Old 09-10-2013, 04:46 PM   #1 (permalink)
Default Batteries
Hey all, forgive me for asking such a stupid question but in currently out of 6s packs for my trex 500 (2200mah) but i have tons of 3s 1300 mah pack.
So i was wondering if I wired two 3s packs in series what flight time I should get?
I only want to get into a hover to double check everything is working fine and it doesn't need gain adjusting or anything. Thanks in advance Darcy
Sent from my GT-I9305 using Tapatalk 4
Darcy Brown- ZenRC Field Rep
RED! Goblin 500, Quantum 4120-1200, BK Servos, from www.zenrc.com.au
ORANGE! Goblin Speed, Kosmik Kool 200HV, Pyro 850-50L, BK Servos, Brain
NevErSn0w is offline        Reply With Quote Quick reply to this message
Old 09-10-2013, 05:19 PM   #2 (permalink)
Short answer is 1/2 mAh = 1/2 flight time, but the discharge C rating may limit the head speed (are you using a governor?). To get the amps, the supplied volts may drop. If the volts drop, so does the head speed for a throttle setting (unless governed).
Unless I am mistaken, a 30C rating on a 1100mAh pack is the equivalent to a 15C rating on a 2200mAh pack (regardless of cell count). The discharge C rating is how fast you can pull current from the cells in the battery.
Smaller batteries tend to have a higher IR. The higher the IR, the more heat generated during current draw.
There is not a limit on the amount of current requested, just the current that can be supplied. Faster current draw, the more the battery heats up (bad for LiPo's :-) - Why we let them cool before charge and discharge - Internal flashpoints and all)
By wiring in series, you up the cell count (S). By wiring in parallel you up the mAh rating.
You can do it if you must, just watch really carefully (and limit flight time even more). No point testing a 500 if you send it up in flames.
Old 09-10-2013, 07:36 PM   #3 (permalink)
Okay, the packs are 40C
Maybe I should just wait for my 6s packs to turn up
Old 09-10-2013, 11:20 PM   #4 (permalink)
Good call. Impatience in aviation leads to unscheduled landings.
Old 09-11-2013, 01:49 AM   #5 (permalink)
What size 6s packs did you purchase? I hope you didn't buy 2200 mah packs for a 500.
Trex 700L Ikon 2 / Trex 700L Ikon V. 2 / SAB Goblin 500 Sport Ikon 2 / HD Cell 500 Ikon 2
It isn't about if, it is about when!
Old 09-12-2013, 03:03 AM   #6 (permalink)
Think I got 2500 mah pack and a 3000 mah pack
Old 09-12-2013, 12:09 PM   #7 (permalink)
2500 is a bit small. I tried the 2600 and found the flights too short. I went with the 3000mah and works great.
Old 09-13-2013, 12:11 AM   #8 (permalink)
What's your flight time with 3000mAH?
suthae is offline        Reply With Quote Quick reply to this message
Old 09-13-2013, 12:14 AM   #9 (permalink)
I have my timer set for 6 min. I actually get the longest flight time on my 500.
Old 09-13-2013, 10:30 AM   #10 (permalink)
Later on you can get a 600 and use two of your 500 packs
jrwalte is offline        Reply With Quote Quick reply to this message
Old 10-14-2013, 03:11 PM   #11 (permalink)
Okay, so I ended up with 3 3000mah packs
Trex 500 esp, Compass Warp 360, Spektrum dx7s
Old 10-14-2013, 04:40 PM   #12 (permalink)
Happy flying. Your patience should be rewarded.
Old 10-15-2013, 05:39 AM   #13 (permalink)
Thanks mate, now just to wait for a nice day
