Like Tree1Likes
Old 11-24-2013, 10:24 PM   #21 (permalink)
Ok, then what about this one...
Link: http://www.daddyhobby.com/forum/showthread.php?t=76981
-Shane
ShaneXman is offline        Reply With Quote Quick reply to this message
Old 11-25-2013, 12:35 AM   #22 (permalink)
-Shane
He shaved it down most likely the only pyro motor that has a 5mm shaft as standard is the Mini Pyro 400 motor.
SYNERGY 516
Mikado LOGO 550
Mikado LOGO 700
SMJT is offline        Reply With Quote Quick reply to this message
Old 11-25-2013, 01:06 AM   #23 (permalink)
Roger that! Thank you for the clarification bud.
-Shane
Old 11-25-2013, 10:11 AM   #24 (permalink)
Kontronik used 5mm shafts in Pyro 600 motors in the past (I had a 600-12 with a 5mm shaft in my Logo 500), when you have a 5mm version and send it to Kontronik they replace it with a 6mm shaft unfortunately.
Regards Arnaud
Mikado Logo 550SX | Mikado Logo 600SE V2
catzjes is offline        Reply With Quote Quick reply to this message
Old 11-25-2013, 10:45 AM   #25 (permalink)
This is Mikado's way of making sure you only use their sponsored motor unfortunately. More and more people are getting away from 5 mm shafts, i just can't understand why they insist on 5 mm unless they don't want people to have other options. For me that was the only reason i am not trying this heli out. I just like to have the option of selecting my motor rather than being dictated
_____________
abanihani is offline        Reply With Quote Quick reply to this message
Old 11-25-2013, 11:13 AM   #26 (permalink)
No doubt Mikado has a a nice little deal going on with Edge blades and Scorpion. I wonder if they weren't tied up would they have made it a little bigger?
JR Forza 450 | Align Trex 550 V1 | Henseleit TDF | Henseleit TDSF
Varelco is offline        Reply With Quote Quick reply to this message
Old 11-25-2013, 04:26 PM   #27 (permalink)
I hope Mikado dont start going down the Align route and dictating our setups for us,i chose to go back to Mikado airframes for their flexibility,ive already been put off buying a 550SX because of the lack of motors for it and this could put me off a 480,i want to fit what motor i want and its certainly not a Scorpion
raptor50luvver is offline        Reply With Quote Quick reply to this message
Old 11-25-2013, 05:45 PM   #28 (permalink)
I too hate the 'dictated' setups because I know my helis fly great with other setups. I dislike how Mikado has made the Logos less like Lego in that many of the parts are no longer compatible or have been discontinued.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 11-25-2013, 07:36 PM   #29 (permalink)
Mikado seems to be the Apple iPhone/iPad of the Heli world.
Locked into their way or no way, very restrictive.
On the other hand, it simply works well and there are few complaints of quality or performance.
SAB Heli Division Rotorquest
snemi00 is offline        Reply With Quote Quick reply to this message
Old 11-26-2013, 12:30 PM   #30 (permalink)
+1 to that. I was thinking along the same line....
I don't always fly but, when I do, I fly Gaui "X1" and "X1.5"
fabian1675 is offline        Reply With Quote Quick reply to this message
Old 11-26-2013, 12:48 PM   #31 (permalink)
Mikado's recommended setup for the Logo XXtreme 480 is as follows:
FBL: Mini VBar Blueline Express
Motor: Scorpion HK4015-1070
ESC: YGE 90 LV with Power BEC
Cyclic Servos: Savox Digital Servo SH-1250MG Midi Size
Tail Servo: Savox Digital Servo SH-1290MG
Link: http://www.readyheli.com/MIK2208-Mik...o_p_41963.html
No thanks...
I guess I can just turn down / taper the Kontronik Pyro 6mm shaft to 5mm...
...and go with my desired setup from the first post.
-Shane
Old 11-26-2013, 01:45 PM   #32 (permalink)
how easy to taper the shaft? I asked Kontronik and they were heavily against making the shaft 5 mm, you probable can get away with scorpion as the internal shaft diameter is probably 8 mm or so but not pyro motor, it is 6 mm all the way through.
_____________
Old 11-26-2013, 02:10 PM   #33 (permalink)
What's the difference if you turn down an 8mm shaft or a 6mm shaft? Either way, the weakest part of the shaft is going to be the smaller diameter portion. Am I missing something?
-Shane
Old 11-26-2013, 03:01 PM   #34 (permalink)
yes you are, if you have a small diameter shaft like 6 mm all the way through it is so easy to damage the internal bearings or at least reduce their life significantly, that is the reason that Kontronik does not advise on the use of 5 mm in their motors. you have to be careful here. Scorpion get away by using larger inside shaft and bigger bearings so okay with scorpion and not okay with Kontronik.
_____________
Old 11-26-2013, 04:18 PM   #35 (permalink)
Got it. Thank you for the additional information.
-Shane
Old 11-27-2013, 12:12 PM   #36 (permalink)
can u run 12s on this machine?
TREX 700FBL - JR 8717HVs -Outrage BL9188HV Tail- OS 105HZR - Hatori SB-22 Pipe - Vbar 5.3 Pro
Synergy N5C - JR 8917HVs -Outrage BL9188HV Tail- YS 56 SR- Hatori Pipe- Vbar 5.3 Pro
haha is offline        Reply With Quote Quick reply to this message
Old 11-27-2013, 01:40 PM   #37 (permalink)
No one is going to be able to answer that really, no one has seen it. There looks like there might be room in the tray to fit a couple of 6S batteries, stacked or one in front of the other.
Is there enough 'meat' on the pinion to drill it out to 6mm without jeopardising strength? Would be easier than removing and turning down a motor shaft
Old 11-27-2013, 11:55 PM   #38 (permalink)
Originally Posted by prototype3a View Post
My best wild guess... the -12.
I know this is probably a n00b question, and I do know that the only difference between the Kontronik Pyro 600-11 and the 600-12 is the KV's...but why would I choose one over the other? More gearing options? Greater motor efficiency? Which one is the better option for the XXtreme 480?
I'm pretty much decided on turning down the stock Kontronik Pyro 6mm shaft, so I'd appreciate any input, clarification and direction. Thanks in advance.
...and just for reference, here are the specs of the "Super Combo":
-Shane
Name:	Screen Shot 2013-11-27 at 9.47.23 PM.png
Old 12-02-2013, 04:38 PM   #39 (permalink)
This is my intended setup:
  • Flight Style: Technical 3D
  • FBL System: Mini Vbar Silverline (I think it will be released next year)
  • Motor: Kontronik Pyro 600-11
  • Pinion: 18T mod .7
  • Target Headspeed(s): 2600rpm
  • ESC: Kontronik Jive 100LV
  • Governor: Kontronik
  • Cyclic Servos: Futaba BLS153
  • Tail Servo: Futaba BLS251
  • Main Blades: Edge 473 FBL
  • Tail Blades: Edge 72
  • LiPos: 6s 3600-4000mAh
  • Anything Else: Scorpion Backup Guard
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 12-02-2013, 04:50 PM   #40 (permalink)
Where do you plan on getting your 18T mod .7 herringbone pinion to fit on the Kontronik Pyro 600-11 motor shaft?
Let me know. Thanks!
-Shane
