Like Tree9Likes
Old 02-07-2009, 04:15 PM   #81 (permalink)
Thanks very much! Its a great heli. I'm sure you will love it!
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 03-22-2009, 03:34 PM   #82 (permalink)
How well did the cylic servos line up Rick, any modification required and did the supplied horns have holes at the correct distance?
X-Cell Fury 60 Expert
Hirobo Sceadu 30
Align T-Rex 500 ESP
RC budget, £100 per week, time spent building and flying, priceless!
fury is offline        Reply With Quote Quick reply to this message
Old 03-22-2009, 04:12 PM   #83 (permalink)
I didn't have to modify anything to install the servos. They were fine.
I think the horns were after market from my LHS. Not sure what brand or model.
Rick
Old 04-24-2009, 04:28 PM   #84 (permalink)
Sadly it looks like the picture links are dead. If possible I'd really love to see your build pictures.
Thanks in advance
Loki is offline        Reply With Quote Quick reply to this message
Old 04-24-2009, 06:14 PM   #85 (permalink)
Working on it. putfile.com went away for some reason ...
Rick
Old 04-26-2009, 09:12 PM   #86 (permalink)
Thanks in advance
OK Loki, the pictures are all restored. They are in my album now so we are not at the mercy of another site anymore. I may even have added a few more as I re-did it.
Rick
Old 04-27-2009, 01:46 PM   #87 (permalink)
Thanks a million.
It's nice to watch the Finless videos but also I can now print this out and refer to it! Again thanks for taking care of it.
Loki
Old 04-27-2009, 07:38 PM   #88 (permalink)
Thanks a million.
Loki
No problem.
Rick
Old 05-03-2009, 07:48 PM   #89 (permalink)
What is the wire wrap aound the wires I like it! Were can I get it?
Angelo
esmoglo is offline        Reply With Quote Quick reply to this message
Old 05-03-2009, 08:03 PM   #90 (permalink)
I used flexo clean-cut that I bought years ago:
http://www.techflex.com/prod_CCP.asp
Many use this:
http://www.readyheli.com/SearchResults.asp?Search=braid
You put the sleaving on first. I used 1/8" and 1/4" depending on how many wires I was running. It can be bunched up to make the inside diameter increase so that you can easily slide wires through it. Bunch it like an accordian and keep sliding the wire through. Slip some heat shrink over the ends after ward. Put the connectors back on then shrink the tubing. I bought an assortment of heat shrink sizes from Home Depot and used the size that was just bigger than the sheathing.
If you have to lengthen a run, you can buy servo wire extensions and then cut off the socket end and splice in the new wires. Put shrink around the individual wires to isolate them. You can shorten runs by cutting off the connectors then replacing with new ones.
http://www.servocity.com/html/servo_...s___leads.html
There are kits available to put on new connectors.
I use this one:
http://www.hansenhobbies.com/product...orkits/ck_sck/
Rick
Old 05-31-2009, 09:16 AM   #91 (permalink)
Originally Posted by rdlohr View Post
After months of homework for all the mods, I've finally finished my TREX 500.
The build took a long time and I found that I had to do many more mods then were required for either my 450 or the 600 builds. Some of the mods were required and some I just wanted to do. Ultimately, I’m really happy with the quality of the completed bird.
I tried to stay top end on the components since I have found that spending more up front usually costs me less long term and I am generally more happy with the heli. I didn’t follow this to an extreme though since I didn’t opt for a Jazz ESC on this build.
ESC: Stock Align
Cyclic Servos: JR Z3650s x 3
Tail Servo: Futaba BLS251 Brushless
Gyro: Spartan DS760
Component placement is always critical for me so I built off of all the lessons I have learned from the 450 and the 600 as well as lots of Helifreak input. Here are rules I generally try to balance while laying out components. Most of these came from Finless Bob years ago with an associated EEEK.
1) Isolate high current noisy components (Main Battery, ESC, and motor) from low current parts (Antenna, Battery, gyro, gyro controller, and receiver)
2) Protect all components from crash damage
3) Make heli parts you replace regularly easy to replace (Bottom Plate, Tail boom, belt, tail pulleys, etc)
4) Keep wiring runs short
5) Protect all wiring
6) Assure continuity from head to tail. (Newly added rule with this build)
Here's what I came up with:
I avoided running any wiring through the boom block area so it could be easily removed. I ran the wires on the outside through this area.
Side views with no canopy
The receiver and gyro were combined into one Electronics Module. It’s completely protected inside the rear of the machine and easily removable as an entire unit. This allowed me to minimize the wire runs between these components. I couldn’t use one of my TREX500 gyro trays since the Futaba receiver has its plugs on the top so I made a variant tray that slides in the back. The rear two plastic bottom plate screws secure it in place while allowing it to be easily removed. I was trying to avoid any rewiring when I have to swap out the plastic bottom.
When shortening the gyro to rudder servo run, I included a drop down diode under the shrink around the tail servo connector.
The ESC was placed inside the front to protect it and minimize high current wiring. It fits under there with no altering of the stock ESC wires like it was made to fit. I'll keep watch on that area for heat since both the motor and ESC are heat generators. I used a similar approach with my TREX 600 and have had no problems with it.
