Old 06-30-2014, 07:32 PM   #1 (permalink)
Default Finding a good upgrade motor for a 300X... Scorpion 2208-24 winner.
So got my 300X I got used off RCG today got all my stuff put in went out to try out and darn thing about did a flip on the ground. came in took the blades off, head off, main shaft out everything and the motor is vibration like crazy...
so now need motor but don't really have funds to spend much
any ideas..
the stock e flite motor might been okay if someone hadn't decided to fill a HUGE chunk out of the side of it
Anyone ever see someone do this to a motor?
ID:	519306   Click image for larger version
ID:	519307   Click image for larger version
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 07-01-2014, 06:49 AM   #2 (permalink)
Wow no one.. Okay so it seems the following motors have been used sussefully in the 300x
Scorpion 2208-24? Not much info other then someone did try this one
scorpion HK2213-14
Hyperion 2213-3585
Lynx 2214-3S-4100
dons wicked
Any others anyone using that work well and or comments on the ones i listed
Like to see all 300x sized motors listed here, and using stock 1300 mah battery
if your using a 450 sized motor please list the pinion u using, HS ur flying at and batt size and flight time thanks
Old 07-01-2014, 07:18 AM   #3 (permalink)
I've never seen that before. I use the lynx motor 13T pinion using a talon 35 esc governor at 3500, 3650 and 3800 on the stock 1350 lipo. Very smooth and if I only fly gentle sport I get 4:30 with about 30 seconds to land and I'm putting back just over 800 mah, but if I get aggressive on the stock lipo I need to be on the ground in 3:30 minutes. Be aware my 300X is a heavily modified, heavy weighted heli.
terryv83 is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 07:49 AM   #4 (permalink)
Thank you for that info, you have a fully decked out aluminum heli i guess. on a 1300mah 4 minute flights is fine with me. That lynx is a 300 sized motor right, i wont have to cut anything to make it fit into the stock frame or do you know
Stock motor is 1.022 diameter
Old 07-01-2014, 11:09 AM   #5 (permalink)
http://www.hobbyking.com/hobbyking/s...arehouse_.html
I am using this guy right now with 11 tooth pinion. I have the 12,13 and 14 tooth pinions and will test each one but the 11 is real smooth and im getting almost 4:30 flight time. for the price you cant beat it!
shinybrute is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 11:49 AM   #6 (permalink)
I run a Typhoon 450H 2215-3550kv, 14T slant pinion (Lynx 136T main gear on stock hub) YEP40 governed at 3700RPM.
Flight time is 3.30 (Nano-Tech 1.3 45-90C) pretty hard 3d practice...
http://www.hobbyking.com/hobbyking/s...50_class_.html
Oxy 285 (6s) (AR7200BX, HKII 2216-16, Koby40) T-REX 450L (6s) (VX1e, HK 2520-1880, HW50v3), Goblin 570 (12s) (VX1n, HKIII 4025-550, Jive80+HV)
Lynx Team Pilot / Oxy Field Rep
Livan75 is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 11:50 AM   #7 (permalink)
Stock esc or something else? man that motor is heavy...
I am looking at the 2208-24 motor its lighter then stock and i just try a Scoprion 2221-8 in mine with a 13 tooth so i know with a 13 tooth a motor that size would fit.. but if it cant go with a 13 t pinion on the motor i dont kno how the elevator will ever clear you guys must be running lot shorter arms
Old 07-01-2014, 11:55 AM   #8 (permalink)
Well that one is a lil lighter then the other.
14 tooth pinion oh wow. how come the driffrent tooth main gear? is that why you running a 14 so the mesh would mesh up w/o the motor hitting the elevator control arm
Thanks for the info
Old 07-01-2014, 12:21 PM   #9 (permalink)
If you try this one, please post your impressions, I'm interested in it as well.
I've been using the Parkfly P2632. Very happy with it, but apparently no longer available.
