Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-04-2012, 08:04 AM   #1 (permalink)
Default New 550 to 600 frame.. HEX50!
HEX50, is the own designed frameset. optimised for use with HV powerystems, and for flybarless, (resolution in VBAR is 100/100!! for 12.5 pitch and 8 cyclic, Beastx has the blue light at 5 degrees or 6 degrees with optional longer servohorn and bellcranks.
Frame will take any setup in HV, ranging from packs from 950 grams to 1350 grams(that equals 12s 2650 to 4000 with 600 blades and tail, maximum 1150 grams with 550 tail.). 6s setups also possible with 2 6s packs parralel.
Motors that can be used are the stock aligns, or the 40XX scorpion/hyperion.
Design will change a little, servos will lay flat to get more room for the ESC.
Its very light, with 2650mAh packs, the heli only weighs 3.55kg, with 3800 packs(1300 grams), the heli weighs 3.85kg, and it feels anything but heavy!
Those who are interested may send me a PM.... and i'll see what i can do.
(picture shows 12s 3800mAh Gens ace.. still 1 cm forward in the battery tray)
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, Gryphon Rotorblades, RCbearings.co.uk,
Nko15 is offline        Reply With Quote Quick reply to this message
Old 04-04-2012, 02:46 PM   #2 (permalink)
woah.
Lunar Wolf is offline        Reply With Quote Quick reply to this message
Old 04-05-2012, 01:12 AM   #3 (permalink)
Been waiting to see some actual pictures up close, the little comment droping here and there kept my anticipation up. Reminds me a little about a frame I had seen about 2 months ago (http://www.helituning.com/index.php/...0e-frames.html). Yours is much better in regards to the battery location and options to use some high capacity packs. I might be interested, but would like to know how much stuff from a 550e frame portion is new and is it provided or does it need to be purchased seperatly?
Guessing from the looks of it one would need at least:
- New servo arms
- Servo linkage
- Servo levers
Wynn
Logo 550sx
Wynn1427 is offline        Reply With Quote Quick reply to this message
Old 04-05-2012, 02:52 AM   #4 (permalink)
Everything is included in a kit to convert the 550 into this machine bellcranks and its holders are custom made. not an off the shelf part (they are 5mm thickness, will NEVER break!, and yes, i tested that.. LOL), Links are included, balls are included, elevator servo arm(for futaba/savox,align/mks/torq only now) is included(needs special hole distance in order to work with the bellcranks. Bolts, bearings etc, its all there.
only thing you'll need extra are 2 of those 6 armed servohorns. wich will come with the servos in a 550 kit... The bellcrank/elevator horn to swash links can be used from the 550. stock gear from 550(mod 0.7) will fit too. .
otherwise, shoot me a PM, we'll work it out.
I dont like the helituning frame.. i think its too thin at the bearingblock/motor area... that WILL flex with HV or powerfull 6s setups. .. This frame handles the 4035 just fine for the 100+ flights ive been hammering on it.
Really the only problem my frame has, as i designed out of the point of view for a HV 600, it doesnt take 6s 5000 packs. with the stock tail, 2x 2650 or 3300 or such in parralel will work tho. 3800 or 4000 will only work (and is only needed) if you use 600tail/ blades. AND: the motorshaft needs to be long enough to mount the pinion upside down(setscrew on the end of shaft.)
Old 04-06-2012, 04:51 AM   #5 (permalink)
that looks great...i just bought new side frames for my 550 .
why does the motor pinion need to be fitted upside down?
and approximate cost please?
thanks
chris
warp 360-ds92-ds525m-polaris bec-beastx-edge 50 lite-yummy
Synergy E5-castle 100 ice-bec pro-beastx.
futaba T8FG--R606FS/R617FS
chrismechanic is offline        Reply With Quote Quick reply to this message
Old 04-06-2012, 04:06 PM   #6 (permalink)
because the motor is mounted on top, and there is very little room between the gear/motor it needs to be upside down.
Cost will be around 150 euros including all the hardware.
Currently modifiying the frames. will upload some pictures when the next prototype is cut.
Old 04-06-2012, 04:25 PM   #7 (permalink)
V2.1...
Old 04-10-2012, 03:48 PM   #8 (permalink)
Just send the new v3 frame to the CNC'er who's gonna cnc them for me. 45XX motors now also fit, as do the Pyro 700.
Old 04-14-2012, 11:57 AM   #9 (permalink)
Ok, i now now 2 things
1: my frame crashes really well, even from tailslide crashes!
2: Align headblock is too weak for hard 3d flying:
Old 04-15-2012, 05:17 AM   #10 (permalink)
what happened nko15 ???? did the head break in flight ?
chris
Old 04-15-2012, 07:15 AM   #11 (permalink)
Broke in flight after a tailside. I think the Jbolt broke first, leaving the head stuck on with the other half broken/bend bolt(wich was stuck in the hub too). and the head just broke away.
Old 04-15-2012, 09:01 AM   #12 (permalink)
that must have been some tail slide
what are you going to replace it with?
Old 04-15-2012, 09:33 AM   #13 (permalink)
Stock.. Hahahahah. Going to drill them out to accept a M4 bolt.
Old 04-17-2012, 09:28 AM   #14 (permalink)
Made the modification.:
Threaded the mainshaft, use 1 M4x7 12.9 bolts. WAYY stronger, no chance of wobble in the headblock due to double clamping on 2 bolts, and less chance of breaking/bending the jesusbolt.
Align should go with a 3 bolt head design. 1 bolt isnt strong enough for the torque a 10/12s system has.
Old 04-17-2012, 10:27 AM   #15 (permalink)
Have you thought about using the KDE head with 1 Jesus bolt and 2 bolts more to lock the head down?
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 04-17-2012, 01:05 PM   #16 (permalink)
Yep, thought about it, But since i have an own design swashdriver, i cant use the KDE head(clearance issues). On top of that, its 75usd.... Might go with the Outrage head.
Old 04-23-2012, 03:40 AM   #17 (permalink)
Made some mods.. V3 is rtf, some pictures here:
bunch of CNC parts
Frame put together..
Both machines... V2 in front, V3 in the back
I'll fly these machines at 3Dmasters 2012 in the experts class Come watch them!
Old 04-23-2012, 04:27 PM   #18 (permalink)
Flight from today(not that good of a day, nor the flight)
needs tweaking, didnt have a laptop with me
[ame]http://www.youtube.com/watch?v=m8YIReIyk6Y&[/ame]
Old 04-23-2012, 06:56 PM   #19 (permalink)
You are having way too much fun
Keep at it!
Mark
Old 04-24-2012, 05:45 AM   #20 (permalink)
+1 there...great flying, groovy tunes...way to much fun Anko.
here in the uk we have rain...rain and more rain...
now when is the v4 coming ?
chris
