Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion > KDS Innova 700, 600, 550, 450
KDS Innova 700, 600, 550, 450 KDS Innova 700, 600, 550, 450 Discussion
Old 02-16-2013, 09:17 PM   #1 (permalink)
Default 550 DFC to FBL conversion?
Looking at the DFC and FBL heads it seems that they both use the same grips and arms and the FBL head seems to use the same hub with washout guides than the flybar head uses, except that the washout base has a set screw.
My question is, could I replace the DFC links with ball links and then put an FBL washout base and arms on? Will the set screw be enough or does it actually need those washout guide pins? I know a number of other FBL heads just use a set screw and no other support on the washout base (although I prefer RJX's single piece split clamp style washout the best)
I ask this because while HK has a good price on the Innova 550, they only have the DFC version and I want a standard FBL head. (DFC isn't good for moderate headspeeds)
Old 02-17-2013, 06:30 AM   #2 (permalink)
Default DFC Head issues
You can still use the original KDS wash out its fine.. i use them no dramas... other than that you can use any washout for a FBL version only thing you have to watch is if you replaced the the main shaft for the DFC shaft its a lot shorter... so if the washout is not connected to the head directly then you need the old main shaft for the swash room to get full pitch.. been there done that :-)
cheers
Madryan is offline        Reply With Quote Quick reply to this message
Old 02-18-2013, 12:55 PM   #3 (permalink)
Actually the arms coming off the blade grips are different between the FBL and the TDT style head.
GhostFlyer1
KDS Dual Innova 700's, Innova 450,, and to many others to list
Ghostflyer1 is offline        Reply With Quote Quick reply to this message
Old 02-18-2013, 04:58 PM   #4 (permalink)
Default Re: 550 DFC to FBL conversion?
The blade grip arms will need to swapped for originals they should bolt right on
Sent from my GT-I9210T using Tapatalk 2