The ESC control line is isolated to one side away from all the servo runs. Each servo wire was run in its own sleeve to allow easy replacement if a servo dies. The Elevator and rudder servo wires were shortened, but the aileron and pitch servos were just barely long enough. I left some slack in the wiring in back to allow me to wire the Electronics module while shifted out the back.
I opted for a Revolution Whip this time just to try something different than the Deans. I used the antenna bobbin approach that OICU812 showed me while building my 450. I still use my 72 MHz receivers since they have served me well and I’m kind of waiting for the 2.4 radios to mature a bit. Notice also that I never run any wiring below the skid mounts because I have often seen the skids ripped off in a crash.
I opted for the Spartan DS760 gyro and Futaba BLS251 brushless tail servo (thanks OICU812) since I really want a locked in tail and was willing to pay a bit more to get it. Since the BLS251 is a full sized servo, I had to use a TREX 600 tail servo mount with the TREX 500 boom rings. I've seen others grind the 500 mount and make it work. I did use a drop down diode since this servo expects a 4.8 volt input and I wanted to drive my cyclic servos with the higher voltage. I was a bit worried about COG with the larger tail servo, but with the canopy mod and overall component layout, it balances perfectly without even having to move the battery down on the it's tray.
Since ESD is an issue for this heli, I did a number of things to minimize it. The main thing I did was make sure I had conductivity from head to tail through my frame and metal components. I did all the following mods to limit ESD:
1) Use metal tail and assure conductivity from shaft to boom. I used a file to scrape off the anodize just under the screws where the black plates connect to the silver frame. I also sanded the inside of the tail assembly where the boom enters. I filed the paint off the boom at both ends.
2) Copper foil on boom block to assure conductivity from boom to pulley to frame. The copper foil feeds way down into the hole for the cross tie so that when the cross tie pushes in it makes good contact. I filed the top edge flat across like a waterfall where it first goes into the cross tie hole.
3) Made frame into Faraday cage. I have no real proof that this mod helps and it took a few hours of work to do. I'm using it as a test bed to find ways to reduce ESD. I would not recommend others to re-create it. I in fact have already removed parts of it since the copper is thin and gets damaged easily when changing things.
4) Boom stop mod to keep it from hitting the belt
5) Metal cross ties in the boom block
6) Metal main bearing holders
Finally, I did ChasHeliCops canopy mod to make adequate room up front for my battery and linkages. This mod is sweet. I’ve never had a canopy fit more perfect.
ChasHeliCops thread: Easy Canopy Mod / Extra Room - HeliFreak
Many ask about the wire braid. I put sleaving on all my wires to protect them from rubbing on edges and to hide any splicing. I take off the connectors using the tip of an exacto knife blade to release the catch on each one.
Many use this:
I use this one:
I opted not to do the following mods:
1) Ground the motor mount to the ESC or battery negative. I prefer to leave my electronics floating with respect to the frame. I will ground it via a resistor or fuse if I later find I have problems.
Warning: Do not ground your frame or motor mount to the negative of the battery or the ESC without using something to limit current in case a short occurs.
2) Rollers to keep the belt from hitting the boom. I like this mod but I won’t do this unless driven to it. My 450 and 600 belts rub slightly too and I’ve never had a problem with them.
Docjoe's mod: Belt Pulley Mod - Page 2 - HeliFreak
Jetleaf's mod: Another Tail Boom Block Mod - Page 2 - HeliFreak
Things to be aware of when building:
1) Had to dremel some plastic away on the plastic bottom in front of the motor on one side to get the frame to lay flat
2) Set screws in the skids leave ugly thread marks in the white plastic
3) Boom needed to be shortened (may have been from the metal tail) Metal tail allows no belt adjustment - HeliFreak
4) ESD problem and associated mods HeliFreak
5) Tail rudder linkage had binding till I filed it a bit. Metal tail is binding - Page 3 - HeliFreak
6) Was difficult to get Spartan in programming mode because I had to plug in the Deans then quickly start toggling switches. I would prefer they give you an extra second or so. Spartan was simple to set up once I got it into setup mode.
As usual, Bob’s vids were invaluable. I found the Spartan vid particularly helpful. Thanks to all the many Helifreaks I borrowed ideas from and bounced ideas off of.
Bob's TREX 500 Build Link:
Trex 500 Build Videos - HeliFreak
Bob's Spartan DS760 Setup Link
SpartanRC DS760 Gyro Review and Setup Vids - HeliFreak
7) Some had had problems with the screws stripping out. Do yourself a favor and get the set of Align Drivers and you most likely will have no problem.
Very disappointed consumer - HeliFreak
The other option is to replace the screws. Heres a good link:
http://www.rcscrewz.com/product_info...oducts_id/2745
Another great resource for ESD and build stuff by ChasHeliCop:
500 Stock Mods Eliminate VDG Static w/ Videos - HeliFreak
All in all, it turned out pretty nice. I can’t wait to get out and fly it. It seems to be an overall solid bird and the size seems perfect.
Hope you like it!
