Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 12-14-2012, 03:13 PM   #61 (permalink)
Seems like it would be fine anyone try one?
Angelo
esmoglo is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 06:17 PM   #62 (permalink)
Originally Posted by esmoglo View Post
Anyone try this BEC?
http://www.experiencerc.com/store/gr...0-p-11198.html
This one is $34.99 VS the WR BEC at $88.00
This is the WR Bec
http://www.experiencerc.com/store/we...k-p-11220.html
Weird that the Gryphon is a switching BEC yet it's specs mimic a linear BEC.
ScotY is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 06:19 PM   #63 (permalink)
Man, I have never been called cheap in my lifetime but I am still having a hard time seeing spending $90 on a monstrous BEC for such a small helicopter!
Old 12-14-2012, 06:44 PM   #64 (permalink)
when i sold the 6hv i kept the super bec things a monster i might use it ,or drive down the road to western robotics shop and see if i can do a trade in on a mini super
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2
TARANIS X9D + ,ez-uhf jr mod
GauiX5 Gauix3
kachur779 is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 06:50 PM   #65 (permalink)
Default gryphon bec
the gryphon bec's are excellent so far. I am using them on my TDR and Whiplash each at 14s. if I have any issues with my yge60 I will try this small one for $35
frito169 is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 07:50 PM   #66 (permalink)
Originally Posted by John Cook View Post
Are you guys sure you are not getting static hits? 2 belts, dry air, spektrum?????? Static????
I'm sure as well, zero Checksum Error's in VB Log, only low Rx Voltage.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 08:00 PM   #67 (permalink)
Originally Posted by Bob O View Post
Now that static/belts have been brought up, I haven't seen anyone mention grounding the boom at all in any threads or pics.
Would also like to know more about it.
Also, koby 55, ds92a+, ds95i, hc3sx, 1 spektrum sat. Gave the sticks a stir on the bench and no brown out.
Kendo is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 08:24 PM   #68 (permalink)
Yea I did the same test and all was good then I put on a second Sat and I went to brown town.....
Angelo
Old 12-14-2012, 08:32 PM   #69 (permalink)
So one sat it is then.
Still a bit sketchy being so close to brown out. Would setting bec voltage to 6v give more margin? In a way I'm hoping no, considering the price on the progdisk.
Old 12-14-2012, 10:13 PM   #70 (permalink)
I ordered a progdisk, I'll report back with results when I get it next week.
Synergy E5S 606 | Synergy 516 | Goblin 380 Buddy | Oxy4
kalleh is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 09:41 AM   #71 (permalink)
No it will likely be worse.
Increasing speed of servo's without decreasing load will result in higher current draw.
If you could increase Voltage then regear servos to run at original speed you'd have a decrease in draw.
Same principle as going from 6S to 12S but on a much less extreme scale.
Old 12-15-2012, 11:29 AM   #72 (permalink)
I have about 10 flights now with Spek Sats Koby 55 and Mks95's and 95i with no problems. Using Vbar. Might be an issue with the 95a's. I could not create brown out on the bench with multiple attempts. Mind u this is a mini p though don't have a 360 yet.
Logo 550SX, Modified Logo 400SE, Forza 450 3S
Lompma is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 12:52 PM   #73 (permalink)
Keep us posted I may just get the BEC Prog disk is $129 VS the WR BEC at $88.00 Again I should have gone with the YGE 40 and WR Bec combo from the begining I would have saved quite a few $$$ in the process. Jive/Koby are highly over priced and over rated.
YEG 40 would have cost $119 plus $88 for the BEC for a total of $207
Koby 55 was $189 plus a BEC $88 for a grand total of $277 Add in a Prog disk at $129 and it balloons to $406 yea that's nuts for a 450 size heli.
Angelo
Old 12-15-2012, 01:26 PM   #74 (permalink)
+100!!! 100 dollars, that is! I am in the same boat as you and not thrilled about it either.
Old 12-15-2012, 01:33 PM   #75 (permalink)
Does anyone have any issues with running the castle 10 amp bec? its only 25$ and i know a lot of people that have used them with no more problems then any other BEC.
for a long time running 6s 450s this was the choice of the guys that i knew ran hv setups
Dave Ketelhut
Team Compass USA
Gens Ace
Prostarhobby.com
Dave Ketelhut is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 01:44 PM   #76 (permalink)
The key here seems to be the unfortunate combination of spectrum sats being sensitive to voltage drop, the DS92A+ servos setting new standards in current draw, and possibly how the HC3-SX distributes power to the sats (can anyone create the brown out on another system?).
Old 12-15-2012, 02:26 PM   #77 (permalink)
On my other 450's that use the Mks 92a's I use the 10mm hole or 12mm hole, on the Warp I'm using the 15 mm hole and there's not alot if torque there so with the Warp doing a pitch pump where all servos are suddenly near stall I can see that : either we need stronger servos or some other method to lower amps?Or a bigger bec as servo load is probably more than your average 450.The Kst215 7v .05/3.7kg torque would be interesting.
Steve
Stevemech is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 02:39 PM   #78 (permalink)
That is my plan to go with the CC 10amp BEC or perhaps the one from ZTW:
http://www.quantumhobby.com/ZTW-6A-S.../ztwubec6a.htm
radu7 is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 02:58 PM   #79 (permalink)
when i do mine im just gonna get a yge90lv.
super small and a killer bec. 6amp continuous 12 amp peak.
Sent from my phone using Tapatalk2...otherwise i would of sent it from my home PC.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 12-15-2012, 03:34 PM   #80 (permalink)
Yes... the Skookum SK-720 with a single Spektrum Sat will give low voltage warnings.
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
