Old 06-02-2014, 10:44 PM   #1 (permalink)
Default Futaba system very jumpy
I have just finished building a new TREX 450 Dominator with 3GX and Futaba R7003 RX, using SBUS connection from RX to 3GX and radio is T14SG, ESC programmed for 6.0V BEC output. After putting in the electronics, I immediately noticed the servos would jump every once in a while. Its not just your typical buzzing, but an actual movement of the servo, maybe 20 degrees or so, but very fast return to neutral position. Even my motor has kicked a couple times while in throttle hold. This is an all new system, all fully charged batteries, and stock kit. The issue has been observed for the last few days and I have no idea what could be causing it. There could be something operating in the area around me that I am not aware of, but I thought these modern 2.4GHz systems with frequency hopping were pretty immune to most types of interference. Right now, I am afraid to even maiden the bird due to the noise issue. Can anybody tell me what might be causing the issue I am having?
IS FURY AND FIRE A RED LINE
tworst is offline        Reply With Quote Quick reply to this message
Old 06-03-2014, 10:52 AM   #2 (permalink)
What servos? Try changing the radio from 12CH mode to 14CH mode and see if that helps.
-Doug
dvelez3 is offline        Reply With Quote Quick reply to this message
Old 06-07-2014, 05:11 PM   #3 (permalink)
I am using the standard align servos that come with the 450 DOM kit and I am already using the 14 channel protocol. I have done about a dozen flights now and have not noticed any ill effects while flying, but I still need to put it back on the bench and monitor it some more to see if the problem is still there.
Old 06-07-2014, 06:03 PM   #4 (permalink)
Unplug the speed controller and power up the RX and such with a battery and see if the prob. goes away. You are pushing your luck flying with a glitch like that.
SAB Piuma 6S, Xnova LIGHTNING 4030/1000kV, Spirit FBL
SAB Goblin 700 Q4530-500, Sprit FBL
SAB Buddy Egodrift Tengu 3220HS/960kV, Spirit FBL
TRex 450L 6S Spirit FBL
Mr.HillBilly is offline        Reply With Quote Quick reply to this message
Old 06-07-2014, 06:14 PM   #5 (permalink)
Dont use sbus 2 port
helicraze is offline        Reply With Quote Quick reply to this message
Old 06-07-2014, 08:57 PM   #6 (permalink)
Tap and wiggle the wires where they connect into the RX and then FBL and try to get it to happen. Could be a bad wire or connection. Take the ESC/BEC out of the loop by unplugging them and using a separate RX pack. Keep trying to isolate the cause.
Range check the radio ( with the motor unplugged) with someone standing next to it to see if it gets worse.
Tap, wiggle and shake everything. Something is not right and it will not get better in flight unless you fix it first.
brianapp is offline        Reply With Quote Quick reply to this message
Old 06-08-2014, 08:00 AM   #7 (permalink)
You want me to tell you whats causing the issue ? Because I had the exact same issue exactly the way you describe it, and I was running a DX9 Spektrum with two satellites. Your problem is a 3 letter word that starts with a "3" and it ends in an "x" and there is a "g" in between somewhere
For me, it was worse in the 3gx setup modes with my transmitter close to the heli. When I put the heli armed have a friend hold the radio 15 feet away and watch the heli (safely) it would go away.
Same radio system on a cheaper ar7200 beastx, was not doing the glitching.
jsbach#1 is offline        Reply With Quote Quick reply to this message
