Old 08-11-2013, 07:31 PM   #21 (permalink)
Default REQUESTS for improvements/new features on DS-16/DC-16 Tx
Originally Posted by chenlixyz View Post
I am aware of that thread as well. I've posted in it also. I know it's common for Jeti and it does not affect performance. I just added it to this thread because I'd like to see it adjusted in the radio so its goes fully to 100% and 0% at neutral.
Again - a suggestion to Jeti is all.
Team - "Self Interests" -
Old 08-11-2013, 10:35 PM   #22 (permalink)
Default Re: REQUESTS for improvements/new features on DS-16/DC-16 Tx
Unfortunately it looks like the RSat2 doesn't support the function of setting the center and throw in the Rx. I was hoping to use this feature but can't.
//Dennis.
Sent from my phone, we don't always agree on the auto correct choices.....
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1
soXos DB7 nightflyer : Jeti DS-16 & DS-12
I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades
Thunder Fighter is online now        Reply With Quote Quick reply to this message
Old 08-11-2013, 11:49 PM   #23 (permalink)
[QUOTE=Also - the funky issue where everything is off by about 2% in the servo monitor screen is annoying. Even when re-calibrated, full deflection does not yield 100%. It's either 98% or 102%. Center is not 0%, its usually 2%.[/QUOTE]
+1 for this: it is very annoying to have this 'issue' in this wonderful Tx !!!!
gelatmi1 is offline        Reply With Quote Quick reply to this message
Old 08-11-2013, 11:52 PM   #24 (permalink)
Originally Posted by Seasick78 View Post
I'd prefer the function curves to be on a zero to 100 scale rather than -100/zero/+100. In other words, mid stick is 50 and not zero.
+1
Sent from my GT-N7105 using Tapatalk 2
Henseleit TDR
Protos Max 700, Logo 690SX , Logo 480 XXtreme , Goblin 570,
Forza 450
dylanwee is offline        Reply With Quote Quick reply to this message
Old 08-12-2013, 12:02 AM   #25 (permalink)
Default Servo Assignment Label
Add the possibility to change the Label on Servo Assignment
e.g.:
Aileron 1 ---> Ail 1 left
Aileron 2 ---> Ail 2 right
Flap 1 ---> Flap left
(this feature is already present on Functions Assignment)
Old 08-12-2013, 12:26 AM   #26 (permalink)
Agree but only for throttle.
Old 08-12-2013, 03:08 PM   #27 (permalink)
Originally Posted by gelatmi1 View Post
Add the possibility to hold the servos to their Neutral position in Servo Test display or in another part.
This could be used for example when we are setting the swash linkages.
+1
Have the Servo signal (standard mode) on output ports and PPM signal on SAT port at the same time on Rxs !!!
+1
Originally Posted by im4711 View Post
I would like to see an increased number of logical switches since some combinations almost did drive mine close to max them out.
Also when playing music I wish I could embed other audio commands/announcements without stopping the music.
both +1
Goblin 500 | Goblin 700 | Logo 500SE
basilio is offline        Reply With Quote Quick reply to this message
Old 08-12-2013, 03:15 PM   #28 (permalink)
Jeti telemetry triggers, as posted in https://www.helifreak.com/showthread.php?t=553039
And a more complete implementation of the governor-function. In such a way that you can define the same low- and high-rpm values as in the Mezon and be able to select the desired rpm. At this moment it's more like the Function Curve with fixed Constant value.
Old 08-12-2013, 03:43 PM   #29 (permalink)
I think everyone would like more logical switches and sounds on events...
In fact there aren't even enough available sounds on event for each position of all the switches on my DS-16...
The fact that there are only 16 available sounds however, could be due to a hardware limitation, and not easily increased by a firmware update...
Fingers crossed though...
Groucho_ is offline        Reply With Quote Quick reply to this message
Old 08-13-2013, 12:44 AM   #30 (permalink)
+1
Old 08-13-2013, 08:42 PM   #31 (permalink)
Default MUI
a. Allow the telemetry sensing of "Capacity" to count down as well as up.
b. Allow multiple flights with no reset to the "Capacity" value shown in the telemetry screen. <-- if flight "1" uses 40% of the battery mAh, then flight "2" should pick up where flight "1" left off. Cockpit does this currently.
c. Show "fuel gauge" (battery capacity setting max = 100%) on the telemetry display screen. Cockpit does this too and is very useful to glance down and see the "fuel gauge" - not just the mAh used.
d. Allow quicker scrolling when setting "capacity" in the telemetry sensors / logging setup.
my .02
Dale.
rdalemercer is offline        Reply With Quote Quick reply to this message
Old 08-13-2013, 09:43 PM   #32 (permalink)
This is how it works already as long as you do not cycle battery power. If you land, but stay connected with power on, it will resume when you spool up again.
Old 08-14-2013, 03:35 PM   #33 (permalink)
Right....but how many times do you not cycle the battery power it you're going to make adjustments, etc? ...it shouldn't be too big of an issue (?) to add the functionality as long as there are more than "me" that would find it useful.
Old 08-14-2013, 03:39 PM   #34 (permalink)
Wasn't saying its a bad idea at all. Just wasn't sure if you knew what I had mentioned.
Old 08-15-2013, 10:48 AM   #35 (permalink)
Yup - I understood...thanks for checking though. In my (short) experience with the DS-16, I've missed being able to have a second flight on a battery that has been partially used. The timer resets as well, so it's up to my brain to remember the last timer mark and mAh used so I don't have an unintended meeting with terra firma
Thanks for your support. It really is helpful.
Dale.
Old 08-18-2013, 05:28 AM   #36 (permalink)
Default Curves improvement
Improve the Function Curves visualization/management.
At the moment after more or less 110% the cursor disappears.
It could be visible till to 150%
In other words something like Dual Rate/Exponential curve visualization.
Old 08-18-2013, 05:35 AM   #37 (permalink)
Default Free Mixes Curves improvement 1
Improve the Mixes Curves visualization/management.
Old 08-18-2013, 05:48 AM   #38 (permalink)
Default Free Mixes Curves improvement 2
Give the possibility to set the OUT value till to 300% ( so e.g. it will be possible to move a point from -150% to +150% (max +/- limit servo throw) using only one mixer and not two/three mixers like now).
Or, to reach the same result, add an OFFSET curve feature till to 300%.
Old 08-20-2013, 03:26 PM   #39 (permalink)
Dale, as soon as you start the edit of the capacity number, hit menu once and increments are by 10, hit again, by 100. I change it all the time because for some helis I have different capacity packs.
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 08-20-2013, 05:35 PM   #40 (permalink)
This is cool tip. I was about to ask the exact same question. It took me minutes to scroll to 5000mah yesterday.
chenlixyz is offline        Reply With Quote Quick reply to this message