Rick
Edit: Oct 4, 2008 Scorpion 1600KV Motor Upgrade:
I bought the Scorpion Motor and a Scorpion ESC back on father’s day when my family knew they wanted to get me heli stuff but didn't know what to buy. My stock Align motor squealed from the first day I powered it up. The squeal went away for a long time, but it had been intermittently doing it recently. I had been flying with it all season so I really don't feel bad about retiring it. Since I was going to the Heli Phenom, I figured it was as good a time as any to give the Scorpion a try.
I reused my 13T pinion since that seemed to be a good tradeoff between headspeed and flight time. I'm mostly a sport flyer anyhow (not by choice ).
The ESC connectors were different than the stock Align version so I had to solder new connectors on my ESC. I didn't put new connectors on the motor since I wanted to be compatible with the Scorpion ESC when its time to upgrade my ESC. Hopefully it will just plug right in.
The biggest changes were caused by the fact that the Scorpion is an out runner. Since the outside motor case spins, you can't locate wiring next to the motor or it will get chewed up. Strategically placed nyties solved this problem and overall the switch over went without a hitch. Here's some pics.
ESC Motor Lines to the right, and control line to the left. I ran the control line above the motor to keep with my philosophy of keeping the bottom plate easy to change in the event of a crash. The only wiring I have under the heli is my 72 MHz antennae.
Right Side showing routing of ESC control line over the top of the motor:
Left side showing nyties I used to assure the wires never migrate to the pinion or spinning motor casing area. Everything seemed to stay in place on its own but I used some nyties to be absolutely sure.
Closeup of the ESC Motor lines:
I took it outside under the spot lights and hovered a bit and it sounded perfect.
Enjoy!
Rick
If its a sexy T-Rex, why isnt it called a T-Sex? lol
ossiegoldhill is offline        Reply With Quote Quick reply to this message
Old 05-31-2009, 02:11 PM   #92 (permalink)
LOL, that could be confused with many things.
Rick
Old 02-22-2010, 07:14 AM   #93 (permalink)
Default Inspiring work
Wow, man. That is one seriously clean build.
I'm getting ready to build my first outdoor heli, a "beater bird" HK500GT. Got HK servos, Turnigy ESC and motor from Hobby King. Got the Spartan Quark and Futaba 9257 tail servo, Align main gear and 13t pinion from my LHS. Will use blades from LHS either right away or after I break the first set.
My biggest concern is making the breakage prone parts easy to replace, and I notice you emphasized that in your build. I won't put quite as much energy into making my heli as pretty as you have, but I plan to follow your component placement and routing scheme. I really like the idea of mounting the gyro and receiver on a plate together.
Am trying to decide if it's worth the energy to shorten cables, esp. the gyro. Really cleans things up and I'm sure it improves repairs, and looks like a fair amount of additional work up front.
I'm open to any advice you care to offer. I want to thank you for settng a really high bar on an awesome build, and sharing it with us.
freewheel510 is offline        Reply With Quote Quick reply to this message
Old 02-22-2010, 05:04 PM   #94 (permalink)
Thanks for the nice words! It does take a few hours up front. To me, that time insignificant in the overall scheme of things. On the other hand, many people don't shorten their wiring and it works just fine.
Rick
Old 05-21-2010, 10:06 PM   #95 (permalink)
Hey there...
That is a realy clean build. Attention to detail, right down to the removal of conectors to get the smallest braid on. Like the heat shrink too. A+.
Just finishing my first build. Trex 500 3G Flybarless. Hope mine turns out that clean.
Wattsy is offline        Reply With Quote Quick reply to this message
Old 05-21-2010, 10:09 PM   #96 (permalink)
Originally Posted by Wattsy View Post
Hey there...
Thanks Wattsy. I really enjoyed that build. Been flying it ever since with zero mechanical problems. Its still my favorite heli.
Rick
Old 02-13-2011, 11:49 AM   #97 (permalink)
wow, what a beautiful heli.
you did an awesome job with all that wiring, it looks very VERY clean.
ChrisRain is offline        Reply With Quote Quick reply to this message
Old 02-28-2011, 03:40 PM   #98 (permalink)
Thanks for all good tips and good pictures! You've got a really nice and clean bird there. Can't wait until I get mine a 500 ESP (2011 edition) during this week (it's on it's way from fast lad with UPS now).
I'll try to get a clean and tidy look as you've got but also make sure it's easy to repair after all my crashes.
Have you found any problems with heat on your ESC mounted under the batterytray, what esc do you got?
BR
Patrik
BR / Patrik
E-flite Blade Nano cpX, Align Trex 250SE, Align Trex 500ESP
Spektrum DX8+AR8000+AR7610+TM1000
Gameburg is offline        Reply With Quote Quick reply to this message
Old 02-28-2011, 04:15 PM   #99 (permalink)
Thanks Chris!
BR
Patrik
No problem with heat. I have the stock Align ESC still under there.
Rick
Old 04-03-2011, 07:23 PM   #100 (permalink)
As I am ready to start building my 500ESP 3g, your great build up was an eye opener.
rmklaw is offline        Reply With Quote Quick reply to this message
