Engines and Mufflers Having problems or need advice on Engines or Mufflers? |
12-08-2012, 01:15 PM | #1 (permalink) |
Filling with nitro
How do you fill your tank?
Do you have a T piece near the carb inlet. Do you not have a T piece and just pull the tube. Do you fill from the muffler side?
Have a great day - John "Do it to them before they do it to you" {Hill Street Blues} When the blue light is flashing I am kidding. E&OE. |
12-08-2012, 01:28 PM | #2 (permalink) |
I pull the line off the carb to fill.
Nice clean look. All my filters are in my fuel jug so no filter on the heli. |
12-08-2012, 01:35 PM | #3 (permalink) |
i pull the line off my tank. filter in the can and fllter in the line to the carb
12-09-2012, 08:58 AM | #4 (permalink) |
I use a T-style filter in the line to the carb w/ a short piece of tubing, plugged at the end. Just pinch the line below the carb and pull the plug to fill the tank.
12-09-2012, 10:09 AM | #5 (permalink) |
No one yet fills from the muffler side then!!
12-09-2012, 10:43 AM | #6 (permalink) |
I would but the laws of physics say no. Although it is very good at filling the motor
TT titan x50 / TT mini titan / JR Vigor CV... ...vbar'd / 700 airwolf streched JR Voyager mechanics / JR Venture CP |
12-09-2012, 11:58 AM | #8 (permalink) |
Yes - I personally don't do it this way but have come across it twice recently and the method quite surprised me.
Also, in general I don't like pulling tubes off the barbs on filters.
12-09-2012, 02:31 PM | #9 (permalink) | |
The heat makes the fuel line brittle and pulling it off the muffler repeatedly will wear it out 100X faster than anywhere else. |
12-09-2012, 09:25 PM | #10 (permalink) |
muffler - not to mention that it hurts like hell if you touch it and leaves a nice blister. makes no sense to me to have anythng going on on the muffler side. i use a t.
12-10-2012, 12:31 AM | #11 (permalink) | |
Fuel goes into the tank and goes to the lowest part of the tank where the pick-up is also located. Since the fuel is being pushed in it want to find a way out which happens to be the pick-up that also at the lowest point in the tank. Henceforth out the pick up into the engine (or header tank and the same thing happen but in a smaller scale). Very little actually stays in the tank. Or, if there's enough back pressure from the motor and the pump is strong enough then it blows a line off.
12-10-2012, 12:35 AM | #12 (permalink) |
I've always used a t connector except on kasama because they have a built in separate line for fuel but I also use an in line filter. That is a must I think, especially if you use a fuel magnet. In case it deteriorated and went straight to the motor.
TDR, Srimok N x 2, Banshee 31, Dune! |
12-10-2012, 05:22 PM | #13 (permalink) |
We always fill from the inlet side because as you fill the tank with fuel the air has to be vented out through the muffler line
Rave 450 | Lepton | Logo 400/500/600 | Aeolus | Sceadu | Freya | Avant FX | Raptor G4 Gryphon field rep |
12-10-2012, 05:43 PM | #14 (permalink) | ||
