Old 01-25-2010, 02:11 AM   #121 (permalink)
Does anyone know the dementions of the old Zippy-H 3300 mAh 6s1p 20c lipo's ?
I'm thinking of buying the new 2650 40c or 3000 40c but i dont know if the new 3000 mah are the same size. I have the Trex 500 "Classic" with tray mod. The 3300 fits perfectly between the fame.
Spec.
Capacity: 3000mAh
Voltage: 6S1P /?6 Cell / 22.2v
Discharge: 40C Constant / 50C Burst
Weight: 524g (including wire, plug & shrink wrap)
Dimensions: 144x45x41mm
Balance Plug: JST-XH Discharge Plug: 5.5mm Bullet-connector
The 2650 are not on stock. And i want to use two of them in a Trex 600 aswell. I have seen people put 2x 550g on a 600 so that should not be a problem. But i dont know if this one will fit my 500 without cutting the frame.
I rather had the 2650 but i'm already waiting about 2 months for those.
Edit:
And just like that they are on stock got 8 2650 mah 6s1p comming over. Lower weight would be better for both the 500 and 600. Got enough lipo's and you can charge 5c so its not a disaster that the flight times are a bit shorter.
Astennu is offline        Reply With Quote Quick reply to this message
Old 02-06-2010, 10:19 PM   #122 (permalink)
Im using 22.2V 4.0 mAh 6s turningy lipos,however i had to slightly modified my battery tray to make the canopie fit, i will share the projet .im now having over ten minutes of cruise flying which i divide in two stage of 5 min at time
Name:	CAR PICTURES 005.jpg
ID:	138095   Click image for larger version
Name:	CAR PICTURES 003.jpg
ID:	138096   Click image for larger version
Name:	CAR PICTURES 004.jpg
ID:	138097   Click image for larger version
Name:	CAR PICTURES 002.jpg
stealhty1 is offline        Reply With Quote Quick reply to this message
Old 02-09-2010, 11:42 PM   #123 (permalink)
It looks like you found an easy way to turn your old style frame into the new style frame. Good job.
550 Trex FBL, Beastx, Kontronix 100 Jive
500 Trex FBL, Beastx
450 Trex Sport
All flown with my DX7
Tommygunn is offline        Reply With Quote Quick reply to this message
Old 02-11-2010, 07:28 AM   #124 (permalink)
Originally Posted by jndell View Post
Has anybody tried an A123 in their 500? and if so how did it do?
thats one of my special things A123 the one that i use is the 6 cell 19.9v 2300mah from A123 Racing ($89.00 some thing ) but with the 14t is not posible to fly in a good HS (1700 rpm) <> you have to get a 16t (2600 rpm) and it good to do some flips inverted hovering mild 3D.i haven't try the 17t.but flight time is pretty good 6 min flat.
heli bob is offline        Reply With Quote Quick reply to this message
Old 02-11-2010, 07:44 AM   #125 (permalink)
Originally Posted by DerClown View Post
Guys, with the 6s 3300 or 3000 pack hows your 3D ? Are you able to do tic-tocs, other tricks, that demands stick banging ? I mean is the bird not to heavy ?
the heli with a 14t it good and HS is over 3000rpm tic-toc good for me i dont do them very good very sloppy still practice i need.
Old 02-11-2010, 07:48 AM   #126 (permalink)
how did you cut the frame with out spliting the CF
Old 02-15-2010, 07:13 PM   #127 (permalink)
Default Flightmax 5000mah 6s1 15 c
Long flights, perfect cg, no puff. try it from HK.
Pard is offline        Reply With Quote Quick reply to this message
Old 02-19-2010, 03:40 PM   #128 (permalink)
At first glance this thread would seem to be all about capacity, but a lot of folks are evidently more concerned about what will fit physically, and how the heli performs carrying whatever the weight is.
So, simple really; could I please request that folks with the new frame state what the dimensions of battery they have found to fit. Should anybody have been unlucky enough to invest in a battery which didn't fit, it might be rather handy to hear about its dimensions too!
From what I've read the 500ESP tends to be a bit tail heavy, and so a weighty battery (say 560g rather than 450g) may be just what's needed to balance it. What weight of battery is considered ideal?
Also, for 3D (which I am only just starting to explore) are you better with a weighty battery, or a smaller one positioned as far forwards as possible? Given that for a given C rating a larger capacity battery will deliver more amps I suspect that this question may not be so simple to answer!
