Old 01-23-2013, 12:47 AM   #1 (permalink)
Default Servo summary
There is a great thread about pilot experiences with alternative servos
https://www.helifreak.com/showthread.php?t=4149107
Since it sometimes is hard to get an overview when reading a thread I made a table with the stats (in case I want a metal gear upgrade after crashing/stripping the stock ones). Figured it would be useful for my fellow helifreaks as well.
Code:
Servo			Type	~Cost	Speed	Torque	Weight	BeastX settings
					@6.0V	@6.0V	(g)	Swash / Tail (Hz)
					sec/60°	kg-cm           Pulse-Length (µs)
Stock (DS76)*		C	$18	0.09	2.0	7.6	200 /  -  / 1520
MKS DS95		C	$79	0.053	3.0	21.2	200 / 333 / 1520
MKS DS92A+		C	$53	0.06	3.0	17.4	200 / 333 / 1520
TGY-306G-HV☦		C	$23	0.06	3.1	21.0	200 / 333 / 1520 (guess)
MPX Nano Pro MG		C	$33	0.07	2.0	12.0	 ?  /  ?  /  ?
Spektrum H3020		C	$24	0.08	1.6	12.6	200 / 165 / 1520
Align DS415M		C	$25	0.08	2.4	13.9	200 / 333 / 1520
Savox 0257MG		C	$33	0.09	2.2	13.3	200 / 270 / 1520
Spektrum H3000		C	$35	0.09	2.2	13.3	 65 /  50 / 1520
Solar D654¶		C	$9	0.10	2.5	12.0	 ?  /  ?  /  ?
Hitec 65MG		C	$26	0.11	2.2	12.0	 65 /  50 / 1520
Hitec HS-5065MG		C	$34	0.11	2.2	11.9	200 / 165 / 1520
Stock (DS76t)*✝		T	$19	0.03	0.8	7.6	 -  / 270 / 1520
MKS DS95i		T	$90	0.038	2.4	21.2	 -  / 560 /  760
Align DS425M		T	$25	0.05	1.2	13.9	200 / 333 / 1520
Hitec HSG-5084MG	T	$30	0.05	1.9	21.7	200 / 333 / 1520
Hyperion DS11-GCB 	T	$30	0.05	2.0	10.3	 ?  /  ?  /  ?
Hyperion DS09-GMD	T	$33	0.05	2.0	8.4	 ?  /  ?  /  ?
Spektrum 5020G		T	$50	0.05	2.8	24.5	200 / 270 / 1520
Savox SH-0262MG		T	$33	0.06	1.2	13.6	200 / 333 / 1520 (google)
JR DS290G		T	$35	0.07	1.15	7.1	200 / 165 / 1520
* Plastic gears
☦ AKA KST-DS215MG, BeastX guess, Tape+loctite mod suggested:
4 : Tarot 450 Pro V2 Build : Turnigy S306G-HV Servos (13 min 55 sec)
✝ Stock tail is 4.8-5.0V only! Use 1N4001 diode step-down ($1.99 for 2). ¶ Requires some frame cutting. Foam mod suggested by mixfisto: https://www.helifreak.com/showthread...83#post4654883
Anything I missed? Please comment it you have experience with a particular servo and the ar7200bx (working great / not working) or know the beastx setting / frequency.
Disclaimer:
Stats don't give the full story. Sometimes servos have other issues (inaccuracy, flakyness) so just because it looks good on paper doesn't mean it will fly well / reliably. I'm sure there are some typos in there as well, let me know and I will try to correct it. The price column is a rough estimate (for some servos a € ↦ $ conversion was needed).
Double check your servo frequency before installing!!!
http://www.beastx.com/service_servoliste.php
Blade 450, Scorpion 2221-6 10T, YEP45A
Blade MCP-X v1, BLHeli, HP06v2, XP-12A, HP03T, XP-3A, MH-X frame + swash, MH head, grips. 140mm solid tail.
In the mail: Blade 300 100% stock
Last edited by isdal; 01-31-2013 at 01:29 AM.. Reason: Added BeastX settings column.
isdal is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 01:25 AM   #2 (permalink)
Anything I missed? Please comment it you have experience with a particular servo and the ar7200bx (working great / not working) and I can add a column for beastx setting / frequency.
Disclaimer:
Thanks for that... should prove useful for those considering replacement.
xpantz is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 06:55 AM   #3 (permalink)
Why is there a "¶" after the Solar D654? Thanks for the comprehensive list!
CamDLux is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 09:30 AM   #4 (permalink)
Sticky this, please!
Thanks!
PS: Stock tail servo is good for 4.8v - 5.0v range. MKS DS95 for cyclic should be added, too
T-Rex 700 HV DFC, Logo 550SX, Logo 480Xx
JR Forza 450, G380, OXY 285
I'm proud of my crashing skills!
Chep is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 10:24 AM   #5 (permalink)
+1 on the sticky request. This is great information. We really don't have that many stickies up for the 300X and this is a common repair/mod item.
OXY Heli and Lynx Heli Innovations Team Pilot
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 10:40 AM   #6 (permalink)
Couldn't really see this myself due to not being able to scroll down in the window. Copy-pasted it here to see what it said.
Thanks for compiling this list!
One of the worlds leading authorities on attaching helis to trees.
