Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 03-31-2013, 02:42 PM   #1 (permalink)
Default Stuck ? OWB shaft
I'm trying to change my OWB from the 19 to 20t version and seem "stuck".
I have the motor removed.
I have the two screws removed from the upper gear (42 T) and it spins on the shaft.
I have the lower "bolt" removed the bottom of the OWB shaft.
It seems like this shaft should push down and out of the heli, but it does not seem to move. I've done some light taping on the shaft end at the top, but nothing is happening.
Suggestions needed.
blade_crasher is offline        Reply With Quote Quick reply to this message
Old 03-31-2013, 03:06 PM   #2 (permalink)
HF MR Support
...Take a 5mm pin punch or old 450 main shaft and tap the OWB shaft down..no need to remove the bottom bolt...If it is stuck too bad, get a bigger hammer!PT
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 03-31-2013, 06:28 PM   #3 (permalink)
PT thanks again. The 450 shaft and hammer did the trick.
Old 03-31-2013, 06:35 PM   #4 (permalink)
HF MR Support
Yep..."Been there- done that"
Old 03-31-2013, 09:32 PM   #5 (permalink)
PT: I replaced the "metal shaft" with new along with the 20t new OWB. When I removed the old 19t, some of the small "pins" fell out of it. It has gone to the trash but I have saved the main shaft part. There is some visual marking but nothing I can "feel". Is there some reason I should not save these for re-use?
Old 03-31-2013, 09:48 PM   #6 (permalink)
HF MR Support
Yep...the cage holding those bearing pins is usually what breaks...I save mine that I take out and use some purple Scotch -brite along the length of the shaft so they can be used again
if nothing else is available...
