan's Hobby, Model & RC FAQ Web Links |
08-16-2013, 10:14 PM | #3 (permalink) |
Well, I definitely wasn't overdriving the servo, but I did loosen the mount screws a tiny bit, and took it for a flight. Seemed to have cooled down quite a bit.
I think I was somehow stressing the case having it too tight?
08-18-2013, 06:07 AM | #4 (permalink) | |
. Servo - Installation - Correct Mounting & Tips for longer life. Much more information available under sub sections "Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures" "Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ." below "Radio Systems, Accessories, Alterations and FAQ" at Alan's Hobby, Model & RC FAQ Web Links Alan T. |
08-18-2013, 10:38 AM | #5 (permalink) |
Good info A.T.
After figuring this out, I proceeded to crash and striped the gears in that servo. Looks like I'm going to get really familiar with the inside of it! :-)
