Go Back   HeliFreak > R/C Electronics Support > Robird G31
Robird G31 RobirdUSA Factory Support Forum
Old 07-14-2015, 12:41 PM   #1 (permalink)
Default set up questions
I just picked up my robird g31. I'm still putting my heli together so I'm sure I will be back with many questions but here is the first.
How can I run two spectrum satellites & a BEC? do i need a Y harness from the BEC to both of the SRX cables?
Keep your skids up!
TEAM FLYBAR
130x, X3 Sprint, Goblin 500 ikon, Align 600 Nitro fb, Logo 600 ikon, DX7, No more money...
CompleteDestruction is offline        Reply With Quote Quick reply to this message
Old 07-15-2015, 08:57 PM   #2 (permalink)
https://www.helifreak.com/showthread.php?t=619007
I power the rudder with the esc, and the cyclics with a bec.
7hvu, 6hv,,Prôtos,450Pro, DT520E
some planks
Jumna is offline        Reply With Quote Quick reply to this message
Old 07-19-2015, 12:37 AM   #3 (permalink)
That way works really well.
There is another route you can go if you're handy with a soldering iron, and don't mind opening the Robird up to do a little surgery.
https://www.helifreak.com/showthread.php?t=477043
SoXoS Strike 7.1 (x2) | Miniature Aircraft Whiplash Nitro NII | Miniature Aircraft Fury 57 | Blackout Mods : ??????
Teams: Aero Panda, Heli-Professional, SoXoS USA, 1ST RC, Xpert RC USA, Pulse Battery, iKon Flybarless, Blackout Mods USA
PowerDyne is offline        Reply With Quote Quick reply to this message
Old 07-19-2015, 11:05 AM   #4 (permalink)
My bec only has one output lead and I don't really want to get into opening up the g31. I also want to run all 4 servos at 7.4v. So I'm thinking a Y connector is best for my situation.
This is on a x3 and my bec it a 10a
Keep your skids up!
TEAM FLYBAR
Old 07-19-2015, 12:18 PM   #5 (permalink)
Then the Y cable into the SRx-1 Port with the BEC plugged in one side, and the Srx cable in the other. Then run one of the male/male leads that came with the Robird between the SRx cables, and the other SRx into SRx-2 to power the tail servo is the way I would do it.
Or you could also place the Y split into one of the Cyclic servo ports and plug in the BEC there as well.
Ground is common on all ports except the R/S port on the left side, as that is signal only on all three pins.. All you really need to power the tail is to bridge the positive from any of the ports that can accept power.
Old 07-22-2015, 11:06 PM   #6 (permalink)
Ok guys. I'm not sure why I'm having issues with such a simple concept...
I found a picture online that may help... is how they show in the picture okay?
Also. Do I understand correctly that I must bind sats on a different rx? There is no way to do it with the g31?
Keep your skids up!
TEAM FLYBAR
Old 07-22-2015, 11:34 PM   #7 (permalink)
Its been awhile since I've setup a Robird but I was running 2 sats on a heli with no rx but I believe I had to bind them with a rx.
T-Rex 700 Dominator vx1e, Goblin 570 vx1e, T-Rex 600N DFC vx1e, Jeti Ds-14
NSFlyer12 is offline        Reply With Quote Quick reply to this message
Old 07-23-2015, 10:07 AM   #8 (permalink)
You bind your sats to the receiver. One and then the other using the same receiver. Then plug them into the Robird.
blade_crasher is offline        Reply With Quote Quick reply to this message
Old 07-24-2015, 12:53 PM   #9 (permalink)
Thanks guys! Is it okay to wire it how it shown in the picture?
Keep your skids up!
TEAM FLYBAR
