Old 09-13-2012, 05:37 AM   #301 (permalink)
I prefer low expo settings as well, giving it fast response with flips and rolls. But I just couldn't help but notice most of my flying suffers from it. Especially since I flew with aggressive settings for a month or two and came back from it. I've seen V-Bar settings from a couple of well known international contest pilots, even they don't even have extreme settings at all. Quite mellow actually :).
RAW 420 / RAW 580 / Kraken 580 Nitro / Goblin 700 / 2x RAW 700 / Kraken 700 S
VBC-t & Neo Pro / Scorpion motors & ESCs / MKS HBL575 SL & HBL980 / Supra X D4, D6 & S6 / OptiPower / Revolectrix 2x Bump & 5x PL8v2
https://www.youtube.com/kjoer
kjoer is offline        Reply With Quote Quick reply to this message
Old 09-13-2012, 11:10 AM   #302 (permalink)
Found a friend for me and my MiniP. Cant go wrong with that name...
puttekula is offline        Reply With Quote Quick reply to this message
Old 09-13-2012, 02:11 PM   #303 (permalink)
Originally Posted by kjoer View Post
I prefer low expo settings as well, giving it fast response with flips and rolls. But I just couldn't help but notice most of my flying suffers from it. Especially since I flew with aggressive settings for a month or two and came back from it. I've seen V-Bar settings from a couple of well known international contest pilots, even they don't even have extreme settings at all. Quite mellow actually .
I'll do some experimenting on expos of 5% to 10% this weekend. Thanks for all Your input.
MiniProtos Carbon with Low FBL, MSH 2580kV, YGE 60A, Mini V-BAR
Kyosho Concept 46VR with ASP46, GP750
Walkeras: Genius CP Brushless, V100D03, V120D02
Futaba T8FGS
pilot4fn is offline        Reply With Quote Quick reply to this message
Old 09-13-2012, 02:38 PM   #304 (permalink)
Brilliant
SYNERGY 516
Mikado LOGO 550
Mikado LOGO 700
SMJT is offline        Reply With Quote Quick reply to this message
Old 09-14-2012, 11:00 PM   #305 (permalink)
Ditched all XT-60 connectors and replaced them with EC3 connectors.
Futaba T8FGS
Old 09-15-2012, 09:43 AM   #306 (permalink)
4 packs, mainly inverted tail in then nose in. I have had the nose in inverted working for a long time but only now getting tail in working.
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1
soXos DB7 nightflyer : Jeti DS-16 & DS-12
I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 09-18-2012, 12:29 PM   #307 (permalink)
Activated Governor Store (finally) on YGE. I should have done it before - my Mini Protos was awesome before, now it even better!
Also, over the weekend I did some tweaking of Mini V-Bar, based on kjoer's instructions - this helped my Mini Protos to fly again much better as I had finally chance to fly it one battery (before major rain kicked in).
Thank You kjoer!
I did changes segment at a time, since my Mini Protos in not stretched. Today was first flight with some adjustments.
Changed following:
- Main rotor otherwise to same, but dropped paddle simu to 20% (was 35%)
- Tail rotor P & I Gain still left alone
- rest of tail rotor setup I did identical to kjoer
Now it is just matter of time to have better weather to test fly MiniProtos better adn add some more changes.
Futaba T8FGS
Old 09-22-2012, 02:51 PM   #308 (permalink)
Today, I opened up the servo packages and took out the horns. Going to cut them today. As well as putter about with the junk on my workbench and make space. Can't do too much else. Waiting on transmitter / receiver.. batteries. An now carbon frame sides ... Sigh. Too windy to fly today for me anyways.. The bin at the field has numerous blades sticking out of it but noone was there.
CrashAddict is offline        Reply With Quote Quick reply to this message
Old 09-22-2012, 05:21 PM   #309 (permalink)
Es un mal video pero... Me encanta este heli!!!! 6s, 15t, 1300 voltz
[ame]http://www.youtube.com/watch?v=AVVjwcpWdLg&sns=em[/ame]
donangelo is offline        Reply With Quote Quick reply to this message
Old 09-23-2012, 12:56 PM   #310 (permalink)
Ok, was doing rainbows, the belt snapped mid arc (about 15m) and the heli dropped straight down.
Changed the belt and tried again (belt was really consumed).
