Go Back   HeliFreak > R/C Helicopter Support > Beam
Beam Beam Helicopters Factory Support Forum
Old 07-04-2012, 07:40 PM   #1 (permalink)
Default avantgarde needs more pinions sizes
i really need a 14t pinion to make the head speed i want using a cc80hv gov.. will a logo pinion mesh with the avantgarde gear?? i wish beam would make a 14t and 15t pinion...
audio131 is offline        Reply With Quote Quick reply to this message
Old 07-04-2012, 08:05 PM   #2 (permalink)
Yeah that is a bit weird, 12t, 13t then straight to 16t?
It just limits your motor KV choices I guess.
Team Old Mate - He's a good bloke
timmytron is offline        Reply With Quote Quick reply to this message
Old 07-05-2012, 06:20 AM   #3 (permalink)
Default pinion
true ,but i only had a 600mx and a 700mx motor.
Old 07-05-2012, 02:50 PM   #4 (permalink)
Will the 700mx motor fit?
. Futaba 16SZH, Trex 700X, MicroBeast Plus, , POWER LAB 6
hobdean is offline        Reply With Quote Quick reply to this message
Old 07-05-2012, 04:04 PM   #5 (permalink)
Default motor
hi. i think itwill fit if u dremel the frames towards the gear side. about an 1/8.. i went with the 600mx first because i wasnt sure of the balance points yet.. it maybe too nose heavy with the 700mx depending on lipos used .. can always use stick on weight on the tail to campensate,,,,,UPDATE---700mx fits with out mods .expect needing to drill motor mount to make the 4mm bolts fit
Old 07-18-2012, 07:24 AM   #6 (permalink)
Default still need pinions
really need a 14t pinion for the avantgarde,,beam please make one
Old 07-26-2012, 12:15 PM   #7 (permalink)
Sorry for the many questions, I guess without not seeing it I dont undersand how you drill the motor mount the make the 4mm bolts fit? Could you please give a little more detail? What pinion are you using with the 700mx?
Old 07-26-2012, 03:51 PM   #8 (permalink)
Default motor mount
that motor mount was made for a 600 sized motor which the bolt pattern uses a 3mm bolt,, 700mx motor uses 4mm bolts to attach to a mount,, so just drill out the mount till u get the 4mm bolts to go thru it and into the 700mx motor.... used the stock 12t pinion..flat line throttle curve. the pinion is no high enough to run cc gov,. rreally a 14t is needed..
Old 07-28-2012, 09:07 PM   #9 (permalink)
Will cc ice 2 80 hv handle 700 bx
Old 07-29-2012, 07:04 AM   #10 (permalink)
Default 80hv
on a 600 ship. no problem
Old 11-28-2012, 05:35 AM   #11 (permalink)
I just found that mikado make one in m1
lowey79 is offline        Reply With Quote Quick reply to this message
