Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion |
12-04-2014, 05:31 PM | #1 (permalink) |
KST Servos
Hey Guys,
Do KST servos not come w/Grommets or Brass Eyelets? Just ordered this (http://www.helidirect.com/kst-ds515m...ze-p-30077.hdx) and didn't come w/any. Also... Is the main servo shaft supposed to continuously rotate w/o stopping?
Trex 500e Pro, i2 Head, VX1e; Trex 550e DFC w/Blue Full Vbar, 730MX 600e Pro Performace Upgrade w/Blue Mini Vbar, 750MX Logo 600se w/Silverline Vbar Pro, PowerJive120, Pyro 700-45L Yellow SAB WobblinGoblin770 w/ iKon v2, Red Mostro v1 w/ iKon v2 |
12-05-2014, 10:42 AM | #2 (permalink) |
Is this a dead forum?
12-05-2014, 03:30 PM | #3 (permalink) |
yeah mine did not come with any either. I am looking to use the futaba ones. Part number FUTM2340 going to use these on my Forza 450. don't know if they work though.
12-05-2014, 09:58 PM | #4 (permalink) |
That's pretty ridiculous. How do they expect you to mount the darn servo? Did you notice if the output shaft on your KST DS515mg manually rotates around continuously w/o stopping?
12-05-2014, 10:02 PM | #5 (permalink) |
Just looled up the price for those grommets per your part number above. Cheapest I could find was $6 bucks. So now a $65 servo turns into a $71 servo. Hope it's worth it.
Have you gotten a chance to try it yet or do you know anyone who's using it as a tail servo on a T500? Do you think it will cut the mustard?
12-06-2014, 06:40 PM | #6 (permalink) |
its a 500 size servo so should be no problem for a 500. the grommets are not really needed for an electric as the vibration is almost none existent. the reason i need to use the grommlets is because the Forza 450 calls for them in a 500 size servo otherwise the screws are too long. so I either need shorter screws or grommets.
12-08-2014, 11:41 AM | #7 (permalink) | |
http://www.rcplanet.com/Futaba_Servo...p/futfsh20.htm THese worked great. I did not use the brass collets. You have to buy these separately. |
