Old 11-11-2007, 09:56 PM   #1 (permalink)
Default K&B night blades
I bought a set of K&B night blades for my Diablo (450 class heli). I know I have to charge them with the included UV LED, but I'm wondering: What's the best way (location on the blade and amount of time) to charge them and how long can I expect them to glow bright enough to be seen?
HeliFreak Support
Graupner MZ-32
Old 11-11-2007, 10:07 PM   #2 (permalink)
I think you are supposed to mount the uv led on the tail pointing at the blades.
If the led goes out the blades will glow a bit, but I dont think you should run them that way....
-Ari
aka, Sir-Crah-a-Lot
aballen is offline        Reply With Quote Quick reply to this message
Old 11-11-2007, 10:53 PM   #3 (permalink)
Ah, I see now. I feel like an idiot: I was thinking that the LED would have to go on the tail rotor if it was mounted on the heli and I knew there's no 12V power source small enough and with enough capacity, not to mention one that wouldn't mess up the aerodynamics. The sparse instructions say to shine the LED on the tip of the blades, so I assume I'd mount it on the vertical fin and shine it toward the blades?
The instructions also say not to look directly into the LED, but I assume that means on the ground? I don't see how you could avoid looking at it, at least for a few seconds, when the heli is in flight.
HeliFreak Support
Graupner MZ-32
Old 11-16-2007, 11:31 PM   #4 (permalink)
any luck?
Pics of how you mounted the tail would be cool... action photos too!
-Ari
aka, Sir-Crah-a-Lot
Old 11-17-2007, 06:44 AM   #5 (permalink)
Not yet. A death in the family preempted all of my heli activities. I hope to get back to it in a day or two.
HeliFreak Support
Graupner MZ-32
Old 11-17-2007, 06:53 AM   #6 (permalink)
We will put some mounting pictures up on our web site soon. The best place to mount the led is on top center of the boom pointed at blade. The bright spot of the led should shine about 1/4 nich down from the tip of the blade. A quick way to mount them is to use a drop of hot glue on the top of the boom, push the led on top on the hot glue. Put a small zip tie on it to make sure it don't move. Wire it up and have fun.
The is a video of Burt Flying his 600 at IRCHA with them.
Thanks Kevin & K&B Dream Designs Team
KandB is offline        Reply With Quote Quick reply to this message
Old 11-17-2007, 10:09 AM   #7 (permalink)
Registered User
Sorry to hear, our condolences from HF.
William James
Old 11-17-2007, 06:50 PM   #8 (permalink)
That would be great, Kevin. Thanks.
And thanks for the kind words, Will. It's been a rough few days, but my mother is now at rest and it's all behind me now.
HeliFreak Support
Graupner MZ-32
Old 11-18-2007, 10:09 AM   #9 (permalink)
I used a plastic tail servo mount with 3 zip ties for mine.
dieselracer is offline        Reply With Quote Quick reply to this message
Old 01-27-2008, 02:07 AM   #10 (permalink)
Default LED power supply
My problem is: how do you power the LED light?! No where can I find how to power it. Please assist. Thanks.
_Sam B_
Sam2b is offline        Reply With Quote Quick reply to this message
Old 01-27-2008, 04:08 PM   #11 (permalink)
You plug it into a free reciever channel...
greetings
doeni is offline        Reply With Quote Quick reply to this message
Old 02-06-2008, 12:03 AM   #12 (permalink)
That's what I did too, connect it to a free slot in the rx.
However I sent an email to K&B and here's what they replied:
Hello Maxime,
Sorry it took so long to get back to you but I wanted to talk to my R&D VP first.
You should have more clearance than what you have. The center of the bulb of the LED should mount over of the boom.
You also really need 12v for the LED. Connect the wires to the same source that you are connecting your glow wire to. True UV LED is very dangerous as you can not see the light. It is also VERY expensive. Ours is a safer quality which allows you to see the light. You should still not look directly into the light. The quad led we use on the larger blades is very bright yet safe at 10' distance.
This picture is of a 30/50 size with the Ultra bright UV LED. The mounting position can be the samewith on exception. We have found that it is best to shine the light closer to the end of the blade on a 450 and closer midway between the root and the end of the blade for the 30/50 size helicopters. In the picture the boom is rolled forward. The bulb is really above the center of the boom.
Thank you for your question!
Dick Cook
President
K&B Dream Designs, LLC
(614)863-1111
http://kbdreamdesigns.com
dickcook@kbdreamdesigns.com
Maxime30 is offline        Reply With Quote Quick reply to this message
Old 03-12-2008, 11:04 AM   #13 (permalink)
Any idea where you might get a true UV LED from? I'm having hash around to block the light. Getting an eyeful of LED when you are hovering or doing a pass is quite disorientating.
Currently I'm using a shade, attached to the boom, to block the light. I'm a bit worried about how it's going to hold up in maneuvers, though.
An optional reflector http://www.theledlight.com/reflectors.html and a true UV LED would be a nice upgrade if you could provide it.
The above text is not intended to cause offense, unless implicitly stated.
Rogan is offline        Reply With Quote Quick reply to this message
Old 05-21-2008, 10:52 PM   #14 (permalink)
I have to say that I had the same question. I don't think you should feel stupid. The directions don't really say for sure and I did go to the web site (I'm talking to you K&B) and there still is no description or pictures. I'm going to try it now. Hope it works as well as I have imagined.
Doug
rotorcraftman is offline        Reply With Quote Quick reply to this message
Old 05-22-2008, 10:55 PM   #15 (permalink)
Try electronicgoldmine.com
Thats where I am going to get stuff from. I Not looking for UV LEDs but they have some.
wacojoe is offline        Reply With Quote Quick reply to this message
Old 05-25-2008, 07:09 AM   #16 (permalink)
Default Power source
ok, if you guys are looking for a good power source just tap into your main battery.
I did a full flight last night with no problems. I bought jst connectors and connected them right together off the battery.
Complete success, the power draw is so low there was no drain on the battery and flight time was good.
Now that I have the connector there I can easily disconnect the light for day flight, also never have to worry about the extra weight or having a seperate charged battery around.
Somebody please hit the staples button! "That was easy" :-)
Scotty T is offline        Reply With Quote Quick reply to this message
Old 05-25-2008, 07:07 PM   #17 (permalink)
Aballen that avatar of yours made me try to squish the bug on my screen. LOL.
Team Outrage
OPM - Fly it like it aint yours!
JR X9303 2.4 Baby. I have felt the difference and I like it!
Don"t make me list 'm all !
Raven_darkcloud is offline        Reply With Quote Quick reply to this message
Old 06-10-2008, 09:35 AM   #18 (permalink)
So I took my 450 out for a night flight with the K&B night blades, I set them up just like ya'll mentioned but I plugged into my open channel on my Rx, the light lite up but I was a little disapointed on the tail lighting up, it never really got up to a nice bright glow. Could this be becuase I need more power to the UV light? I even moved the light closer to the blades to see if that would help but it didn't make much difference.
T-Rex 450V2, 500 and 600 Shavers
Spek is offline        Reply With Quote Quick reply to this message
Old 06-10-2008, 12:19 PM   #19 (permalink)
The RX is only putting 5 volts to the LED.
I believe the LED wants 12 Volts, So running it direct off of the 3S main pack would be the best option.
The LED should only shorten your flight time by about 2 seconds.
Jeff Borowski
flyinfool is offline        Reply With Quote Quick reply to this message
Old 06-13-2008, 03:31 PM   #20 (permalink)
Awesome, thanks for info. I went out and picked up a little 3s 150 by Venom, just gonna strap that under my gyro and watch those blades light up the sky!