Itzo is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 12:43 PM   #7 (permalink)
I have the Solar's and they work GREAT (running them with the YEP45a esc at 5.5v they work even better). Had many crashes, no problems.
There are 2 things you need to know abut these however. The motors can 'slip', so before installing, take the back off (or slide out) and put a tiny piece of foam under the motor. This will insure no slippage. This takes about 2mins a servo.
Also, These are a little tight in the front elevator slot. you have to cut out little bit of the frame to give room for the servo horn to move. It only takes a couple mins and doesn't affect the frame strength when using the Astroid braces!
mixfisto is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 02:22 PM   #8 (permalink)
Should add the Turnigy TNG306-G for the tail, MKS95 clone/OEM for $22, and the Hitec 65HB/MG for collective.
similis vobis fugere eam furatus
"The beatings will continue until morale improves."
-- William Bligh
petedee is offline        Reply With Quote Quick reply to this message
Old 01-23-2013, 03:21 PM   #9 (permalink)
Pete do you have a link for this Turnigy TNG306-G servo. Google gets me nothing except a few posts here.
Old 01-31-2013, 01:18 AM   #10 (permalink)
Default Updated with BeastX settings
I added a column for BeastX frequency settings and some more servos.
There are some servos in there I couldn't find the frequency for, if you are running those successfully let me know the settings and I'll update the post again.
Old 01-31-2013, 03:02 PM   #11 (permalink)
Same settings as the HV version, I think I gave the wrong number but this is the one, running nicely on my tail.
http://www.hobbyking.com/hobbyking/s...strSearch=306g
-- William Bligh
Old 01-31-2013, 04:53 PM   #12 (permalink)
Yeah thanks... I ended up finding them.
I should give them a try.... not that I need any... but they look nice :-)
Old 02-01-2013, 03:53 AM   #13 (permalink)
Mixfisto, what frequency etc you running them at???? i see the list didnt mention it, may be it could be added?
I think this thread is a perfect candidate for sticky as long as the list gets updated
BLADE 500Xc, 300X, MCPX V2 BL, 130x Red Bull, Hubsan X4 Quadcopter, DX7s
sn00p is offline        Reply With Quote Quick reply to this message
Old 02-09-2013, 07:36 AM   #14 (permalink)
Default Use for bot T and C?
You list the 306G as Cyclic but see people using them for the Tail.
Can't these and others be used for both cyclic and tail? TGY-306G-HV
And is the high voltage necessary for either T or C. I would like to use TGY's all the way around if that is possible.
Thanks for the effort
TopperMcFly is offline        Reply With Quote Quick reply to this message
Old 03-02-2013, 10:40 PM   #15 (permalink)
Airtronics 94809
Jose (Youtube -> Silverexpress01
See also Helifreak Blog)
MCPx 76/7 | Trex 250 DFC 667/19 | Hurricane 200 FES 143/7
Silverexpress01 is offline        Reply With Quote Quick reply to this message
Old 03-03-2013, 04:43 PM   #16 (permalink)
Im running futaba s3156's on cyclic and an align ds520 on the tail
The futabas are incredible servos. They literally have NO slop and the servo body is very rigid structurally. ..an important trait cyclics should possess on the 300x. Run them at 200hz at 6v with a cc10 bec.
Im running the ds520 because im using an align trex 450 pro v2. Non boom mount its mounted on the rear of the frame. The 450mx motor I run offsets any of the weight. Anyways, at 1520us and 333hz it runs very well.
But I dont think ill ever run anything but s3156's on 450 and smaller helis again, they are incredible.
flatthump is offline        Reply With Quote Quick reply to this message
Old 03-05-2013, 09:11 AM   #17 (permalink)
I was looking at the specs for Spektrum servos and the H3020 is giving up a lot of torque 34% less verses the stock servo but is 22% faster. Has anyone looked at the A3040 it has 5% less torque and is 9% slower which seems to be a lot closer to the stock servo at least on paper. Both servos are 63% heavier than the stock.
I was thinking of giving one a try but wanted to get an opinion of speed versus torque. I was always told when in doubt go with torque.
Smith T is offline        Reply With Quote Quick reply to this message
Old 04-07-2013, 02:33 PM   #18 (permalink)
This should be a sticky.
Could do with including some Hyperions in the cyclic servo list such as:
Hyperion DS11-AMB - 10.5g, 2.5Kg/cm, 0.15 speed
Hyperion DS11-SCB - 10g, 2Kg/cm, 0.13 speed
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 04-07-2013, 05:59 PM   #19 (permalink)
Can you also amend the Savox 0262 frequency this should be between 200 - 300 Hz not 333Hz.
This was confirmed by Savox USA after I tried the 262 at 333Hz during setup and it started to run warm. I run mine at 270Hz.
sc00bied00
sc00bied00
DX8i | Phoenix Sim | Nano CPX | 300X | 450X | Goblin 380 | Soko Heli Tool
sc00bied00 is offline        Reply With Quote Quick reply to this message
Old 04-07-2013, 07:38 PM   #20 (permalink)
sc00bied00
It seems like I'm unable to edit the post anymore Does anyone know if you need special forum powers to edit posts after a bit of time has passed? It would be great to be able to keep the first post in this thread up to date.
