Old 05-02-2004, 02:14 PM   #21 (permalink)
actually my friend doesn't own a Century, he flies mine when I let him...
I edited my post above...
Jim
Lieutenant Dan is offline        Reply With Quote Quick reply to this message
Old 05-02-2004, 06:19 PM   #22 (permalink)
I see I've made Jim's ignore list, along with a whole bunch of other village idiots. I so do miss the "WOW" factor Jim! Don't worry Jim, I won't bust your balls again.
Al Magaloff is offline        Reply With Quote Quick reply to this message
Old 05-02-2004, 07:04 PM   #23 (permalink)
Now that surprises me!
Ill bet some people miss that feature here.
Welcome to the club.
rstacy is offline        Reply With Quote Quick reply to this message
Old 05-02-2004, 07:30 PM   #24 (permalink)
Im just glad we can all start to act our age and not get so riled up when someone ruffles feathers intently for reaction.... Thanks Jim for starting a trend...
"FREAK" Out
~Bart~
ThBrtmn is offline        Reply With Quote Quick reply to this message
Old 05-02-2004, 10:18 PM   #25 (permalink)
Ray, Al, I'm actually starting to like you guys !!, I will take your names off my RR ignore list,
we are having a fun fly Jun 5th & 6th, if you guys can make it I will shake your hands (I promise to wash my hands first )
Jim
Old 05-02-2004, 11:15 PM   #26 (permalink)
LOL your to much Jim!!
Like i said glad you got her flying better
Fly On
Tom
Stator Gator
Sold Heli's to build AMC Racecar....still lurking
Tom Fiddler is offline        Reply With Quote Quick reply to this message
Old 05-03-2004, 06:24 AM   #27 (permalink)
Aw Jim. I dont know what to say.
Old 05-03-2004, 06:29 AM   #28 (permalink)
, I was simply cheering for my side !!
Glad to see you finally admit it Jim
Ray how is the little hawk flying for you?
Jeff H is offline        Reply With Quote Quick reply to this message
Old 05-03-2004, 07:45 AM   #29 (permalink)
[quote="Jeff H"]
Not as well as I would like.
I liked how it went together.
The head looks like an older miniature Xcell head.
The wire drive for the tail sucks big time.
It had serious wind up problems.
I was pretty certain that this would be a problem but many RR whiffle ball simulator pilots assured me that it wouldn't be a problem.
Well it is.
I did the SteveH upgrade to .093 drive wire and it did get better but it still not right. I didn't have a chance to work with it this weekend.
It also sounds like I received one of the clutch bells that didn't have the liner glued in properly. I may need to drop the motor and fix that.
I have to keep reminding myself that I only paid $159.00 for this machine.
The tail rotor servo and gyro cost more that the helicopter!
Tom F thinks that may be the problem. I need to go find a Fu Taba 153 gyro for this heli!
Old 05-03-2004, 10:15 AM   #30 (permalink)
LOL...I never thought of it that way...
"FREAK" Out
~Bart~
Old 05-03-2004, 11:29 AM   #31 (permalink)
I've got a 701 Telebee in the basement, and a FMA servo that I'll trade you. That way, you won't have that much $ tied up in it for that fateful day.
Old 05-03-2004, 12:00 PM   #32 (permalink)
Ray, try wheel bearing grease on the wire...
Jim
Old 05-03-2004, 01:57 PM   #33 (permalink)
exactly how does grease help with a flexibility problem?
Ray, Torque tube
Old 05-03-2004, 02:28 PM   #34 (permalink)
I don't believe the wire drive needs to flex !!, I used wheel bearing grease on mine and I never had a problem with the drive wire twisting, I use-to piro my Hawk so fast I was told I was going to brake something "but never did"...
Jim
Old 05-03-2004, 02:49 PM   #35 (permalink)
It isnt the pirouette rate that suffers.
It is the holding power that causes wind up.
Turn the gain up enough to get decent holding power and the tail will start whipping back and forth in an oscillating manor. The sound will be like a rubber band being stretched. The longer you let it go, the worse it gets.
I could get the wind up to stop by turning the gain down but then the gyro performance would be horrible.
Old 05-03-2004, 03:02 PM   #36 (permalink)
Ray...all I have is my experience with my Hawk and others around me...
...So you are saying that you are getting a wag in the tail? Is it during manuevers or hovering? Is it possible that it is the type of gyro or servo?
With mine and others around me, I havent ever heard the rubber band noise you speak of. One guy had a telebee once but got the 401 combo... thats what we were all flying on ours...I wish you could have flown mine before I put the TT in it.
"FREAK" Out
~Bart~
Old 05-03-2004, 03:10 PM   #37 (permalink)
I suppose anything is possible. This combo has worked in other helis.
The rubber band sound is a combination of the pitch and RPM of the tail rotor changing as it tries to keep with the demands of the gyro.
I havent had a chance to work with it much since changing the drive wire.
I hope to play with it this week.
Old 05-03-2004, 03:11 PM   #38 (permalink)
""The sound will be like a rubber band being stretched"",,, yes, yes, I did have this (and the wag) with my Hawk SEv2 wire drive with the 401 & S9253 !!
"oldfart" told me to use a longer servo arm and set the ball at the end of servo arm and turn down my sensitivity on the Tx, after I did this I never had that problem again,,,
oldfart called it GIO "Gyro Induced Oscillation"
when rebuilding after a crashed I saw NO sign of the wire twisting...
Jim
Old 05-03-2004, 04:56 PM   #39 (permalink)
Jim,
Thanks for the input.
That is exactly what I am running into.
And as you have found out, doing the things Phil suggested will settle it down.
The problem is that the gyro will no longer hold as well as it should or could.
Old 05-03-2004, 06:09 PM   #40 (permalink)
Jim and Bart,
do a blinding 540 and try to have the tail stop on a dime. It will overshoot every time. That is wind-up, any demanding tail manuver is almost impossible with a wire tail.
Try full speed backwards flight or forwards for that matter, then do a pyro. Notice how the pyro speed is very inconsistant... that is the wind-up.
