Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba CGY750 FBL System
Futaba CGY750 FBL System Futaba CGY750 Help and features Support Forum
Old 06-22-2014, 11:19 AM   #1 (permalink)
Default CGY750 Swash Servo Installation and Setup
Hi all, doing my first install of a CGY750. Using firmware v1.4. On page 13 of the manual it states;
"Navigate to the [SWASHsetbasic] -> SWS.Rate parameter. This will disable the gyros and cause the servos to remain centered during setup."
It does disable the servos but it does not center them. Am I missing something?
Stu
awesomeOne is offline        Reply With Quote Quick reply to this message
Old 06-22-2014, 07:01 PM   #2 (permalink)
It does not center them like a Beast X regardless of stick position. You still need to go mid stick when installing the servo arms. But what it does do is the gyros will not be moving the servos as your are trying to do a setup.
marc8090 is offline        Reply With Quote Quick reply to this message
Old 06-23-2014, 09:37 AM   #3 (permalink)
Right, what Marc said. What I do with my 14SG is pull up the servo monitor screen so that I can make sure that I have the collective at exactly mid-stick while I'm leveling the swash and setting zero pitch.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 06-23-2014, 10:14 AM   #4 (permalink)
Default Zero
I will usually set up a temporary pitch curve that is zero all of the way across. That way even if the stick moves you will remain at mid stick value. I have done this since 2006 on flybarred models.
Team Kontronik Team minicopter VTeam
Team YS, Team RoToR Rage
Evo Power Battery PeakAircraft
Clarence Creer is offline        Reply With Quote Quick reply to this message
Old 06-23-2014, 06:15 PM   #5 (permalink)
Thanks guys. I have used the flat pitch curve on other setups. Was keen to make sure my unit was not faulty as the manual seems to indicate that it locks the servos at mid stick... Apparently not...
Old 06-23-2014, 08:00 PM   #6 (permalink)
Nope, it does not. I like it because it makes it really easy to check how level the swash is at the full range of collective movement (using a linear pitch curve, obviously).
