Old 10-15-2016, 12:30 PM   #1 (permalink)
Default TH and lockout switch....having an issue.
Hey gang, still getting used to the jeti- I have a question.
Not 100% sure what changed in my setu pbut i have a Gobby 500 on Brain. TH (SG switch) isnt working to kill the model. I have default, TH,low, IU 1 and 2 programmed in the system. I also have a lockout switch in the SB slot- which is set to throttle cut. Idea being that I want to have TH and the lockout switch controlling the cut.
A friend whos been helping me said that TH would be one of the f-modes, and the lockout switch would act as a backup.
I have been through the menus a few times now....im stumped.
Can now be found on the links.
Doom Buggy is offline        Reply With Quote Quick reply to this message
Old 10-15-2016, 01:19 PM   #2 (permalink)
If your Throttle Cut is on the lock-switch and you have flight mode "Hold" on switch Sb the you should be all set.
Just make sure the "Hold" flight mode is the top-most in Flight Mode setup. Also go to Throttle Curves and double check that your Hold-flight mode really is on 0. You haven't touched your ESC settings? Needs teaching the endpoints?
I didn't quite get what you are after?
RC-Thoughts.com - TeroS formerly known as CP-Geek
TeroS is offline        Reply With Quote Quick reply to this message
Old 10-15-2016, 01:23 PM   #3 (permalink)
Sorry if I wasn't clear- activating TH does not stop the motor from spinning. The throttle cut switch is the only one that is stopping/starting the motor. It is in the topmost spot in the tx.
Old 10-15-2016, 01:42 PM   #4 (permalink)
Solved- apparently the throttle curve was set to constant. I changed it to standard, and it all works as it should.
Old 10-15-2016, 01:51 PM   #5 (permalink)
Constant is just fine. The point is that throttle curve on Hold should be constant 0. )That means 0 output on throttle regardless on stick-input or anything else.
But good that it's solved now
Old 10-15-2016, 08:48 PM   #6 (permalink)
James from esprit model has an awesome YouTube video on how to create a logical switch that in essence does exactly what you're looking to do.
Chase 360, Goblin Fireball, Protos 380, Trioblin 570, Trioblin 700, Chronos 700, Synergy N7, Protos Max V2 Leggero 800 EVO, DJI Inspire 1, Mavic Pro, Vortex 280, Mojo 280, Blade 200x, Jeti DS-14 MSH Brain2
RCHN #604
rchelipastor is offline        Reply With Quote Quick reply to this message
Old 10-15-2016, 10:48 PM   #7 (permalink)
Thanks RC- orig had a logic switch, went this route instead.
Old 10-16-2016, 01:06 AM   #8 (permalink)
This is a screen shot of my Flight modes
I use a locking switch on the SE position. When the switch is down, it engages a flat throttle curve of -150%. I call it "motor off".
I set assigned Throttle Hold to a 2-way switch on SG position. I set the throttle curve to a flat 25% which is the Kontronik auto-rotation bail out curve.
I assigned IDLE UP 1, 2, and 3 to a 3-way switch on the SA position. For this switch to be active, both the SE locking switch and the SG switches need to be disengaged.
Name:	Jeti Flight Modes.jpg
14S Specter 700 V2 NME/Tron 7/Kraken; 8S Tron Dnamic; 7S Kraken 580; 6S Buddy 380 KSE
VBCE/Neo/EVO, Jeti/Spirit, YGE "T" ESCs; LiFePO4 field charging batteries
Sims on Mac: Heli-X, neXt, AccuRC, Phoenix, AeroFly RC7 Ultimate
Amain Team Pilot
jhamel is offline        Reply With Quote Quick reply to this message
