Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 05-03-2013, 11:30 AM   #1 (permalink)
Default Warp Bling Bling
What is out on the market atm?
Fusuno canopys/fins and landing gear. Lynx fins and swash lvler
Anymore aftermarket stuff on the way?
Yaman is offline        Reply With Quote Quick reply to this message
Old 05-03-2013, 11:37 AM   #2 (permalink)
There really is not much of a need for aftermarket parts for the Warp. It is well made and flies well right outof the box. The parts that should be made from CNC aluminum already are, so there is not much to upgrade.
Hawk R/C has a set of CF tail case sides, which have a support between them, behind the pulley. I have one of these and it is very nice. I have not installed it, yet.
Compass makes the thicker boom, the brace for between the idler pulleys, the new motor can, and a metal tail bellcrank mount.
I suspect you will see more in the way of tail pushrod supports, from the aftermarket. A friend of mine made a really nice one on a 3D printer. The next time I have to work on the machine, I will be installing that.
Some people are looking for metal canopy mounts, but the stock ones break off in a crash, saving the canopy, so that one might be better off left alone.
Old 05-03-2013, 11:41 AM   #3 (permalink)
alu tail grips is on the wishlist....not a fan of plastic
Old 05-03-2013, 12:06 PM   #4 (permalink)
It's not the plastic tail grips that bother me, but the lack of a thrust bearing in the grip I don't really like. I have seen some success with folks running the 450X aluminum grips as a drop-in replacement.
NX4|Tri-Chronos|Chronos|7NT|Specter700
Saje Marvin - Citizen 125
Raz0rSh4rp is offline        Reply With Quote Quick reply to this message
Old 05-03-2013, 12:54 PM   #5 (permalink)
Yeah but the tail is very snappy I'd be a little afraid to lose some of that.
r/c helis lifestyle
HeliSmith is offline        Reply With Quote Quick reply to this message
Old 05-03-2013, 01:52 PM   #6 (permalink)
I don't believe that thrust bearings are necessary. The bearings in the stock tail grips are fairly large, they can take the load without issue without the need to further complicate the design with thrust bearings.
If the radials were smaller, then I would totally agree.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 05-03-2013, 02:27 PM   #7 (permalink)
I'd love a blingy hardware set and I would like a little heli display stand for mine to set it on the shelf and for showing it off at the field
r/c helis lifestyle
Old 05-03-2013, 03:14 PM   #8 (permalink)
Setup do u have?
Old 05-03-2013, 04:15 PM   #9 (permalink)
Originally Posted by Yaman View Post
Setup do u have?
I added it to my sig thanks it definitely should be there.
Compass Warp 360 w/Stock Motor (17t) running from a YGE60 governed at 3200RPM by the Vbar Black, sporting MKS DS95 on cyclic and JR3500G on tail.. Currently running Pulse 1350mAh 35C 6s
r/c helis lifestyle
Old 05-04-2013, 03:21 PM   #10 (permalink)
Default blade
The biggest issue I had with this bird other than the stuff that they already replaced was a crappy tail which I replaced with the blade 450 X aluminum tail grips and hub, way nicer now.
frito169 is offline        Reply With Quote Quick reply to this message
Old 05-04-2013, 03:49 PM   #11 (permalink)
Pics!!
AccuRC, realflight 7, Jeti DS-16.
donskills is offline        Reply With Quote Quick reply to this message
Old 05-04-2013, 04:15 PM   #12 (permalink)
Default pics
couple pics
ID:	417708   Click image for larger version
Old 05-04-2013, 04:29 PM   #13 (permalink)
Thanks!! That looks tight!!
Old 05-04-2013, 05:22 PM   #14 (permalink)
Are they a direct fit on the Warp?
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote Quick reply to this message
Old 05-04-2013, 05:32 PM   #15 (permalink)
Weight on this compare to the plastic?
Warp 360/ds95/ds95i/koby55/Mini Bec G2/TracX/stockmotor
Old 05-04-2013, 07:04 PM   #16 (permalink)
Default direct fit
Yes they are a direct fit but you do lose a little bit of throw. As far as weight goes it's actually lighter than the stock blade grips/hub.
Old 05-04-2013, 08:32 PM   #17 (permalink)
+1 for the visual appeal.
Now get some Edges on that and the previously mentioned tail case upgrade.
California Cabernet & Cuban Cigars
Warp 360 | HC-3SX | JIVE 80+ | HK 2520-1360 | MKS DS92A+/95i | Radix | DX8 | PL6 | GP 6S 1500
Mr-Mike is offline        Reply With Quote Quick reply to this message
Old 05-04-2013, 10:14 PM   #18 (permalink)
I didn't mind the tail, but I wanted a smaller disc as I kept ripping up my tail blades on landing (I hit TH which gives full negative at low stick)
At any rate, I did the same mod, it works very well...
Combined with the Hawk-Creation tail cases we're carrying and a set of Edge 60's ... I have get to shred another set of tail blades. I'm going to change the tail fin next as the pointy one digs into the ground too easily.
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 05-05-2013, 12:04 AM   #19 (permalink)
Default hawk
Any pics of the hawk creations tail case? Is it lighter the same or heavier than stock? A link maybe, didn't see it on your web site.
Old 05-05-2013, 05:52 AM   #20 (permalink)
http://www.rchelicanada.com/compass-...prod_2584.html
Hope to see mine early this week. Ordered last Saturday so I would guess it couldn't be much longer now.
