Like Tree1Likes
Old 12-01-2012, 08:34 PM   #121 (permalink)
Well after more than 100 flights and a hand full of crashes, i have got a twitchey servo. I ordered a new one and i hope my hands will be able to replace it. Other tahn that this heli has been great , it just came back from disney and flew great in the wind,
TREX 800 DFC PRO HV , TREXIKON 600 EFL PRO , LEAP 3D QUADCOPTER
Heli biggie is offline        Reply With Quote Quick reply to this message
Old 12-01-2012, 08:55 PM   #122 (permalink)
Sounds like it needs a cleaning. It's mainly the silver track that needs the cleaning. I use deoxit. Red liquid. Then follow up with Deoxit Fader Lube.
I get the 100% sample size. Comes with four of the Deoxit types. You use very little.
Some people use the Deoxit spray from Radio Shack. It's 5% solution and the rest is the delivery solution. I heard they don't even bother taking the servo apart. Just spray like they do WD40.
The mCPX is famous for it's jittery servo. It's just one of those maintenance thing with Blade's linear servo.
Daryoon is offline        Reply With Quote Quick reply to this message
Old 12-02-2012, 10:33 AM   #123 (permalink)
Well i have a servo on order already but i will keep that in mind, now today i wake up to no more power, i believ the motor is dead, so how do i get the motor out?? This thing is too small. But i love it.
Old 12-02-2012, 04:20 PM   #124 (permalink)
Disconnect the motor plug, then simply push it out from the underside with a screwdriver (it's glued in place)
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 12-02-2012, 07:30 PM   #125 (permalink)
You may have to unhook your servo leads also.
Lu523 is offline        Reply With Quote Quick reply to this message
Old 12-03-2012, 06:50 PM   #126 (permalink)
Another covington ga in the house, we should fly some time ,
Old 12-05-2012, 02:23 PM   #127 (permalink)
My new never crashed nano has bad vibrations which I feel when I hold it in my hand. I have perfectly balanced blades, I've tightned the feathering shaft a little and I've tried different main blade tensions. Nothing of this helped the problem. What's the next thing to do? The heli is unflyable... :-(
I'm used to micros, have had 4 walkera micros over the years.
GAUI X5, Align 450PRO, Blade NCPX
togy is offline        Reply With Quote Quick reply to this message
Old 12-05-2012, 04:33 PM   #128 (permalink)
Did you check your main shaft if it's bend? I know some Nano's that came out of the box with slightly bend main shafts. Worth taking a look
timox72 is offline        Reply With Quote Quick reply to this message
Old 12-05-2012, 08:03 PM   #129 (permalink)
With me it would be more like crashing.
Old 12-06-2012, 01:33 PM   #130 (permalink)
I checked the main shaft and it is bend despite never being crashed.. Is it hard to change it? Seems like its glued or something, how do I do?
Old 12-06-2012, 02:32 PM   #131 (permalink)
Buy a new one. Looks like the collar is CA's on the shaft. I wish they would have pinned it instead.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 12-06-2012, 03:22 PM   #132 (permalink)
I've already have ordered one:-D. I'm more concerned about getting the main gear back on.
Old 12-06-2012, 03:24 PM   #133 (permalink)
I made a shaft today with the collar from a stock shaft. While not exactly painless it comes off after a few knocks. Would be great if we could find a fitting collar somewhere.
Kendo is offline        Reply With Quote Quick reply to this message
Old 12-06-2012, 03:38 PM   #134 (permalink)
He Craig,
What you can use for a new collar is one of the sides of a MSR head link. Incredible tight fit over the 2mm main shaft. I'm flying with that on my wild set up without any problems
Old 12-06-2012, 03:59 PM   #135 (permalink)
He Craig,
One side of the stock collar has a small collar that sits on the rotating inner part of the bearing. How would this work with the msr head links?
Old 12-06-2012, 04:25 PM   #136 (permalink)
I used "un cure". Put it on, waited only a few secs, twisted off with a pair of pliers. No problem really.
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 12-06-2012, 05:15 PM   #137 (permalink)
Well, the stock collar needs that because of it's thickness. The MSR head links have a much smaller diameter so the whole "msr-collar" rests on the inner part of the bearing
Old 12-06-2012, 05:41 PM   #138 (permalink)
Here are some measurements:
- Outer diameter MSR head link 3.64mm
- Outer diameter of the bearing inner ring 2.86mm
- Inner diameter of the bearing outer ring 4.13mm
Give or take 0.02mm, it was a bit tiny to measure. As you can see the MSR head link works perfect here
Old 12-06-2012, 08:42 PM   #139 (permalink)
Hahaha. I fly at earl oneal soccor field at 4 pm when it works out perfect. I need room for the 450 and 600. But that only happens 2 times a week if im lucky. Most of the time its a quick few flights before the sun goes down off the deck, im still waiting on new motor. If the brushless setup becomes available again i will be getting that. I miss my nano.
Old 12-07-2012, 06:13 AM   #140 (permalink)
Is it possible to post up a pic?
mixfisto is offline        Reply With Quote Quick reply to this message
