Like Tree11Likes
Old 03-27-2014, 12:45 AM   #281 (permalink)
Originally Posted by orthobird View Post
any other suggestions?
Have you tried the reverse button in step 7? Set stick to max collective and click it till the swash really at max collective
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote Quick reply to this message
Old 03-27-2014, 10:32 PM   #282 (permalink)
thank you all, i got it all set up!! thanks to all comments. now that i know, it is easy!!!! now, i am busting my head, trying to set up a meson 130 esc with a bavarian demon 3SX and a jeti Tx R3 (for a different helicopter)
orthobird is offline        Reply With Quote Quick reply to this message
Old 04-02-2014, 11:03 AM   #283 (permalink)
Is there a governor FAQ? What does sensing divisor mean?
Sent from my A500 using Tapatalk
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 04-02-2014, 12:29 PM   #284 (permalink)
To the best of my knowledge, there is no specific governor FAQ. Sensing divisor is the motor number of poles divided by two, or 1 for magnet sensors of glow engines.
Best regards,
Jose A.
ALZRC TRex 450 Pro DFC
ALIGN TRex 500 ESP DFC
ALIGN TRex 600E PRO DFC (Power booster)
Goblin 500
joanpeca is offline        Reply With Quote Quick reply to this message
Old 04-06-2014, 03:26 PM   #285 (permalink)
help...
i have a small Gaui X3 helicopter that i set up from a Kit
it has IKON flybarless system
and it has JR 9503
i am using SAVOX servos
6s system
when i spool up and get to about 1/3 stick, still while on negative collective, the hell tilTs to right and back
any idea what this is. i have made sure the swash is as level as possible with my eye and with using a small balsa stick as a gauge and mid stick on the Tx with servo arms at 90 degrees to the servo. the helicopter was programmed with the IKON computer program, and using a laptop with windows 8.0
this bird has never flown
it has not left the ground yet
i am just spooling it up on the ground first to see what happens
have never gotten it to the positive side of pitch.
i also placed it on a table with a level, and i was certain the table was flat to within .5 degrees. Then, i reprogrammed it with the IKON computer program. still doing the same thing, on spool up, once speed gets high enough, it will start to tilt back and to the right.
i also have adjusted the turnbuckles to compensate for this, and it has not effect on the problem. the problem persists.
Old 04-06-2014, 06:34 PM   #286 (permalink)
Default BRAIN Frequently Asked Questions
Do you have the self level on?
Life is like a helicopter! What you get out of it depends on how you fly it!
wlvn is offline        Reply With Quote Quick reply to this message
Old 04-06-2014, 07:25 PM   #287 (permalink)
yes, i undid it, and now all is good. thank you!!
Old 04-06-2014, 08:15 PM   #288 (permalink)
Cool! Have fun and be careful with the self level feature! Read about it before you play with it.
Old 04-07-2014, 07:42 PM   #289 (permalink)
Just as an FYI!! today was the maiden of my Gaui X3 with the IKON. outside of the small amount of tail jitters during flight, this is solid. well, one of my facebook friends sold me a T-rex 550 used, no batteries, for 500 dollars. it had a system in it: curtis youngblood total G, which i hear is good, but i have decided to remove that, and i purchased another IKON for this, my 3rd helicopter. going up from the blade 450 x, to the Gaui X3, and now this:
so now, i am here, asking for help??
question?
i am using a castle creations ESC, 6s lipo battery, IKON FBL unit, and align servos. my Tx is a Jeti DS 16. my rx is a Jeti R3.
i have bound the Rx to the Tx, and the R3 is plugged into the channel 3 of the IKON.
now, here is my problem??? on my Tx, i have to pick a swash type, only has three options: 3 servo, 4 servo, and mechanical.
on my Tx, i have gone to device explorer, and picked + PPM.
on the IKON PC program, going thru the steps, i have picked the swash that corresponds to the helicopter.
however, i cannot get "roll" output from my Tx to the Rx.
can anyone help? or is there something i am not doing, or maybe i am doing wrong. thank you.
Old 04-23-2014, 12:24 PM   #290 (permalink)
where can i find the manuall for the brain dont see it on MSH site,many thanks marty
Align 470M,stock motor,Kontoniks 60 amp esc,Futaba 760r gyro,Theta 921 cyclic servos and Theta Sabre T1 tail servo.
MeekaMoMo is online now        Reply With Quote Quick reply to this message
Old 05-07-2014, 06:47 PM   #291 (permalink)
I didn't see a thread for Brain feature requests but here is one I'd like to see.
I have on my DX8 a dial (AUX3) that I would love to be able to assign to pretty much any parameter in the Brain.
Take off, dial in the cyclic gain, for example before landing, firing up my BT/Android app and then assigning it to another variable/parameter and having the brain holding the value.
This would make setting up the heli so very easy.