This time I was flying with earphones, felt the power fading but thought I could bring the heli back inverted: wrong I didn't realize I was in idle2 with no reserve, 10m high. Again, half of the path back, the heli dropped down straight.
Changed the broken screw holding the head and tried again.
Third one was a good one.
Bad day but great Mini, just one belt and one screw!
ziper_it is offline        Reply With Quote Quick reply to this message
Old 09-23-2012, 08:28 PM   #311 (permalink)
This weekend at SRC I flew the mini under construction lights. Gave wrong input and skid bumped at high speed, TH'ed, over corrected. It went straight up 25 feet and fell. I checked the servos and tail, put it back on the line, and finished the battery!
aclysma is offline        Reply With Quote Quick reply to this message
Old 09-25-2012, 03:00 PM   #312 (permalink)
You must have done that after I left! Wish I'd seen that one.
I only put a couple of packs through my Mini P at SRC, I was having too much fun with the 300X.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 09-29-2012, 03:34 AM   #313 (permalink)
Big Fail today.
Have setup my other YGE esc without blades and with. Decided to do my stretch mini which I have just completed.
Had and error first go with the esc beeping afterwards and refusing to work till I found out how to reset it.
Frustrated by now I decided to give it a final go but didn't take all the care I should have.
Spooled up and somewhere close to 90% the pitch was obviously a bit off and the vbar started compensatory movements tipping the heli but it was too late. I hit hold but the blade tips got smashed on the dumbbell supporting the blades through the skids.
Blades gone. Tail fin broken. Tail blade ruined from impact on tail fin. My second such incident.
Now it has a slight vibrational or stuttering spool up between 20-30% at a guess. Could be a normal thing. Without blades it gets smooth upwards of 50%.
I swear I was on the verge of saying that's it for this hobby.
Fixed it up with spares from my non stretch. Will order new bits.
I wonder if the vbar was the culprit. I've done it with the brain and helicommand with no problems like this. Anyway. Will just put it down to inexperience.
SAB Goblin 700: HJ120,Kon700-52,MKS,HC3SX
TRex 450Pro 3GX; TRex 550E v2.1 3GX APS
Blade mSRX, mCPX, 450X
MSH mini Protos: 3S, 15T, Brain
intelligencer is offline        Reply With Quote Quick reply to this message
Old 10-07-2012, 02:35 PM   #314 (permalink)
Did some maintenance check up on my MiniProtos and found 4 bad bearings.
Both tailbladegrip bearings on only one grip were totally shot.
Above tailbox located belt guide pulley bearings were also shot.
Changed those bearings and now the tail holds real well on every situation.
Futaba T8FGS
Old 10-10-2012, 05:40 AM   #315 (permalink)
Stretched mine and changed motor from 3s - 4s, and mains to EDGE 353mm FBL. Looking forward to testing it when the rain stops.
Synergy E7 ~ Logo600SX + 600SE + 550SX ~ Synergy N7 + N5C ~ Mini P ~ Trex 450L
beans07 is offline        Reply With Quote Quick reply to this message
Old 10-10-2012, 06:32 AM   #316 (permalink)
So you gave up on the 6s motor and went 4s. Look forward to seeing it on the weekend Tim.
//Dennis.
Old 10-10-2012, 02:42 PM   #317 (permalink)
I have both motors but having trouble sourcing 6s packs to use. Jake said that the TP were a special order and most likely wont be ordered again.
Old 10-10-2012, 03:19 PM   #318 (permalink)
Thats the opposite of what Radar told me, yes special order but would be ordered again. I guess we can beat him up on the weekend.
//Dennis.
Old 10-10-2012, 05:41 PM   #319 (permalink)
Jake told me last week that Aidan wanted the batteries for his originally so they ordered extras to make a decent order. He didnt think they would be ordering any more. He told me to contact MF or TP to order them. I will ask Radar on the weekend.
Old 10-10-2012, 07:05 PM   #320 (permalink)
I doesn't look like you are in USA, but helidirect has the 6S pulse 1350's in stock. The product photo is wrong, but you can trust the dimensions in the specifications.
Protos Max 700, Logo 550SX, Goblin 570
MSH USA Flight Team, MSH Brain, Jeti Model, Cyclone
soniczen is offline        Reply With Quote Quick reply to this message
