Old 02-11-2014, 05:13 PM   #1 (permalink)
Default Settings for AR7200BX and Spektrum DX8
Folks, I just got my Protos 500 and I am in the process of installing the AR7200BX. I am looking for set-up and settings for :
1/ the AR7200BX - the heli has standard MSH motor, Futaba servo's and is FBL. I am looking for the set-up parameters in the AR7200BX .
2/ the DX8I - I like to set up an intermediate profile with an idle up 1 and 2 but I would like to have ALL the set-up which include the reverse servos settings etc.
Looking for you help.
3/ I plan to mount the AR7200BX on the port( left when looking from behind) side of the fuselage aft of the gear on the frame, wires facing backwards, this would allow me to not have to install and run extension wires to the servos. That seems to be acceptable based on the manual. Has anybody had problems doing it that way??.
Thanks!!
HarryR is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 09:17 PM   #2 (permalink)
Default Got the first flight in today
Nice, effortless. This Protos 500 flies like a dream. Just amazing , solid, exact, precise and quiet. amazing!! oh and did I mention it..It's a fabulous design, as someone said . the Ferrari of the RC helis.,
Old 02-23-2014, 09:44 PM   #3 (permalink)
im sorry could you speak up i cant hear you over everyones Trex's!
love my P500 too! amazing!
M&P_Hooligan is offline        Reply With Quote Quick reply to this message
Old 02-24-2014, 07:00 AM   #4 (permalink)
Yup, just maidened mine yesterday too with a ARBX. Loved the build, performance and sound!! Bada## heli!!
Compass Atom 5.5 Protos, Trex 450 Pro. MCPX Dbl Brushless
AR7200BX DX8
Outlaw10.5 is offline        Reply With Quote Quick reply to this message
Old 02-24-2014, 05:07 PM   #5 (permalink)
Default More of my input after my Protos 500 maiden flight yesterday
So I had my first flight yesterday . it went perfect. As there are 2 other people I fly with who have Protos 500's ( different FBL / gyro's) I was happy so they could have a look at my finals setup and would you know it, one of my settings was wrong ALTHOUGH I am sure I followed the instructions on one of the Youtube videos. Tail gyro direction needed to be revered. I used 35 for the tail gyro and it flew perfect without any wag or even the slightest shiver. Per the previous owner, the governor was enabled and so was the soft spool feature. It was quite simply. TH on with Throttle on Minimum (closed). Take the TH off and move Throttle up to 50% (my settings are 0-55-55-55-55-55 for Standard and 65-65-65-65-65 for idle up as suggested by the previous owner) with linear Pitch curve 0-25-50-75-100 for both Normal and Idle up. The Heli spooled up to 50 % (half throttle ie zero pitch) and I added some more throttle and it just took of smooth and solid AND QUIET!!
Therefor, I will recommend to get and set up that Governor mode and get the soft spool start set up too. It works and the soft spool features saves your main gear. Very important.
I decided to have 85 % D/R in E , A and R with 25% Expo. For idle up is is 100 % across the board with 20% Expo.( exactly like my Blade 450X) but I did not use idle up just yet.. The Protos flew 4 minute and I had still 45% battery left ( obviously just hovering and puttering around). My TX is a DX8i.
One note. I use 5 cell battery so it might be a bit lite (450 gr) compared with the 6 cell lipo. When the heli spooled up it " set down" it's tail so that was a surprise but then afterwards I remembered, the Protos has a tail boom that is not in line (parallel to) with the landing gear So I think that is why, once there was enough rotor wash, the tail moved to it "this-is-how-I-fly" position. Hope this helps someone because it was pretty difficult to get ALL the information for set up in ONE post.
Old 02-24-2014, 06:03 PM   #6 (permalink)
Default Tools for a successful maiden
www.rdlohr.com
I purchased the Swash leveler from Rick Lohr (www.rdlohr.com).. easy peasy. I was one turn off on one of the servo's.Not any more!! The Protos flew like hanging from a string. Here are some pictures of my swash set-up!
Protos 500 = 8mm = 500 Size heli is the Swash plate leveler you need.
ID:	490141   Click image for larger version
ID:	490142   Click image for larger version
Old 03-08-2014, 07:19 PM   #7 (permalink)
www.rdlohr.com
AWESOME. Glad you like it!
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 03-09-2014, 10:11 AM   #8 (permalink)
Rick
very interested in this leveler how does it work?