Imagine how easy setting up SL would be if you could just pop her in the air and keep flipping the switch and adjusting the values until it levelled correctly.
I reckon I could set up a heli in a single pack with this option.
Atom 500
Spektrum DX8
Old 05-08-2014, 01:22 AM   #292 (permalink)
This thread is probably the closest to a feature request area.
https://www.helifreak.com/showthread.php?t=598239
At least we know Thomas reads it.
//Dennis.
Thunder Fighter is online now        Reply With Quote Quick reply to this message
Old 05-08-2014, 03:04 AM   #293 (permalink)
Will repost in there, thanks mate.
Atom 500
Spektrum DX8
Old 06-17-2014, 04:39 AM   #294 (permalink)
Default MSH Brain software with 6 Swashplate optiopns
Hi,
can someone give me a link to the older Brain Software for the PC?. Should be enough to copy only the folder with the files.
I need the 140° Swashplate with the Nickservo in front. In the current version there are only 4 options of swasplate and this one is missing (in the previous version was 6 options)
Best regards
Pascal
dxnemesis is offline        Reply With Quote Quick reply to this message
Old 06-06-2015, 03:06 PM   #295 (permalink)
Short question
Do i have to place the MSH brain in the centre of the machine?
I've a Compass 7HV and want to place the MSH and receiver next to each other on the gyro tray. So the msh brain is gonna be off centre of the machine, is this a problem?
I don't think so, but better asking if you're not shure ;-)
Spektrum DX9 & DSMX Satellites
Logo 550
Lynx Oxy 3 ( 4s )
sven75 is offline        Reply With Quote Quick reply to this message
Old 06-06-2015, 07:51 PM   #296 (permalink)
No issue with putting it off centre, just make sure the case isn't touching the side frame and that it is square to the mainframe.
//Dennis.
Old 06-07-2015, 01:20 AM   #297 (permalink)
THanks dennis :-)
Logo 550
Lynx Oxy 3 ( 4s )
Old 06-05-2016, 05:44 AM   #298 (permalink)
It took me a while to find out that Ch.7 ( Aux.2) was the Ch. used for selecting the Banks. I am using a DX6 G2 and found a post on how to change this to CH.5 ( thanks egiraldo911)
HeliFreak - View Single Post - How To Assign Bank (setup) switch on the New DX6?
and it works as it should , with values of 100 / 0 / -100.
When Brain 2 and the new Firmware Update becomes available with true Rescue function which Ch. will this be on, will it be universal as in function no matter which Bank one if flying in and no matter if SL is active or not?
It seems to me SL and Rescue should have their own required input values to activate them .
I have Ikon, two Brain s and a Brain 2 on pre-order and really looking forward to Rescue so I can fly more and crash less , I hope.
Anyone aware of a short wiring adapter to go between the Brain and its' wiring cable and BT device? I want the Brain connection to BT extended from deep inside the FBL to a point where cable from FBL to BT device is much easier. Why is this connection on Brain / Ikon recessed to where one must use an object to push connector onto pins and then pull on the wires to disconnect it (very bad). If someone made a solid header extension at a reasonable cost I would purchase one for each of my Brain / iKon FBL.
mS/R --3ea. mCPX 2 converted to BL 4ea. mCPX BL 2ea. BL-130X
400 FBL ,.Blade 450X ikon Blade 450X with Ar7200BX
Blade 300X MIcroheli CF frame many upgrades 230S , LOGO 690 Brain / HD , Trex 450 Pro with Brain ,planks...
everydayflyer is offline        Reply With Quote Quick reply to this message
Old 06-06-2016, 11:15 PM   #299 (permalink)
SL and Rescue are independent should you choose to run them that way. But with a 6 channel you would just basically have to have bank 1 normal bank 2 SL and bank 3 Rescue.
However if you have a 7 channel or higher tx you can have sl on lets say bank 3 and keep banks 1-2 open for flying and then put rescue on it's own channel and have combos. This would require giving up tail gain. If you have a 8 channel you can do all 3 at once
As for the adapter, look closely at the brain 2 they moved the sys io port to the side for very easy access. the bluetooth versions do not have a sys io port for obvious reasons however.
Team MSH USA - Cyclone Blades
MSH Prôtos 380 Brain 2
MSH Prôtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 06-07-2016, 12:07 AM   #300 (permalink)
Thank you very much for the clarification. I do not care for SL and only use it along with Transmitter mixs to create a Rescue . When real Rescue is available even a lowly 6Ch. should give me two Banks ( flying setups) which is plenty for me and Rescue available on a separate momentary switch. With a bit of programing (mixs) perhaps even three Banks and Rescue.
I can get on 3 way sw. 100 / 0 / -100 and 150 on a momentary in fact this is how a Blade 230S is programed at present on a DX 6 G .
If I had the required numbers ( values) I would go head a work on programing now and hope the upgrade is released very soon.
