Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 06-27-2014, 09:26 AM   #21 (permalink)
Suspect Lipo failure if the voltage is low, beware that most chargers like to see the balance connector and the supply leads, check with a normal voltmeter.
LOGO 500SE & 600SE & 600SX
Synergy E7 -
N7 - N5C
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzTDR + II
Alun
CyprusFlyer is offline        Reply With Quote Quick reply to this message
Old 06-29-2014, 06:43 AM   #22 (permalink)
Default Re: TDR down last week.
Originally Posted by otavon View Post
Hey guys,
I purchased the Ultraguard like 4 months ago. It was working fine and now no there's no power going to it, I can't charge it and Optipower is non responsive to my inquiries to them.
I try to charge it with my ICharger 3010 but it says low voltage. Any thoughts?
You're not plugging the circuit board output to your charger, are you?
I have found that mine will not charge itself on the 6V BEC. I don't know if that's normal or not, but I always check it and charge it with the charger when needed. Maybe yours wasn't charging and it got way too low?
Danny Dugger is offline        Reply With Quote Quick reply to this message
Old 06-29-2014, 08:46 AM   #23 (permalink)
Sounds like the lipo run right down, connect up the charger on Nicd mode until the voltage is over 6v then change to lipo mode. If your charger insists on the balance lead connected you'll have to make up a charging/balanced combined lead. I think the BEC would have to be 7.4V plus to charge the lipo, not enough circuitry on the Ultraguard to step up voltage. You could PM a question to Linus, the designer ...
John
Old 06-29-2014, 09:11 AM   #24 (permalink)
Yes, I believe that is the case. I did send Linus a message this morning, though, to see what he says.
Old 06-29-2014, 04:16 PM   #25 (permalink)
OK guys, I heard back from the man. The Ultraguard should be able to step up and charge with an input of 5.3V or above without a problem. Here's a chart from the manual I never read. Lol
Old 06-29-2014, 11:33 PM   #26 (permalink)
WHat's a manual ??
Interesting info though !
John
Old 06-30-2014, 06:38 AM   #27 (permalink)
WHat's a manual ??
A waiter in Fawlty Towers
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 06-30-2014, 02:00 PM   #28 (permalink)
ROFLMAO, more seriously I can confirm that the UG does step up and charge perfectly using the default 5.6v from the Kontronic ESC.
Synergy E7 -
N7 - N5C
Alun
Old 06-30-2014, 04:01 PM   #29 (permalink)
Yeah I'm sending mine in for replacement. The step-up voltage regulator burned on it for some reason - actually melted the heat shrink.
Old 06-30-2014, 04:07 PM   #30 (permalink)
Noticed something funny with my U/G,,it was hooked up, when I was fixing some servo gear damage. No other power source present. I was moving a servo arm when I saw its LEDs light up, then a few seconds later, smell of electrical burning. I unplugged it's lipo and all seemed well, I guess I can understand voltage generated by the servo triggering it to life but not sure what caused the burning smell, have to go back and check it with a magnifier ..
John
Old 06-30-2014, 07:03 PM   #31 (permalink)
Sounds like nothing I want on my helis.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 06-30-2014, 10:54 PM   #32 (permalink)
+1...i do however have one but still in its original packaging. I do however prefer R2 prototype buffer....only 40s of servo power once main power source fails...which honestly I think is enough should something go wrong. Maintenance free unit but not so pretty
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 05:03 PM   #33 (permalink)
There are only two connectors; the balance plug and the one J plug that goes to the receiver. Where should I connect it to so it charges? I'm lost. Sorry
otavon is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 09:40 PM   #34 (permalink)
The battery only has a balance tap and no other connector so you either have to make or buy a harness to charge from the balance connector. I just used servo connectors
The external pins of the female Futaba J connector (without the extension housing) plug into the balance tap. The other two connectors are male Futaba J connectors: one is connected to all three leads and is for the balance board, the other is only connected to the black and red wires and is connected to a Futaba J charging connector. It's pretty easy to make and the Futaba connector will not allow you to plug into the balance board backwards
Old 07-14-2014, 04:26 AM   #35 (permalink)
Moved to another thread as it's not TDR specific.
HedgeHeli is offline        Reply With Quote Quick reply to this message