Murph_d is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 12:36 PM   #10 (permalink)
Yeah, I think I am about decided on it, Looks like th stock ESC will be fine with it and I found some data online looks like with a 13 tooth pinion you can get 3400 HS at 90% TC and 3100 HS at 83% at least one guy did and we did the math and it seems really close.
I hate to pay Almost $60 for a motor this was suppose to be a cheaply built heli.
Old 07-01-2014, 01:10 PM   #11 (permalink)
yeh, the Parkfly was only $8.00. HK lists this one http://http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=8144 for $13.95 but I don't know anything about it.
Old 07-01-2014, 01:45 PM   #12 (permalink)
Yeah I asked somewhere else about that one and someone said didn't think it be very good, someone has a 300X for sale here with a red looking moter like that in it and i PM asked about the motor and never heard back from them.
Old 07-01-2014, 03:12 PM   #13 (permalink)
Thanks for the info
Its because the kv on the Typhoon motor is much lower than the kv on the stock motor so you need the bigger pinion to get the correct head speed (3550kv vs 4500kv). Not rubbing against the servo arm is a bonus
The Lynx slant main gear and stock main gear is about the same diameter so I guess the lower number of teeth is because of the shape of the teeth, can fit less on the same diameter...
Old 07-03-2014, 06:40 AM   #14 (permalink)
Thanks for the info, I went ahead and ordered a Scorpion HKII 2208-24
I got a 11-13 tooth pinion for it too, plan to use the 13 I will post data once i get it and run it I will post real life head speeds with my tach, and sure i will hook the watts meter to it and see how many amps it is pulling, all this be done at 0 pitch with a fresh battery. I plan to tach it at 70/80/90/100 % TC to see how much difference.
should be sometime next week.
Old 07-04-2014, 01:26 PM   #15 (permalink)
Might be Don's wicked motor the same size as parkfly 2632 from HK which is pink.
vronny is offline        Reply With Quote Quick reply to this message
Old 07-04-2014, 01:37 PM   #16 (permalink)
yeah i think it was a dons wicked. after looking at the tunigy one on HK seems a few have had the wicked motor, seen one on ebay yesterday
Old 07-04-2014, 02:45 PM   #17 (permalink)
Any idea what headspeeds would be normal when governing the Scorpion 2208-24? Its very similar in KV to the TGY Typhoon so would 3600~ be attainable?
EDIT: Or would be Scorpion/Hyperion HKII-2213-14 be more suitable for those headspeeds?
Tuvison is offline        Reply With Quote Quick reply to this message
Old 07-04-2014, 03:39 PM   #18 (permalink)
I used to run gov mode back in the day with the old blade 400, and a castle esc, so did my father and we always had some tail wag and i have read others who said using Gov mode they have tail wag, a part of me wants to try gov mode then a part of me doesn't but anyhow as i posted above one guy ( I did a google on that motor for data and found it) said he got the following data
and 3100 HS at 83%
I will be testing at 70/80/90/ and 100% HS to see what I do indeed get. I mean its not trouble to test to find out.
I am really hoping for at least 3500/3600 at 100%, just because I flew my fathers with 3300 max and it felt a lil slow. but it was flyable.
I went with this motor over the 2213 or whatever cause of the weight and i wanted to be able to use the stock ESC. I still might add a BEC to the stock esc. or might go ahead and try my castle 25esc and just put a BEC on it. however with the stock switching BEC I should be okay. Also it seems this motor will fit into the CFX frame w/o hacking the frame
I am bad at math, but i would think the 2213 would go on up to 3800 or more maybe. there is data on this site just have to dig it out.
Old 07-04-2014, 09:09 PM   #19 (permalink)
2208 won't maintain 3600 under load because it's a 220W-ish motor for a 250-size heli. You need at least 330W from 2213 (if efficient enough like the Hyperion/Scorpion) or 2214 (Lynx) or even 2215 (Typhoon).
Old 07-04-2014, 10:03 PM   #20 (permalink)
Thanks DoubleCh but I was talking 0 pitch is what I will be testing at. guess i should have posted that in flight I have no clue. I know my dads Trex 450 at 3600 is INSANE power.
