View Poll Results: What is causing Lockout/Brownout?
Static in belt/boom only 10 34.48%
Rx/electronic placement only 1 3.45%
BEC/ESC noise or slight drop in BEC voltage only 5 17.24%
ESC not grounded to motor mount only 0 0%
2 of the above 4 13.79%
3 of the above 1 3.45%
All of the above 5 17.24%
None of the above 3 10.34%
Voters: 29. You may not vote on this poll
Old 02-11-2008, 07:56 PM   #1 (permalink)
Team Taco CEO
Default True cause of Lockout/Brownout
Starting another poll to see what you think the source of these problems with lockouts are.
Please read all options before voting!
Kevin
Don't Taco My Pack, Bro! ,
Why crash when you can POUND it!
fireup is offline        Reply With Quote Quick reply to this message
Old 02-11-2008, 08:36 PM   #2 (permalink)
You may want to try a poll for what servos people are using too. I have heard that the 3400gs are lockout prone with spektrum rxs. An Align pilot had no issues when running 9257s, when he switched to 3400gs he started getting brown outs. I may not have been the servos but it sure looks suspect.
*******Mike*******
EKIM is offline        Reply With Quote Quick reply to this message
Old 02-11-2008, 08:40 PM   #3 (permalink)
Team Taco CEO
I can't see how it can be servo related, if it's servo current draw related, then it will fall under the BEC not supplying enough voltage under load.
Kevin
Old 02-11-2008, 08:45 PM   #4 (permalink)
These observations were with the stock electronics and the jr servos are amp hogs compared to some others supposedly. So yes I guess it would fall under failing or low volt BEC.
*******Mike*******
Old 02-11-2008, 08:53 PM   #5 (permalink)
I'm just wondering if all the lockouts happened to those helis using the internal BEC of the ESC or there were also cases that effecient external BECs were used?
Richard (rich)
Trex SE v2 -- HS65MG, GY401+9257, CC35, 430XL, GG, G Paddles, K&B Tail Blades
Trex 500 CF -- HS82MG, GY401+9257, stock ESC and motor, Align metal upgrades, K&B Tail Blades
heliboy88 is offline        Reply With Quote Quick reply to this message
Old 02-11-2008, 08:57 PM   #6 (permalink)
im just curious... if the problem does have to do with bec/esc noise, i wonder if a ferrite ring between the esc and receiver might help?
Prophet is offline        Reply With Quote Quick reply to this message
Old 02-11-2008, 09:15 PM   #7 (permalink)
What I question is....Is it possible that running 4 digital servos plus gyro and receiver might be over taxing the 3amp internal BEC to the point where it shuts down or drops/reduces supplied power? Then if you add in a few rod ends/linkage balls that are possibly too tight, adding more resistance to a system that is already short on power. Not sure what else it could be, but I know that most people with the 450 size heli's are using stock setups usually didnt have any issues. Of course most are using Hitec hs65mg's which arent digital. If I remember correctly the 600 came with a 3 amp BEC but most ended up going to the updated 6 amp unit because of digital servos.
I personnally havent had any issues yet, But I sure have been reading a lot about them.
I hope this gets figured out soon, It does make me wonder when or if it will happen to me.
M Carr is offline        Reply With Quote Quick reply to this message
Old 02-11-2008, 09:55 PM   #8 (permalink)
I'm curious too.......are any of these brownouts occurring with an external BEC's and/or aftermarket ESC's?
foofighter is offline        Reply With Quote Quick reply to this message
Old 02-12-2008, 02:41 AM   #9 (permalink)
Team Taco VP
OK I voted 2 of the above! It has to be MORE than one issue or we would not be having these convo's and people would have resolved it by now if it was a single issue.
Based on ONLY user submissions here and that I CANT relate since I am not having an issue I think it is a noise problem AND a static ARC that is resetting the DX RX.
My .00002 cents.
Bob
Old 02-12-2008, 02:57 AM   #10 (permalink)
Could you change the vote to a multiple choice vote, so we can check every option we think - not only "two of the above"?
Peter
psindrup is offline        Reply With Quote Quick reply to this message
Old 02-12-2008, 03:02 AM   #11 (permalink)
100% sure
And perhaps ESC placement?
My .00002 cents.
That wasn't much!
Peter
Old 02-12-2008, 03:12 AM   #12 (permalink)
Team Taco CEO
Peter
I can't change the poll once it's started, so you should state which 2 or which 3 the problems are if you voted for those.
Kevin
Old 02-12-2008, 05:37 AM   #13 (permalink)
It seems to me that the Spectrum receivers are not tolerant to low voltage and static. If you are going to use one, you better be very careful with component placement (good for any receiver), lube your belt with silicon containing no petrolium distilates, and use a quality external BEC. Otherwise, hope you are one of the lucky ones that doesn't see this problem.
I'll go out on a limb here and say that Spectrum needs to upgrade their design.
Rick
Note: I'm not a big fan of grounding schemes. That's why I said lube the belt. Thats not to say you can't be successful grounding if done right.
Helifreak, the place to be!
rdlohr is online now        Reply With Quote Quick reply to this message
