600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
06-29-2014, 05:38 PM | #1 (permalink) |
tail bounce
Hi Guy's
I've just over from nitro to electric. got the heli all build and 3gx all set up, on the test fkight i found the tail would bounce when turning to the right, its fine when turning left. running 4v on the 3gx at first then updated to 5v and its the same. if i lower tx gyro gain it get worse. the only thing i've build different from the instruction is put the servo on the left had site of the model if your looking from the tail thanks for any advise |
07-02-2014, 01:13 PM | #2 (permalink) |
Most likely you need to lower 'Rudder locking Gain' which is found in the 3GX software under the rudder parameters tab.
Also set rudder delay to zero, to do that adjust to zero then leave the 3GX to time out of set-up mode. If you press the button the delay jumps up again.
Gob 700 BT 'T' | SoXos Strike 7.1 | Henseleit TDR, TDF, TDSF & TDR2 | OMP M1&M2 | UK stockist for OMPHobby M1/M2 ScotiaRC.co.uk |
07-03-2014, 01:05 PM | #3 (permalink) |
thanks for the reply, managed to get it done, just have to wait for the good old scottish weather to break
07-03-2014, 04:53 PM | #4 (permalink) |
Yeah, being just up the A90 in Aberdeen i can sympathise on the weather, non stop wind! Forecast for Saturday looks ok.
07-06-2014, 02:37 PM | #5 (permalink) |
Well managed to test the heli today and i've still got the tail bounce.
07-08-2014, 11:41 PM | #6 (permalink) |
Bounce
I have been battling the same problem.
I almost have it dialed out by lowering the rudder acceleration in the software under the rudder parameters section. Hope this helps! |
07-09-2014, 04:36 PM | #7 (permalink) |
I've got the rudder acceleration set to zero
07-13-2014, 02:57 AM | #8 (permalink) | |
Also have you thoroughly checked the mechanical setup:
07-16-2014, 05:56 PM | #9 (permalink) |
thanks for your reply Grumpy, all is fine with the set up, no slop, servo at 90, no binding.
i never changed the rudder locking gain its set at 70% Last edited by mrmagoo; 07-17-2014 at 03:21 PM.. |
