Hitec Gyro/Servos Hitec Gyro and Servo Support |
01-17-2007, 04:19 PM | #1 (permalink) |
Hitec Optic 6 : Ratchet on Throttle
Need a bit of advice.
I have been flying my TRex and Belt-CP with the Optic 6 but have been finding the ratchet throttle too coarse....so a quick delve into the back of the tx and I removed the spring steel that creates the ratchet. Now I have a smooth throttle throw but I am worried that there is not enough friction now. Is there a better way of removing the ratchet without removing all the stick friction? |
01-19-2007, 08:02 AM | #2 (permalink) |
Hi,
When I got my Optic 6 it came with an alternative spring steel plate that gave you some resistance but no ratcheting. I presume you didn't? You could always try refitting the original but with a piece of tubing over the end so you can't feel the ratchet and then bending to adjust the tension!
1. Trex 450s, 2. HDX frame, microheli bling, sk360, stretched for 350mm radix 3. Rotorworkz G4, 4. Micron FP, 5. MSH Protos 6. Electrified Raptor Ecureuil, 7. Vbar raptor E620 |
01-20-2007, 06:23 AM | #3 (permalink) |
If you call Hitec, they will send you a new non-ratcheting spring. I had to do that for my Eclipse 7. Great people Hitec. I just wish they had been able to get their 9 channel out.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
01-22-2007, 05:59 AM | #4 (permalink) |
Or push a bit of fuel tubing over the spring
Trex 600N Pro Trex 600N Sport Knight 3D |
05-27-2009, 04:09 PM | #5 (permalink) |
I have the same problem, but can't even figure out how to open up the Optic6!
I removed the battery, the module, the four long screws from the back, and the two small screws from the handle. It seems to be hanging up on the side where that black trim wraps around. Am I missing something, or is it time to just yank it apart? The plastic seems a bit brittle, so I'm hesitant to apply too much force having never opened up this one before. Thanks, n8
TRex 450 SEv2 : 430XL / Phoenix 35 / 12T / 325 woodies / HS-65MG / GY401 / S9257 / TP PP 2250 / DX-7 / AR6100 TRex 500 GF : BL500L / Align 75 / Castle BEC / 13T / Mavrikk G5 Pro / HS-225MG / Spartan DS760 / BLS 980 / Turnigy 6s-3000 / AR7000 |
06-22-2009, 12:36 AM | #6 (permalink) | |
screwdriver to pry off the black trim. |
06-22-2009, 01:09 AM | #7 (permalink) |
Taking the clicks out is very easy, All you have to do is manipulte te spring thats already in there. Hammer/flatten on a vise, Out the V bend and put a nice big radii (with a pair of needle nose) on the spring were you think (eyeball/measure) it's going to contact the gears. After that you can overbend the spring steel to get more tension if needed. I have done tis on a few Tx's including an old optic 6 I had.
06-24-2009, 12:14 AM | #8 (permalink) |
Thanks guys - I finally figured it out after tinkering for a while. :-)
I just flipped the steel upside down, and it gave a smooth tension that works for me. For posterity, I took a few pics along the way:
