Go Back   HeliFreak > R/C Electronics Support > Spartan RC
Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support
Old 04-18-2012, 02:10 AM   #361 (permalink)
I bet it'll work as perfect as Quark and DS760's works.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote Quick reply to this message
Old 04-18-2012, 09:24 AM   #362 (permalink)
I wonder how many Spartan Gyro fans will take the jump to FBL for the first time with the Vortex. The DS760 and Quark are so good I can't imagine the Vortex being even the slightest disappointment. This new generation of sensors will be interesting take for a spin for sure.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Old 04-18-2012, 09:28 AM   #363 (permalink)
I think it will probably be great as well, but everyone thinking that it will be perfect because the previous gyros were good are falling into a trap. Futaba has never made a gyro that wasn't amazing and there are plenty who do not like how the 750 flies (and even more before the first update). The SJGD gyros flew great, their FBL is trash, Youngblood's SOlid G and Mini G were amazing, many have had horrible luck with the Total G.
Good tail gyros do not equal a good FBL unit. There is a lot more to the software in the FBL world.
Eury is offline        Reply With Quote Quick reply to this message
Old 04-18-2012, 09:32 AM   #364 (permalink)
But I would be more inclined to trust Spartan than any of the rest. They have a stunning track record for producing great products and responding to their customers.
If I had to voice one issue that I have ever had with Spartan it would be that it has taken them so long to finally produce a FBL unit. I am currently down to two helis, both functioning very well on MicroBeasts. One of those, if it ain't broke don't fix it type scenerios. Until I have a need to get another FBL unit, I can't justify the switch. But as soon as that need arises, and the reviews are good, you can bet I will jump on board.
But again, I really really really would like to hear about some testing of the governor on a gasser. Gassers are different and to know that it had been tested and successfully worked would really go a long way in my book.
HeliXHeli 700 | VBar Silverline | TRM275TT
TREX 550 V2 DFC | VBar Silverline | CC Ice 100 | CC BEC Pro
Rototerrier is offline        Reply With Quote Quick reply to this message
Old 04-18-2012, 06:15 PM   #365 (permalink)
the new fBL unit will be up there but it would be hard to to top the Mikado Vbar
Vbar has been in the gane for quite a while and has allot of R & D behind it,
dl5973 is offline        Reply With Quote Quick reply to this message
Old 04-18-2012, 07:23 PM   #366 (permalink)
Thumbs up
Originally Posted by eurylokhos View Post
...Good tail gyros do not equal a good FBL unit. There is a lot more to the software in the FBL world.
+1.
+1. Those two post sum the essence, the new FBL unit may become a good one but its hardly belivable it will be so upon releas. Expect to see some updates before.
Mateyhv is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 05:49 AM   #367 (permalink)
I have every faith it will rock out of the box, but I'm sure there will be points to improve with updates...
It has had a long development time however, so you can be sure it won't have been rushed out the door.
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 06:18 AM   #368 (permalink)
[...]Vbar has been in the gane for quite a while and has allot of R & D behind it,
Check the date on this photo
http://www.facebook.com/photo.php?fb...type=1&theater
-Angelos
SPARTANRC - R&D
Angelos is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 09:39 AM   #369 (permalink)
I wonder if the gear ratio can be adjusted on this new unit? I would like to use the governor on my gasser.
Suat
Trex 700 Gasser
Old 04-19-2012, 10:19 AM   #370 (permalink)
The Capi
Not sure if I have ever seen a gov that didn't let you adjust the gear ratio.
Old 04-19-2012, 11:50 AM   #371 (permalink)
Here's one....
Old 04-19-2012, 12:43 PM   #372 (permalink)
The Capi
That doesn't have an RPM display so why would it need to know the gear ratio ?
Old 04-19-2012, 12:55 PM   #373 (permalink)
It doesn't. Just a response to your statement. If you wish to change it that's fine...but as it stands...this is a governor that doesn't allow you to change the ratio...regardless of merit.
Just showing an example of a governor that doesn't allow you to choose the gear ratio. Also doesn't allow you to fine tune the gains either. And it doesn't work on a gasser. Very limited governor.
There are others out there that are also more advanced but don't work with gassers.
Since this, and others, do not work with gassers I have to be sceptical about whether the Vortex will work with gassers. I hear and see good intentions, but until there is testing and proof, I reserve the right to be sceptical and would really like to see some testing and results from Spartan on it. I suppose it can be left up to the end users to find out...but that's a sucky way of doing product testing.
Old 04-19-2012, 01:03 PM   #374 (permalink)
The Capi
It doesn't have a gear ratio, therefore it doesn't invalidate my statement. All of which is really unimportant, no gov ever needs to know the gear ratio. The gov controls the engine/motor RPM, what that translates into in terms of HS is of only interest to us humans.
Old 04-19-2012, 01:34 PM   #375 (permalink)
Not sure what that's all about...so back to the topic...How about some information on how well this system will work on gassers? Myself and others honestly, really, genuinly want to know. I will very much be intersted in this system and will only be puting it on a gasser which is why I keep asking. With all the new gassers coming out, this will certainly be a very good thing to know.
Old 04-19-2012, 08:06 PM   #376 (permalink)
"All the new gassers"
What new gassers? Whiplash-G is still vaporware.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 08:11 PM   #377 (permalink)
-Angelos
Good to see you have been working on this since 2009
Mikado Vbar has been in production since 2006 and they have produced at least 9 versions thats is why their system works so well.
Im sure yours will be great too and I hope its better than vbar but im a little sceptical
Im happy if you prove me wrong
Old 04-20-2012, 03:42 AM   #378 (permalink)
I would like to add a special governor mode for gassers but very likely it won't be in the first release. It will come at a later firmware update.
-Angelos
SPARTANRC - R&D
Old 04-20-2012, 03:06 PM   #379 (permalink)
Hopefully the Vortex vx1 comes out before hobbyking bring out their own Turnigy flybarless unit.
God help Spartan if it takes that long.
http://www.hobbyking.com/hobbyking/s...ystem_v3_.html
Damm looks like its all over for Spartan Hobbyking is up to v3 already
Old 04-20-2012, 06:10 PM   #380 (permalink)
Turnigy....lol
Align Trex 700 V3 DFC HV - Vcontol Touch ¦ Mikado Logo 200 ¦ SAB Kraken 580 ¦ Align Trex 500X ¦ Sab RAW 500
Raydee is offline        Reply With Quote Quick reply to this message