Thanks,
Steve
Steve Evans is offline        Reply With Quote Quick reply to this message
Old 02-20-2010, 02:39 PM   #129 (permalink)
There's a point to where there is a trade-off for how hard the system has to work to carry the extra weight. You may get the same flight times with a lower capacity (lighter) batt, as you will with a higher cap. (heavier) batt. depending on the type of flying you do. Then "C" rating comes into play too....balnace the mah with the "C" rating for your application.
Some are trading shorter flight times for lighter helis to throw around hard. If you are just cruising, or just venturing into mild 3D weight is not as critical. It's something of a balancing act, depending on what you are doing, or what you want....flight time....or perfomance....or a little of both.
I know I can not articulate as well as some....so I'm not sure I put it right.
Trex 600esp/Trex450Sport
DX7
Flyextreme is offline        Reply With Quote Quick reply to this message
Old 02-20-2010, 04:23 PM   #130 (permalink)
I hear what you're saying! It's a bit like choosing between a BMW M3 and an M3 CSL which lacks the power seats, climate control etc. Life is a compromise! Maybe the fact that I didn't choose the CSL means I should be getting fatter batteries? ;-)
On a more serious note, I can't help but wonder if the recent update to the 500ESP shifted the balance a bit. The "old" 500L motor is 650W/800W(30 sec), whereas the 500M is a rather more impressive 1260W/1470W(30 sec). Effectively doubling the power would seem to open the possibility of carrying a little extra weight. Presumably the lowered battery tray of the new frame shows that Align are expecting folks to be using bigger batteries to go with the increased power?
This rather makes me most interested in hearing what battery gives the best CoG (assuming that I can still put the ESC under the battery tray), working on the principle that that's something that must be correct, and having achieved that I'm likely to have struck the capacity/size compromise that Align intended for this model.
Steve
Old 02-25-2010, 05:04 PM   #131 (permalink)
with an metal hand saw just let it sink into the frame
Old 03-08-2010, 09:50 AM   #132 (permalink)
Thanks man i got the pack from HK 22.2v 3000mha 6cell and fits thanks i dint need to mod the heli.
Old 03-25-2010, 09:33 AM   #133 (permalink)
Hi, did enyone tried these batteries? Do they fit?
Rhino 3700 6s.
http://www.hobbycity.com/hobbycity/s...idProduct=9341
cmax is offline        Reply With Quote Quick reply to this message
Old 03-26-2010, 03:12 PM   #134 (permalink)
Would a newbie building a 500 esp be better off going with a standard battery or try going big? I gotta order some batteries soon.
robertsm is offline        Reply With Quote Quick reply to this message
Old 03-26-2010, 03:21 PM   #135 (permalink)
Many different opinions here but at some point the larger batteries will be a trade off between weight and longer flight times.
I can tell you that the 6s 3000mAh 40C's from HK is top notch and works awesome. They also have perfect COG with the TT and ESC underneath the battery tray. The only problem is that they are so popular that the stock lasts for a few days at top. I ordered another bunch about three weeks ago when HK got new stock and it sold out within a day. I guess I was part of the problem...:o
Heli G is offline        Reply With Quote Quick reply to this message
Old 03-31-2010, 11:46 PM   #136 (permalink)
Default Try this!!!!
http://www.hobbyking.com/hobbyking/s..._25C_Lipo_Pack
hellikev is offline        Reply With Quote Quick reply to this message
Old 04-01-2010, 01:52 AM   #137 (permalink)
Originally Posted by hellikev View Post
You're rather missing the point. The idea is to identify what batteries will fit in a 500, not find the biggest battery you can!
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz
Old 04-01-2010, 01:42 PM   #138 (permalink)
Steve
I was quite suprised to see how big it was when i opend the link.
Old 04-11-2010, 05:55 PM   #139 (permalink)
Dang, just got my 3000mAh 35C from hk, they're wider than my 3300mAh I bought a year ago... so I had to cut the frame to get them to fit (last year I dropped the tray down about 1cm to fit the 3300mAh) but the 3000 ones are wider than the 3300 - I should've checked.
anyways, I cut the frame to make them fit..
the wires are like two or three times thicker than the 3300, and somehow I hard a hell of a time to solder them onto the deans connectors.
10inja is offline        Reply With Quote Quick reply to this message
Old 04-13-2010, 09:21 PM   #140 (permalink)
Smile Fusuno New Shape Canopys
I got my Turnigy 6S 3300mAh 30C in my 500 with out any modification in the frame, I use the Fusuno New Shape Canopy, works perfect and you don't need modify the heli to use this large lipos, the heli looks nice and more agresive
BonewJunior is offline        Reply With Quote Quick reply to this message
