Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion > KDS Agile 7.2
KDS Agile 7.2 KDS Agile 7.2 Discussion
Old 03-18-2014, 05:22 AM   #1 (permalink)
Default 7.2 flight times.
Just wondering what flight times you guy's are getting.
I'm running 800mx 520kv motor with 19t pinion, HS governed at 2050, 5000mah opti's . Getting around 4 mins mild 3d.
Just not long enough I would prefer nearer 5 mins.
Dean Tamsett
Lynx Team Pilot: www.lynxheli.com
doomdpuma is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 06:16 AM   #2 (permalink)
4 min
Scorp 4525-520
19t
Pulse ultra 5000 65c
2250rpm
If you want more flight time u can lower your hs to 1900 or get bigger packs
The agile is pretty heavy...
Tri$tate 3D | BK Servo | Switch Blades | HeliDirect | Canomod
cjpainten is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 06:28 AM   #3 (permalink)
It really depends on how you fly and stuff also it depends on what size main blades you use. A lot of the team guts use 710s which can help and you don't need as much pitch. Yes the agile is 12lbs little heavier then some 700, but put that into perspective. The 7.2 is a bigger 90. 3 inches longer and a 7hv and taller. Not as big as a logo 700xx. Also that weight helps with a lot of things like if you fly in a lot of wind, and feels more solid then any 90 I've flown which is quiet a bid of them.
Sent from my SCH-I535 using Tapatalk
Team Empire Hobby Team HobbyWing
Gaui X7F, Gaui X7 FZ, Gaui NX7
Bubba Gump is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 05:30 PM   #4 (permalink)
I just received a 18T pinion. In my theory, it should give longer flight times.
Its more in the ballpark for governor at 2100 hs, and smaller pinion should be easier on the batteries.
I run a 750MX 530kv motor and got 3:30 minute flights with the 19T pinion.
Will come back with numbers after flying it this weekend.
TRCHK
BorgeBorge is offline        Reply With Quote Quick reply to this message
Old 03-19-2014, 08:34 AM   #5 (permalink)
You could loose the Gov and run Throttle Curves, this is usually good for close to another minute.
Same head speed as Gov but with one or two less tooth pinion.
It's an option anyways.
