Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 04-09-2015, 07:48 PM   #1 (permalink)
Default YGE and Scorpion HK-4025-1100 HELP!!!!!!!!
I have the older scorpion HK 4025-1100 and the YGE 120HV non BEC ESC . I set the timing to 6 degrees and the PWM to 8kHz what the specs from Scorpion says but the motor wont spin up and it just cogs? This is in a Goblin 570 . Anyone have the right timing and PWM so i dont burn anything up?
_________________________________________________
Goblin Tri-Blade 630 gasser , Goblin Speed , Blade 360CFX , T-Rex 450L , DX8
Pingletonme is offline        Reply With Quote Quick reply to this message
Old 04-09-2015, 08:13 PM   #2 (permalink)
Yge recommends 18 timing for outrunner motors.
Pwm should be 8-12. I use 10 on my scorpion motors.
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 04-09-2015, 08:15 PM   #3 (permalink)
https://www.helifreak.com/showthread.php?t=418502
NO FLYBARS
504Rone is offline        Reply With Quote Quick reply to this message
Old 04-09-2015, 08:16 PM   #4 (permalink)
I just read that in the sticky post about over heating. thanks for your reply its a huge help coming from Castle Cremation's ESC's
Old 04-09-2015, 08:35 PM   #5 (permalink)
I've seen a 120hv on a 700. I highly doubt you'll overheat it. But start with 18 timing and 8 or 10 pwm.
Heli's I have:
Old 04-10-2015, 05:18 PM   #6 (permalink)
+1 on 18 deg timing & 10 kHz pwm.
dgunawan is offline        Reply With Quote Quick reply to this message
Old 04-10-2015, 05:41 PM   #7 (permalink)
+1 as well.
Nothing smaller than 700 .....
ah_liang is offline        Reply With Quote Quick reply to this message
Old 06-23-2015, 05:13 PM   #8 (permalink)
I'm running the 4025 III 1100 KV in a Logo 550 SX. It holds head speed quite well at 2200 rpm (P gain and I gain one step from maxed out) and turing down the I-gain on the tail fixed the tail flutter on funnels.
However I feel there could be more power, especially on 1900 where there's quite the delay before I can feel the gov reacting.
I'm running 18% timing with PWM set to 8 (as Scorpion says for that motor) and then 9.
Motor is supposed to be smoother with a bit more power at the cost of efficiency, right? So shall I go ahead and set it to 10 PWM? My ESC maxed out at 32°C (18°C outside temperature) and motor isn't too hot to touch.
700E Pro DFC, 550SX v2, 450 Pro DFC, mCPX BL, DX8
Crowbar is offline        Reply With Quote Quick reply to this message
Old 06-23-2015, 11:15 PM   #9 (permalink)
I suggest 10-12 pwm. You will notice much more power
Heli's I have:
Old 06-25-2015, 02:45 AM   #10 (permalink)
Did one flight on 9 and then a bunch with 10 PWM yesterday. Big difference in power, had to dial down the governor quite a bit. But wobble on stops got reduced which is a good thing. Only get 4:30 of semi-hard flight time, but that's quite alright.
I shall try 11 and 12 one of these days to see if the increased power is worth the increased heat and flight time for me. 10 is where it's at for now, I kinda wish I could control that in-flight with the transmitter so PWM goes down the more I get to center stick.
