Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 04-21-2014, 01:34 PM   #61 (permalink)
Five more flights in this morning before work and I'm still impressed.
C'mon Gaui, lets get the tail pitch slider(which is what I really have been waiting for)
SAB KRAKEN JIVE 120, BK CYCLIC, BK TAIL, PYRO 750-500, THUNDERBOLT, VBAR
GOBLIN BT SPORT HELIJIVE 120, BK CYCLIC, BK TAIL, XNOVA 4525 530, SWITCH, VBAR
GOBLIN 570 JIVE 120, MKS SERVOS, XNOVA , SWITCH MAINS, KBDD TAILS, VBAR
seefest is offline        Reply With Quote Quick reply to this message
Old 04-21-2014, 05:10 PM   #62 (permalink)
+1000000000000
Soxos Strike 7.1
Minicopter Diabolo 700 UL and 550
Mikado Logo 600SX
Gaui X3
Arag_ is offline        Reply With Quote Quick reply to this message
Old 04-21-2014, 05:15 PM   #63 (permalink)
Default Re: New X5 Formula Head
Same here! I hope it's a little more reasonably priced than the new head/swash, though.
Sent from my Nexus 4 using Tapatalk
hoblium is offline        Reply With Quote Quick reply to this message
Old 04-22-2014, 07:49 PM   #64 (permalink)
Hello guys,
Does anyone know if the swash can be upgraded without upgrading the head? My swash is sloppy but the head is fine. (I have the FES kit)
thanks
Synergy 556, Sab 700, Vbar and Vcontrol
Mac_Heli is offline        Reply With Quote Quick reply to this message
Old 04-22-2014, 10:48 PM   #65 (permalink)
Originally Posted by Mac_Heli View Post
Hello guys,
thanks
Should be no issue at all with the new swash and older head.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 04-23-2014, 06:35 AM   #66 (permalink)
Not sure about that... There seems to be an ofset on the washout balls... Not at 90 from the pitchlink balls...
Gaui X3 HW 50A V3 OMG H1/H2 Servo's BL450MX Mini-V (M.I.A.)
Gaui X5 FES Polaris BEC BLS451/251 Silverline V-Bar Formula Swash/Head
JR Forza 700 Scorp 160A opto + 4525 520 JR NX8925/SLG01 Vbar Neo
JR XG14 PL8 v2
mverhorst is offline        Reply With Quote Quick reply to this message
Old 04-23-2014, 12:43 PM   #67 (permalink)
They are not off set, the balls that connect the links from the swash to the main grips are just turned 90 degrees. Should be a drop in replacement, no issues. As far as the upgraded head, you can use that with the old swash as well.
BTW, if your only upgrading from the old swash to the new swash, you should not have to do anything as far as linkage rod adjustment, FBL settings, or any other change. Just pull the old swash off, and drop the new swash in, pop the links on, and fly!
GAUI X5 / X7 *
Old 04-23-2014, 03:44 PM   #68 (permalink)
I have just checked mine upgraded swash, have not mounted it yet.
What you mention on the pitchlink balls was not what I ment. But I have checked the washout balls and they are at 90 from the pitch link balls so you are good to go anyway...
JR XG14 PL8 v2
Old 04-23-2014, 05:36 PM   #69 (permalink)
I don't see a problem swapping swash. The new version is much lighter as well. From memory, 20+ grams.
Gaui R5 Kosmik 200, Scorpion HK 4235-630
TDR (build in progress)
Raptor G4 720e xnova 4530-525 Kosmik 200
Gaui X5 Jive 100 Scorpion 910, Jeti DS-16
john2kx is offline        Reply With Quote Quick reply to this message
Old 04-27-2014, 09:57 AM   #70 (permalink)
I have bolted mine on...
Found the install a breaze until the washout arm ball links had to be installed.
I had some strugle getting them treaded, so I used the supplied jezusbolt for leverage and that made it real easy... To easy... The ball link broke clean inside the washout arm....
Darn it... I've got it out be putting it in the oven at 100 degrees C and using a exacto knife...
Attached a picture with the jezusbolt leaver... Please be carefull, the ball will snap without any warning and there is no measurement givin in the manual....
JR XG14 PL8 v2
Old 04-27-2014, 10:15 AM   #71 (permalink)
I screwed mine in as tight as I could by hand and just by luck it was perfect. If it needed to go anymore mine probably would have broke as well.
Old 04-27-2014, 11:49 AM   #72 (permalink)
When assembling the washout arms I found it easiest to screw them in a little at a time, back out to clear any debris and then repeat until they were fully seated.
Just to give a ballpark measurement I clamped my calipers on those arms. They measure 32mm from the top of the metal part to the end of the plastic ball link.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 04-28-2014, 12:11 AM   #73 (permalink)
Does any of you Gaui Insiders know if there will be any spears for this head...???
I would really hate to crash it right know and ruin a part of the Formula head.
JR XG14 PL8 v2
Old 04-28-2014, 01:10 AM   #74 (permalink)
Thats what im waiting o, spares. Knowing me i crash the first flight out and then what?
Buy a whole new formula head? Nope.
Once i can buy the parts seperate i will buy the head. Ive flown it already and i want it.
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 04-28-2014, 03:34 PM   #75 (permalink)
Why is this swash 'better' when it seems to have smaller bearings?
Also why are the swash ball sideways and not facing into the rotation (they face anti clockwise). Wouldn't this mean there is more chance the ball links will pop off? Wouldn't it have been better to go the other way so they cannot fly off?
12S 4035-500 Gaui X5 Formula VBar, 6S 2520-1880 Gaui X3 AR7200BX, Phantom 3 Professional
FailureToFly is offline        Reply With Quote Quick reply to this message
Old 04-28-2014, 07:10 PM   #76 (permalink)
My x3 is like that, ive had some hard landings, a few crashes and a blade strike on a light pole. The only links that came off were the grip arm links.
Im with you on the bearing size, but im not sure how much smaller it is?
If the swash is like the x3, which it looks like the bearing replacement is easy and cheap.
Also if they sell the lower and upper separate thats even better.
Old 04-29-2014, 12:17 AM   #77 (permalink)
I actualy think that the same bearing is used...
Seems like the lower part of the swash has the same dimensions as the old swash.
Never mind, picture above shows otherwise...
JR XG14 PL8 v2
Old 05-05-2014, 02:43 AM   #78 (permalink)
Can someone running the new formula head please tell me the distance from the boom to blade tip?
Also what blade length your running?
Old 05-05-2014, 11:24 AM   #79 (permalink)
Boom to blades= -10 mm from stock
Blades- stock 520-523mm
Old 05-05-2014, 12:44 PM   #80 (permalink)
I dont have the stock measurement anymore, can someone please measure the formula blade tip distance ?
I need the actual numbers, thanks
