nano CP X Blade nano CP X Helicopters Information and Help |
08-03-2014, 11:01 PM | #1 (permalink) |
Nano cuts out at low RPM
I was flying at night and noticed something I have not seen before in the daylight. If I spool up (stock Nano) very slowly (using a standard 0-25-50-75-100 curve) it will sometimes cut out at about 20%. The blue light will go off and the motor stops. However it picks right back up again (or may stop if I keep the stick down low). However as soon as I give it more power it will work fine. It never happens at higher stick input levels or in stunt mode (flat 80% curve).
Once in the air it works fine. It is on the gel low end of the throttle curve that it can't fly at those low RPMs. So it doesn't affect flight, but does seem odd and I wanted to see what it might indicate. Is the board on the way out? Motor? |
08-04-2014, 03:55 PM | #2 (permalink) |
Yep, happen to me. Sorry for the bad news... your battery is dying.
08-05-2014, 11:35 PM | #3 (permalink) |
Thats good news, I thought it might be the board
08-06-2014, 12:48 AM | #4 (permalink) |
Yup, sounds like a battery.
If a new battery doesn't work, then it might be a motor or servo that is pulling too much power.
"If you aren't crashing...you aren't flying" ZMR250-ZMR150-Custom 250 hex -Nic, Team Mesa RC Foam Fighters Elite |
