Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 02-11-2013, 01:33 PM   #21 (permalink)
Originally Posted by Smok1n View Post
So my question is - where can you get a bare connector for making a new battery cable?
Here:
http://www.rc-connectors.com/index.p...vr1dajnfti5qj5
If you don't want to crimp, they have one assembled with wire but wire is only 28 gauge.
Shipping is only $2.
kingmeow is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 01:37 PM   #22 (permalink)
Originally Posted by kingmeow View Post
Here:
Thanks!
Goosky Legend S2
Goosky Legend S1
Smok1n is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 01:49 PM   #23 (permalink)
I am glad to see others are having the same dramatic results as I have.
I guess that confirms the theory about direct soldering to the ESC, upping the wire gauge and better connectors.
Happy Flying
737 Driver is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 02:03 PM   #24 (permalink)
Thanks for starting that thread mixfisto, and this one 737 Driver, they let me know I wasn't the only one unhappy with my mild upgrade.
A few more bits of information about my battery rewiring: -
I used 22awg stranded wire. This stuff is stiff but manageable, nothing to worry about.
This wire should be good for 10A continous and much more in bursts. It's probably overkill for this purpose.
My wiring, including the new connector, weighed about 1.2g. This is about 0.7g more than stock.
My unloaded head speed (zero pitch, taped to the bench) is the same as it was before I rewired - about 3800 rpm at 68% Tx governed. That's according to the helitach iphone app, which is well worth investigating by the way.
But the main thing is it now doesn't bog when I pitch pump
Next on the agenda is some battery life tests.
fac13 is offline        Reply With Quote Quick reply to this message
Old 02-11-2013, 03:56 PM   #25 (permalink)
Here:
Astroid design sells them cheaper (60 cents)
http://astroid-designs.myshopify.com...e-battery-plug
I just ordered some.
P@reez is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 02:21 PM   #26 (permalink)
Did you get all of them? Apparently they are a hot commodity now. I was waiting to order the connector when I placed my wicked motor order and now the wicked motor is in stock but no connectors.
kpod is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 02:40 PM   #27 (permalink)
It's wild and that set up comes with the connector...
Oxy 2 FE, 180cfx spartan lynx pro tail,130x stock, Goosky S1 x 2 , mcpx stock x2, mcpx bl mod, nano cpx dbl bl, nano cpx wild bl, nano cps, DX8. For fpv Phantom 3 pro.
Bhujang is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 02:47 PM   #28 (permalink)
I ordered the wicked kit and it connects to a 300x. I was hoping to order the connector for my mild kit that I currently have though at the same time though.
Old 02-12-2013, 03:25 PM   #29 (permalink)
Default Re: BL Nano- Bog to HOT DOG
What's your order #?
Sent from tapatalk
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 04:49 PM   #30 (permalink)
Whoops sorry! Thought you meant the 16500 motor size for the nano...
Old 02-12-2013, 05:11 PM   #31 (permalink)
Never mind, just put 2 and 2 together with your name
Old 02-12-2013, 06:56 PM   #32 (permalink)
Hey 737 Driver, my motor slipped away from the pinion today and crashed me. I just had done a forward flip up 20' I guess and it went strait to the ground. No harm done except the pain of getting the motor back in. I attempted to glue it in and took too long to get it in and the glue set up and had to all be scraped out before I could get the motor back in. While I had it apart I went ahead and ran the battery lead strait to the ESC the way you originally did it with the stock connector and servo wire.
Got all that done and the tail motor wouldn't work. Apparently the sticky tape under the esc had pulled loose my tail FET which I had replaced the 3rd day I had the Nano. So I had to resolder the tail FET and all is well. Rain and dark set in so only hovered in the house but can't wait to take it outside.
It was already doing considerably better after resoldering the esc leads to the board.
It would be nice in the future if the brushless kits came with a heavier battery lead and connector already soldered to the esc or at least in the kit with the idea of starting off that way.
If its fixed don't break it!
Bladecpnitro is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 07:22 PM   #33 (permalink)
Yeah, I think it's probably the way to do it. Would be top shelf from the get-go
mixfisto is offline        Reply With Quote Quick reply to this message
Old 02-12-2013, 07:41 PM   #34 (permalink)
Yeah but not all Mild kits bogged using the stock battery wires, I think it might have something to do with the wires being frayed where they enter the main board, or a dodgy connector.
You guys are a small sample out of the 500+ Mild kits out there, if the stock wires weren't up to the task for 99% of people you would hear a lot more complaints!
I will most likely make the Mild kits come with the wire and connector though, and will be the same price as the Wild kits
Old 02-12-2013, 08:14 PM   #35 (permalink)
Dylan,
I gotta tell you - I am loving this mild kit! So glad my stock motor burned out and I couldn't find a replacement.
BTW: I did the heavier wire direct to the ESC, but only because I had a flaky battery connector anyway. I was having no bogging issues with the stock wires soldered to the stock location. Running the suggested throttle range - 68 % flat curve in Norm (now IU1) and 75 % flat curve in IU2. (DX6i)
Goosky Legend S2
Goosky Legend S1
Old 02-12-2013, 09:25 PM   #36 (permalink)
And that is why Dylan rocks
Old 02-13-2013, 07:21 AM   #37 (permalink)
I just tested my battery to esc mod this morning and its worse than ever before. With my best lipo I'm now reaching low voltage cut off at 3.5 minutes where it was 4.5 minutes with my lesser batteries after resoldering the ESC to the board. My guess is I didn't get a good solder joint to the esc with the battery leads. A good solder connection makes a lot of difference too.
I took a short cut and soldered the leads to the front of the board where the pos/neg pins come through the board. I'll probably have to move the leads to the back of the esc where the other wires are connected to the esc.
Old 02-13-2013, 08:25 AM   #38 (permalink)
My bl mild kit actually flew very well with the stock wires and I went back to check and I don't have them soldered to the esc. I resoldered them to the front of the board where the esc wires solder to, not directly to the esc. I didn't want them pulling on the esc and breaking my other solder joints.
The only reason I believe my initial set up didn't work as well as it should have was that when I soldered the esc to the board, I believe my poor soldering skills loosened the connection the battery wires made to the back of the board. I completely removed them and soldered to the front of the board and the problem was solved.
I'm starting to believe my current bog issues are 100% battery related. I have 4 eflight 35c batteries coming to test this theory out.
I still like the idea of the thicker gauged wire. I plan on dropping in the wild motor to give it a try. The thicker wire should guarantee that we get the most out of the mild setup as well. I just hope the added benefit isn't outweighed by the weight of the wire.
Old 02-13-2013, 12:01 PM   #39 (permalink)
My situation has gotten worse. I took it back in to recheck my solder joints and now the main motor won't spool up. It starts but goes right back off.
Anybody have any ideas on where to look for the problem?
The only thing I've done different was to relsolder my battery plug on to the heavier wire because it broke loose bending it around to plug it into the battery and move the battery wires to the back of the ESC.
Could it possibly be my main motor FET?
